How To create DDS textures up to DX Level 11
  2. Intel Texture Works
  3. DDS View
  4. Conclusion
With this How To we will show how to create and use the latest versions of DDS (Direct Draw Surface) Textures with Ventuz. DDS Textures can be used in order to save performance and VRAM as they can be written to the graphics card memory directly and in compressed state.
From now on we support way more so called Block Compression modes (BCn). The old term DXTn is now replaced by BCn where “n” is the Level.
You can use a DDS Texture in Ventuz like you can use any other image file format.
With the change and update to DirectX 11 for our graphics engine and the support of the latest BC modes we are able to use all currently available compression modes. Please see the following table for reference:
Source data Minimum required data compression resolution Recommended format Minimum supported feature level D3D 9 equivalent
Three-channel color with alpha channel Three color channels (5 bits:6 bits:5 bits), with 0 or 1 bit(s) of alpha BC1 Direct3D 9.1 DXT1
Three-channel color with alpha channel Three color channels (5 bits:6 bits:5 bits), with 4 bits of alpha BC2 Direct3D 9.1 DXT2,DXT3
Three-channel color with alpha channel Three color channels (5 bits:6 bits:5 bits) with 8 bits of alpha BC3 Direct3D 9.1 DXT4, DXT5
One-channel color One color channel (8 bits) BC4 Direct3D 10 ATI1
Two-channel color Two color channels (8 bits:8 bits) BC5 Direct3D 10 ATI2
Three-channel high dynamic range (HDR) color Three color channels (16 bits:16 bits:16 bits) in “half” floating-point* BC6H Direct3D 11 N/A
Three-channel color, alpha channel optional Three color channels (4 to 7 bits per channel) with 0 to 8 bits of alpha BC7 Direct3D 11 N/A
*”Half” floating-point is a 16 bit value that consists of an optional sign bit, a 5 bit biased exponent, and a 10 or 11 bit mantissa.
Most of these formats allow either Linear and/or sRGB. The BC4 is meant to be used for grayscale images like a heightmap, roughness or ambient occlusion textures. If you want to achieve the highest quality and most lossless texture you should go for BC7 Fine.
To export DDS files with the latest support of BC Levels, we suggest the Intel Texture Works Plugins for Photoshop, which can be found ​here
Intel Texture Works
After installing the Intel Texture Works Plugin, you can create or convert your textures by choosing the Intel Texture Works DDS Type from the Save as type dropdown:
By choosing a filename and clicking the save dialog, another dialog will pop up and ask you for the Texture Type and Compression. See available types and formats;
You can go for any of the available types and compressions. The decision should be made according to the usage of the texture. A simple heightmap should not be saved with BC7 since you will mostly use a grayscale image only. In this case a BC4 linear grayscale would be the perfect match.
On the ​''Intel Texture Works Plugin'' homepage is a very good table with hints about each type of BC and their usage :
BC1 RGB 4BPP aka DXT1 Useful for color maps or normal maps if memory is tight. Contains RGB types of data
BC1 sRGB 4BPP aka DXT1 Same as above with sRGB extended header only on DX10 + level hardware
BC3 RGBA 8BPP aka DXT5 Useful for color maps with full alpha, packing color and mono maps together. Contains RGBA types of data.
BC3 sRGBA 8BPP aka DXT5 Same as above with sRGB extended header only on DX10 + level hardware
BC4 R 4BPP Grayscale Useful for height maps, gloss maps, font atlases or any other grayscale image
BC5 RG 8BPP aka 3Dc Useful for tangent space normal maps. A two Channel Tangent Map
BC6H RGB 8BPP Fast Compression Useful for HDR 16 images only on DX11+ level hardware
BC6H RGB 8BPP Fine Compression Same as above with longer optimized compression time for a finer result
BC7 RGBA 8BPP Fast Compression Useful for high quality color maps, color maps with full alpha. It provides the best quality compression only on DX11+ level hardware
BC7 RGBA 8BPP Fine Compression Same as above with longer optimized compression time for a finer result
BC7 sRGBA 8BPP Fast Compression Same as BC7 Fast above with sRGB extended header only on DX10 + level hardware
BC7 sRGBA 8BPP Fine Compression Same as BC7 Fine above with sRGB extended header only on DX10 + level hardware
None RGBA 32BPP Uncompressed
For cubemaps, the texture size need to be a power of two. Else writing the texture is not possible without an error and the image can not be loaded correctly.
DDS View
To check if the textures are written correctly and/or valid, you can use the DDS View. A precompiled version of the DDSView is available ​here. The source code can be found ​here. The tool requires the ​Visual Studio 2015 Redistributables. Drag & drop any DDS File onto the DDSView.exe. As long as it is a valid and working DDS File it will show it.
Conclusion
In this How To we have given you an overview of the creation and usage of DXT compressed textures and the use cases of each compression type. The user can use the information to implement a workflow that allows for better performance than simple PNG or JPG encoded pictures.
  • ​https://github.com/Microsoft/DirectXTex
  • ​https://software.intel.com/en-us/articles/intel-texture-works-plugin
  • ​https://docs.microsoft.com/en-us/windows/desktop/direct3ddds/dx-graphics-dds
