Layer 3D
  1. 3D Layers
  2. Blending
    1. Mode
    2. Opacity
    3. Blocked
    4. BlockedOnFullTransparency
    5. Layer Mask
      1. Mask
      2. Texture Loader
      3. Loader
      4. IPP
      5. Lighting and Shaders
        1. Lighting
        2. Shaders
      6. Texture Property
      7. 1D Gradient
      8. SVG Loader and SVG Text
      9. Other
      10. Texture Array Loaders
        1. Flipbook Loader
        2. Strip Loader
      11. Flipbook
      12. QR Code Generator
        1. Mask Properties
      13. Mask Vignette
      14. Mask Border
  3. Layout
  4. Effects
    1. Blending
    2. Mask
  5. Mask Self
    1. Effect
    2. Effect Group
    3. Color Correction
    4. Filters
    5. Distortion
  6. Layer
  1. 3D Property
    1. Camera
  • 3D Layer Root Node
      1. Ambient Occlusion (SSAO)
      2. Depth Of Field
      3. Bloom
      4. Imagebased Lens Flare
      5. Anti Aliasing
      6. Depth Keyer
    1. 3D Property
    2. HDR specific properties
  • 3D StandardThis is a standard 3D Layer
    3D HDR This is a Layer using the High Dynamic Range engine mode
    3D Layers
    Ventuz 3D layers have 3 different render engines or modes:
    • Legacy: This engine mode essentially emulates the Ventuz 4 engine within the current engine, to provide backwards compatibility with scenes created in Legacy versions of Ventuz. Previous versions of Ventuz render engine have used a fixed function based vertex-based lighting model. They also had different ways of accessing the 3D world, cameras and materials.
    • Standard: This is the default render mode used in Ventuz 5 and, as you can see, it is not using vertex-based lighting and therefore is more similar to industry standard 3D applications using other lighting techniques. As with legacy mode, the properties change to match the available features of this render/lighting mode.
    • Standard with legacy Lighting: This mode is halfway between the legacy and standard modes. It allows the use of some of the new effects, materials and possibilities of the engine, while retaining the lighting model from Ventuz 4 and earlier.
    • HDR: This can be considered an advanced version of the Standard mode, which uses High Dynamic Range (HDR) computing. This mode calculates at more than 8/10 bits of information per color channel to render the final results. This requires more computing power, but it provides the means to create much more powerful and higher quality effects. As you can imagine, there must be a compromise between performance and quality, meaning that you should only use the HDR engine where it actually provides a benefit.
    Blending
    Blending
    Mode
    Opacity
    Blocked
    Layer Mask
    Mask
    Texture Source
    Texture Loader
    Texture Loader Presets
    Loader
    Image/Texture
    Description
    Internal resource name
    Image/Texture
    Description
    Shape Circle
    Shape Triangle
    Shape Pentagon
    Shape Cross
    Spike Star
    Checker
    internal://images/checker.png
    Checker Blue
    Checker Dots
    internal://images/dots.png
    Lines
    internal://images/lines.png
    Noise
    internal://images/noise.png
    Alpha Glow Full
    Alpha Glow Half-Full
    Alpha Glow
    Alpha Glow Half-Sharp
    Alpha Glow Sharp
    Dimple
    internal://images/dimple.png
    Pimple
    internal://images/pimple.png
    Liquid
    internal://images/liquid.png
    Woodchip
    IPP
    Image/Texture
    Description
    Image/Texture
    Description
    Lensflare Ghost Colors
    Lensflare Star
    Lensflare Dirt
    Lighting
    Image/Texture
    Description
    Image/Texture
    Description
    Incidence 1D Lambert
    Incidence 1D Rainbow
    Incidence 1D Specular
    Incidence 2D Smooth
    Incidence 2D Steps
    Incidence Diffuse
    Incidence Diffuse Anisotropy
    Incidence Specular
    Incidence Blue Back
    Celshading Steps
    Shaders
    Image/Texture
    Description
    Image/Texture
    Description
    Hatch Lines
    Hatch Curves
    Hatch Letters
    Texture Property
    1D Gradient
    Gradient Presets
    SVG Loader Presets
    Other
    Image/Texture
    Description
    Ventuz Logo SVG
    internal://images/ventuz.svg
    Flipbook Loader
    Strip Loader
    Gradient Presets
    Flipbook
    Image/Texture
    Description
    Flipbook Clock
    QR Code Generator
    ECC Level
    • Level L ~7%
    • Level M ~15%
    • Level Q ~25%
    • Level H ~30%
    Mask Properties
    Mask Vignette
    Mask Border
    Layout
    Effects
    Blending
    Mask
    Mask Self
    Effect
    Effect Group
    Color Correction
    Filters
    Distortion
    Layer
    3D Property
    Camera
    3D Layer Root Node
    • Camera: A drop-down menu used to select the camera that would be used in that 3D Layer. One powerful feature of Ventuz is that cameras can be shared between 3D layers, allowing an effective combination of 3D compositing and 2D post-processing in the same environment. There are two types of camera options available, with these particular parameters:
      • Normal: assigns a separate camera per 3D Layer, the default option that appears on the drop-down menu. Below is the default camera, you can find the rest of the 3D cameras available in the scene - 3D cameras are named accordingly to the 3D Layer they belong to, but can be renamed more usefully instead.
