Keyframe Animation
Keyframe Animation This node contains the animation curves and the animation logic for all bound properties.
In contrast to most 3D applications, Ventuz does not associate animations with the scene directly. Instead, the curves, keyframes and logic information of an animation all belong to a Keyframe Animation node. A scene can therefore have any number of independent animations each with its own set of animated properties, timeline and keyframes. The information of an animation can be edited in the Animation Editor. For more information on animations in general, see Animation and State Engine.
Each Keyframe Animation node contains a timeline independent of the global scene time. To play an animation, a Control Node has to be bound to the Control Input Property.
Animation Logic
If an animation contains an Animation Logic, the nodes icon is colored blue instead of green and additional input as well as output properties are available.
Then each node will provide a number of Input Methods that can be used to interact with the state machine. For an explanation on the semantics of Begin/Next/Prev/Present/End, please refer to Animation Editor. Additional methods can be added by using the Custom Model button. When the AutoBegin property is true, the State Machine will jump to the Begin state when the scene is being opened.
