Math Effects
Linear This node interpolates linearly between a start and target value.
Decay This node interpolates linearly between a start and target value. In contrast to Linear the gradients for increase and decrease can be set individually.
Damper This node interpolates between a start and target value with ease-in and ease-out.
Oscillator This node oscillates around a target value, beginning at a start value.
Clipping This node clips and maps a range of values to another value range.
Delay This node transfers values from input to output with a customizable delay.
Linear
Interpolates linearly between the current value of the Value output property and the value of the Target input property. The interpolation is automatically started when the Target value changes and finishes after the amount of seconds specified in Duration. Once the interpolation is completed, the Reached event is fired.
By checking the UseTarget2 property, the interpolation will use the value of Target2 instead of Target as the interpolation goal.
Decay
Damper
Oscilator
The Damper node is similar to the Linear Node in that it performs an interpolation between the current output value and the target value. It uses a spring-mass type equation to guide the interpolation. The interpolated value will close in on the target value, overshoot it, reverse velocity, overshoot it, while at the same time slowing down until the target is reached.
Delay
Clipping