      • A/B: This option allows selecting two cameras and blending camera position between them, it is mostly used to make 3D camera transitions between two existing 3D cameras. These properties are available:
        • Camera A: A drop-down menu used to select the first 3D camera for the camera transition, initially uses the default camera.
        • Camera B: A drop-down menu used to select the second 3D camera for the camera transition, initially uses the default camera.
        • Amount: controls the blending between the camera positions. It expresses blending as a percentage and the default value is 0%, meaning that the result is Camera A position, while 100% means that the result is Camera B position - intermediate values interpolate between those two values.
    • Engine: A drop-down menu used to select the render engine/mode used in this 3D Layer - the selected Render Engine appears in gray close to the engine drop-down menu. The default value is Standard mode. If you want to use HDR select High Dynamic Range.
    • Amount: How much of the ambient occlusion is applied. You can go over 100% to exaggerate the effect.
    • Tint: Allows you to change the color of the applied ambient occlusion.
    • Show: Tuning SSAO can be tricky, and this option allows to look at various stages of the effect.
      • Result shows the final effect, Ambient Occlusion shows the ambient occlusion map that is the result of the averaging explained above. Depth shows the depth buffer, Normals shows the normals of the objects rendered, Camera Space Position shows the 3d position of the objects rendered, from the camera point of view.
    • Filter Diameter: SSAO can be noisy, a little bit of filtering gets rid of this at the cost of making things more blurry.
    • Flags, 32-bit depth: To speed up the shader, the depth buffer is truncated and converted into a 16-bit depth buffer. When using a large MaxDepth, switching to full 32-bit depth buffer can increase quality.
    • Flags, half resolution: Half resolution is four times faster but more blurry.
      • Flags, dither: Without dithering and a low number of rays, the direction of the rays become visible as streaks in the AO. Dithering will randomly rotate the rays (in 2D), masking the streak effect but adding noise. The noise can be filtered with Filter Diameter.
    • Radius: Radius in 3D-units for how long the rays are cast. Walls as described above will only be found within this radius.
    • MaxDepth: fade out the ambient occlusion behind this depth. Too large a depth will limit precision.
    • Bias: Even on a plane surface, rounding errors might see occluding pixels where they are not. The bias will blend out small surface irregularities. The value given is the cosine of the threshold angle.
    • BiasMinRadius: during refinement, points very near to the center are sampled, which adds inaccuracy. This is a special threshold that is increased towards the center.
    • Samples: Number of rays cast.
    • Steps: Divides each ray in equal-sized steps, within the Radius.
    • Refine: After hitting a wall, do this many binary subdivision steps to refine the result.
    Depth Of Field
    This enables the Depth of Field effect, an effect that is often used in filmmaking and uses the blurriness of the out of focus elements in the scene to drive viewer's attention to certain parts of the image. The options are None, Fast Depth of Field and Quality Depth of Field - the latter is available in two versions, one with simple settings and one with advanced settings similar to the Fast Depth of Field. Simple Depth of Field is a relatively fast method of calculating DoF, but it comes with a drawback: The quality is very much dependent on proper settings. At this point in time, it mostly is used in small amounts to add realism to 3D scenes. The Quality Depth of Field uses up more perfomance but is easier to control, especially the non-advanced version of it.
    Common Properties:
    This lists all properties that are present on all types of Depth of Field shaders:
    • Show Focus Plane visualizes the currently used Focus Distance. You can also adjust its Focus Plane Alpha.
    • Focus Distance: This sets the distance to the focus point. Notice how the Focus gets pushed further away from the point of view with higher input.
    • Quality: Changes the render Quality of the Depth of Field effect. This is helpful if e.g.: the edges of an object have artifacts caused by low quality. Generally speaking, such effects are mostly pretty ressource hungry. For a better overall performance this should be set to the lowest value with acceptable results.
    Instead of an enumeration you can control the Sampling Quality of the Quality Depth of Field using a floating point number between 0 and 1. The effect of the property stays the same.
    Quality DoF:
    This lists all properties on the simple Quality Depth of Field:
    • Aperture: The aperture that is used to calculate the behavior of the Depth of Field. This parameter reflects the physical Aperture of a Camera. As such it controls the Near and Far Blur intensity as well as the fading from sharp portions of the screen to blurred ones.
    • Max Kernel Size: This artificially limits the size of resulting bokeh effects to improve performance - otherwise it would harshly drop the framerate and consume GPU power.
    Fast and Quality Advanced DoF:
    Following is a list of the common properties of Fast Depth of Field and Quality Depth of Field Advanced:
    • Amount: Controls the overall strengh of the depth of field effect.
    • Alpha: With this option you can control if the Layer with the Depth of Field effect will have an Alpha applied. This enables blending with a layer beneath it. Again, producing an alpha channel will use up more performance.
    • Focus Range: Determines the range around the focus point that is in focus. Also introduces a soft transition to the blurrier portions of the scene.
