Cylinder
Cylinder This node provides a cylinder (and tube) geometry.
This is a Geometry Renderer which has a Property Group to switch between different kinds of Geometries. It is also possible to extract the Property Group and make use of it inside the Content Editor. The Cylinder provides a Geometry with adjustable dimensions and, optionally, a hole if the Hole property is set to a non-zero value. The cylinder will be provided for the Geometry Renderer. By decreasing the Angle property, partial cylinders or pie wedges can be created.
  • Nodes and Bindings
