Template Engine
Auto-routing between states
Templates
A Template is an entity that describes both a logical and visual part that can be activated in conjunction with its corresponding data population. Every scene automatically defines a Scene Template, which represents the scene without any dynamic data defined for it. All other templates in the scene are defined by Present States of an animation logic and are usually associated with some amount of dynamic data. All Templates defined by a scene are organized in a hierarchical order that also declares their relationship between each other (Concurrency, Dependency, Independency).
Templates are always organized in so called Template Hosts. Template hosts are organized in a host-tree where each host has exactly one parent host (except the root) and has one or multiple sub-hosts.
Relationships
Template Hosts
Project Templates
If the template engine is used Scene-comprehensively, it defines the root of the host-tree. For every scene that is injected into the project template host one Template is defined. So all scenes managed by this host are concurrent: there's none or one scene active at a time.
Scene Templates
Animation Templates
Animation Groups
DataModel
Animation1
Group2_Animation2
Group2_Animation3
DataItems
Name C# Type Modes Description Attributes
Animation - - The Animation item defines a field that addresses a possible sub-template. The actual value of this field is null or a data instance (TemplateData) of a sub-template. Required
Trigger - RW A Trigger can be either an asynchronous event sent out to the remote client (R), a trigger sent from the remote client to Ventuz (W) or both (RW).
Group - (RW) A Group contains multiple sub-DataItems and acts like a folder. The mode is the sum of all sub-items only defines if the items below are readable and/or writable. The group itself has no value.
Float float RW A floating point value Default, Min, Max, Speed
Integer int RW An integer value Default, Min, Max, Speed
Boolean bool RW A boolean value Default
String string RW A string value Default, MaxLines, MinLines
Enum string RW A string value of type that matches the values of an enumeration. The possible values are define in the field Elements. Default, Elements
Color Color RW A color value Default, Alpha
Asset Uri RW A general Uri value that addresses one or multiple asset pools AssetPools
FloatArray float[] RW An array of float values Default, MinLength, MaxLength
IntegerArray float[] RW An array of integer values Default, MinLength, MaxLength
BooleanArray bool[] RW An array of boolean values Default, MinLength, MaxLength
ByteArray byte[] RW An array of byte values Default, MinLength, MaxLength
StringArray string[] RW An array of string values Default, MinLength, MaxLength
Attributes of DataItems
Name C# Type Description
Name string Defines the technical name of the DataItem
Label string Contains the label text how the DataItem should be presented to the user.
Description string Contains a short description of the DataItem
Required bool Defines if a sub-template must be assigned (true) or not (false)
Default item type Default value of the DataItem
Min/Max item type Minimum and maximum value of the DataItem
Speed item type Edit speed of the DataItem
Min/MaxLines uint Minimum and maximum number of text lines for the DataItem
Elements string[] List of valid elements to fill the DataItem
Alpha bool True if the color requires the alpha component
AssetPools AssetPool Asset pools of the DataItem
Min/MaxLength uint Minimum and maximum number of elements in the array
UserData string A user-defined general purpose string.
Addressing Templates
Examples:
.Text1
Animation1/Template1.Line1.Text
Animation1/Template1.Line1.Color
Animation1/Animation2/$Group2.Headline.Text
Data Formats
In order to store and transfer a complete set of data, we plan to integrate multiple different data formats for being compatible to different platforms and integrators:
Ventuz 4 supports three different data formats: XML, JSON and BIN. all of these formats are 100% compatible to each other and the user can decide which format he wants to use. All three formats are text based and the receiver (Ventuz) can easily decide which parser to user. It simply looks to the first non-whitespace character: "<" for XML, "{" for JSON and any other for base64-BIN
The JavaScript Object Notation (JSON.org) has some advantages and disadvantages compared to XML:
XML
<VTD ns="ventuz://templates/ingame/Scene">
  <LowerThird_Center ns="ventuz://templates/ingame/LowerThird_Center/NS2LAdd">
    <FirstLine>First Line</FirstLine>
    <FirstAdd>Addon Text</FirstAdd>
    <SecondLine>Second Line</SecondLine>
    <Visual01>ventuz://scenes/Assets/logos/FrankfurtSnakes.vzs</Visual01>
    <Visual02>ventuz://images/Assets/sponsorlogos/HH.png</Visual02>
  </LowerThird_Center>
  <UpperThird ns="ventuz://templates/ingame/UpperThird/Scoreboard">
    <Banner ns="ventuz://templates/ingame/UpperThird/Scoreboard_Banner/Banner2LAdd">
      <FistLine>First Line</FistLine>
      <Visual>ventuz://scenes/Assets/logos/HP.vzs</Visual>
    </Banner>
  </UpperThird>
</VTD>
JSON
	"@": "ventuz://templates/ingame/Scene",
	"LowerThird_Center": {
		"@": "ventuz://templates/ingame/LowerThird_Center/NS2LAdd",
		"FirstLine": "First Line",
		"FirstAdd": "Addon Text",
		"SecondLine": "Second Line",
		"Visual01": "ventuz://scenes/Assets/logos/FrankfurtSnakes.vzs",
		"Visual02": "ventuz://images/Assets/sponsorlogos/HH.png"
	"UpperThird": {
		"@": "ventuz://templates/ingame/UpperThird/Scoreboard",
		"Banner": {
			"@": "ventuz://templates/ingame/UpperThird/Scoreboard_Banner/Banner2LAdd",
			"FistLine": "First Line",
			"Visual": "ventuz://scenes/Assets/logos/HP.vzs"
BIN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