Alpha Blending
Alpha Blending This node modifies the blending rules for superposed pixels.
When a fragment has passed all tests (see Z-Testing Node, Alpha Testing Node, Stencil Nodes), its color is applied to the render output and overwrites any value previous set by other objects. With alpha blending, the final pixel color can be a combination of both the fragment (source) pixel color and alpha as well as the pixel color and alpha in the render output (destination).
There are no predefined blending modes like "Overlay" or "Screen". Instead Ventuz directly offers the capability of the graphics card for greater flexibility. Both the source and destination color are treated as a 4-dimensional vector (red, green, blue, alpha) which is multiplied with a blend factor before applying the chosen operation.
color = (source_color * source_factor) op (destination_color * destination_factor)
