Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
SVG Loader
SVG Loader Rasterizes Scalable Vector Graphics coming in as File or XML Text.
The SVG Loader Node is able to create a Texture in the respective dimension based on an SVG File or XML Text.
Usage
Example:
      <g id="g14">
        <g id="g16">
        </g>
      </g>
    </g>
  </g>
</svg>
Output:
Limitations
  • Material Node
  • SVG Layer
  • ​https://en.wikipedia.org/wiki/Scalable_Vector_Graphics
