Nodes and Bindings
Nodes are the fundamental elements from which a Ventuz Scene is constructed. Each node is either a Content or Hierarchy node and thus belongs either in the Content Editor or Hierarchy Editor. This is visualized by the orientation of the brackets around the node icon.
A hierarchy node has vertical brackets, a content node horizontal brackets around the node icon.
A content node describes an asset (i.e. a texture, an XML file, ...), a numeric constant, an event or any other item that does not directly influence the rendering process. In contrast, a hierarchy node is like an instruction to the Ventuz Rendering Engine, for example to activate a certain material or texture, to render a mesh and so forth.
All nodes can be browsed via one of the Toolboxes. These can be accessed either through the toolbox window (accessible via View/Toolbox in the menu bar) or by clicking into the Hierarchy Editor or Content Editor and then pressing Space key to open the Fast Toolbox.
Properties and Bindings
Bindings are visualized as arrows which connect nodes in the Content Editor. To create a binding, select a node, go to the Properties Editor and drag the input property onto another node. When released, Ventuz will open up a list of compatible output properties of that second node. Upon choosing one of the properties, a connection is created and visualized by an arrow going from the output node to the input node. For more information, see Property Editor.
Validation and Rendering
