Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Animation Controls
Simple Control This node translates the complete animation between the very first and the last keyframe in a timeline to a progress value ranging from 0% to 100%
