Content Editor
Description
A Comparison
Two nodes are connected by a line if at least one property of one is bound to a property of the other. The binding relationship can be bidirectional in which case both ends of the line have an arrow head. To remove a binding, click on the line and a list of all bound properties opens. By selecting one of the entries, the respective binding will be removed. To remove all bindings of a node, select the node and press SHIFT + DEL or select Unbind from the Edit Menu.
Sometimes you want to add a node in between an existing connection between two nodes. To do so you can just grab a node from the Toolbox and drop it on a Binding if there is only one connection that fit the value type the node is inserted otherwise you get a list of available possibilities.
Copy
Content Nodes can be copied by simple CTRL + C, CTRL + V. To copy a single content node without the bound content select the node with CTRL. CTRL + P will duplicate the node and place the copy next to the original one. CTRL + SHIFT + P duplicates the node and creates binding to the existing source nodes.
Zoom
Since the number of content nodes in a scene can get quite large, the Content Editor only visualizes a part of the network. By moving the mouse wheel, the user can zoom in or out of the network. Pan the Content Editor by pressing .
The position of the individual nodes can be arranged by the user by clicking  and dragging nodes. Each node can be assigned a name by double-clicking on the node name or pressing F2. As with the Hierarchy Editor, parts of the network can be collapsed by clicking  on a node. To reach the Context menu, press and hold  for a few seconds.
Nodes displayed in the Content Editor can be grouped into Content Families to assure the relative positioning of the nodes in such a Family and to visualize a functional relationship. Select some nodes with the rectangular selection or by clicking on nodes with a pressed SHIFT. Pressing CTRL + SHIFT + F will create a Content Family for the nodes and visualize this with a gray rectangle around them in the Content Editor.
Content nodes can be drawn in a Small version to save space in the Content Editor. Just press CTRL + T to toggle the size of a Content node.
  • Shortcuts: Content Editor
  • Nodes and Bindings
  • Containers and Interfaces
