Ventuz 6 Quick Guide
  • Ventuz 5 Migration Guide
Ventuz 6 Designer
Ventuz 6 Node Reference
Ventuz 6 Configuration Editor
Ventuz 6 Director
Substance Material
  1. General
  2. Properties
  3. Resulting Substance Material Node
Substance Material Loads Substance Designer Materials in .sbsar format.
The Substance Material node can load so called Substances as a *.sbsar file which are created with the ​Substance Designer from Allegorithmic. The Substances have exposed properties which are accessible in Ventuz. With these exposed parameters you can change the appearance of the generated Texture(s) to give them a different look and feel. The accessible input parameters change for each individual Substance and the same goes for the Texture Outputs. Ventuz and the Substance Engine will automatically map and bind the generated Texture inside of the Material Node so that the Substance Material node can be used right away. The rest of the properties and handling of the node is similar to the Material node, like the Texture Stages.
Properties
The Output Properties also vary depending on the loaded Substance. Usally you will find textures here which are already bound to the Material Stages - Texture Properties. In most cases the Outputs Texture Properties will give you a hint where to connect the texture to by reading a naming like BaseColor, NormalMap, Roughness and so on.
As soon as Ventuz did load a Substance and the Substance Engine has generated all the textures, the textures will be compacted. In the following example the Metallic-, Roughness- and AmbientOcclusionMap are "compacted" into one internal single Texture Stage since these textures contain greyscale informations anyway. You still have access to all single textures by using each single R,G,B or A channel.
  • ​Substance Designer and Painter
  • Substance Loader node
  • Material node
  • Light nodes
  • How to use Substance Integration
