Stage Editor
  2. Render Setup Selection and Editing
  3. Preview Selection Menu
    1. Physical
    2. Design Preview
    3. Disable Preview
    4. Options
  4. Machine ID Selection
  5. Design Preview
  6. All Outputs
  7. Connector Selection
When working with a Previs scene the Composition preview may show content with a strange aspect ratio; this is not a bug but rather a technical limitation. This is due to the Render Order, at the point of previewing the Composition the engine doesn't know the design size set by the canvas. It will fall back to the Aspect Ratio set in the Project Properties window.
Physical
This previews the physical device output. Depending on the setting Enable All Outputs, it behaves differently.
Enable All Outputs Behavior
On Previews the output of the device as configured in the Device Configuration.
Off Previews DUMMY Outputs as configured in the Render Setup output mapping tab.
Inputs can be previewed if configured inside your Device Configuration.
Design Preview
Disable Preview
Options
Enable All Outputs: Will use all physical screens currently configured as outputs inside your Device Configuration and render your scene on it, except the screen with Designer open. When disabled, the Preview Renderer will render the Physical Outputs as configured in the active Render Setup, instead of the Device Configuration.
Preview at System SDR Level: When HDR mode on: Sets the SDR white-level of the preview renderer to the Windows SDR level of the Windows Display Settings.
Design Preview
All Outputs
Configuration of both Inputs and Outputs can be done inside the Device Configuration.
Connector Selection
  • Previs Screens
  • Screens
  • Compositions
  • Canvases
