Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Rectangle Geometries
Rectangle
Normalization
Rounded Rectangle
Texturing
  • Flat: Zero to one flat mapping over the whole area of the rectangle.
  • Wrap: The texture coordinates flow around the border. This is great to add a spot light effect and have it animate around an object.
  • Stretch2x2: Imagine the texture to be split into 4 quadrants. Each quadrant is used for the respective corner and the pixel exactly on the border are stretched to fill the straights between the corners.
  • Stretch4x4: Similar to Stretch2x2 but assumes the texture is split into 16 quadrants. The corners are used to texture the corner areas of the Rounded Rectangle and the 2 quadrants between any two corners are used to texture the straight between the same corners on the Rounded Rectangle.
Gradient Rectangle
  • Nodes and Bindings
