Matrix
Rotation XYZ This node provides a matrix to rotate around the X, Y or Z axis.
Scaling This node provides a matrix to scale along the X, Y and Z axis.
Translation This node provides a matrix to translate along the X, Y and Z axis.
The Matrix Nodes provide special types of matrices that can be used as Input Properties for the World Transformation, View and Projection Nodes.