    • Far Range: Provides the option to get more of your scene into focus. But with this option the nearest blur line stays where it is and only the furthest point of the effect gets moved.
    • Near and Far Blur: This changes the Strength of the Near or Far blur.
    Bloom
    • Show: A drop-down menu to select the effect output, the options are Result (the Bloom effect composited over the original scene), Mask (a mask showing the lighter areas that will be affected by the Bloom effect) and Blurred Mask (a blurred that shows the effect areas alone, that is, the Bloom result without being composed over the original image)
    • Monochrome: A checkbox that activates or deactivates the Bloomed areas color. When checked ON, the areas are monochrome, using just one color, as set in next parameters. When switched OFF (default), texture color values are taken into account to colorize the bloomed areas.
    • Threshold: One slider to control the range of colors to be affected by the bloom effect. Values are decimals ranging from 0 (affect more colors) to 1 (take a smaller range of color values to calculate the Bloom effect) - you can check easily how Threshold works if you select the Blurred Mask value in the Sow parameter above. The default value is 0.5.
    • Tint: A drop-down menu that opens a Color Picker to select the color to be used for tinting the Bloomed areas of the scene. The default color is White.
    • Amount: One slider to control the strength of the Bloom effect, it effectively dims out the Bloom effect. Values are expressed as a percentage and the default 100% value fully applies the effect as set by the rest of parameters.
    • Diameter: One slider used to set the diameter of the blurriness between the
    • DiameterUnit: A drop-down menu to set the units used to calculate the parameter value above. The available options are InPercent (default, calculates the Diameter as a percentage of total image resolution) or InPixels (calculates the Diameter as pixel values).
    • Aspect: One slider to change the Aspect ratio of the Bloom effect, which works equally in X and Y axis with the default value of 0. Positive values stretch the Bloom effect horizontally, in the X axis, while negative values stretch it vertically, in the Y axis.
    • Gain: One slider to apply a Gain color correction on the bloomed areas of the scene. The default value is 0 and higher values over-burn the bloomed areas, making it look whiter and brighter.
    • DownsamplingQuality: This is, just like the blur effects, a simple quality/speed tradeoff. The higher the slider, the better the quality, the lower it is, the better the performance. Try to set it to as low as possible while maintaining an acceptable quality.
    • Amount: How much of the ImageBasedLensflare is applied. You can go over 100% to exaggerate the effect.
    • Debug: A drop-down menu to switch between different debug modes. Off shows the result. Mask visualizes that will be used to create the ImageBasedLensflares. This mode is used to adjust the Threshold and clip the not so bright areas. Vignette is the same as Mask with the addition of the vignette.
    • Downsample actual downsampling of the rendertarget used to create the Lensflare. You can increase the quality by using a lower sampling value (x2) or by turning it off
    • Blur: Blurs the result of the Lensflare.
    • Threshold: Clips the lower intense image color informations. The lower the Threshold, the more colorinformations of the image will be used to create the Lensflare. Higher values will therefore use only the brightest colorinformations.
    • ChromaDistortion: shifts and seperates the RGB channels visually. See ​Chromatic aberration
    • VignetteDiameter: sets the diameter of the vignette to fade out the Lensflare. This value can be greater than 100%.
    • VignetteFalloff: Set the falloff of the vignette.
    • VignetteBorder: Set the border amount of the vignette in percentage.
    • GhostAmount: The intensity of the Ghostflares.
    • GhostCount: The numbers of Ghostflares that will appear.
    • GhostDispersal: The distance between the screencenter and the Ghostflares.
    • GhostColors: Load a ghostcolor texture here OR use a gradient.
      • HaloAmount: The amount of the GhostColors.
      • HaloSize: Set the size of the HaloRings and the GhostFlares.
    • StarTexture: Load a startexture here. This is the texture which is usally a streaks/star texture.
      • StarAmount: The intensity of the StarTexture.
      • StarSize: adjust the size of the StarTexture. This value can be bigger than 100%.
      • StarRotation: Rotates the StarTexture. Can be bound to the camera rotation for example.
    • DirtTexture: Load a DirtTexture here. This texture makes your Cameralens dirty.
      • Amount: Set the intensity of your DirtTexture here.
    Anti Aliasing
    The term generally refers to the process of removing jagged edges of objects. They may appear because of the limited raster of pixels on the render output. There are several techniques to reduce the aliasing, like ​Multi Sampling or ​Fast Approximate Anti Aliasing. For more information see the different sampling methods we support in Ventuz that are explained in detail here.
    On the 3D Layer Root, you can change the Anti-Aliasing either to use the configured options or to use a dedicated sampling method.
    The MSAA (Multi Sampling Anti Aliasing) method has an option FixSeams to smooth alpha edges if they seem jagged even with Anti Aliasing turned on in non-HDR layers. More information can be found on the Anti Aliasing reference page. Consider using the FXAA on the respective layer instead of MSAA with fixed seams since this will save performance.
    Depth Keyer
    The Depth Keyer can be used to key out certain portions of the rendering of the 3D Layer based on the the depth. This is useful if you need to feed in any kind of image that has no alpha yet you need to composite it in your scene. An example for such images is the texture coming from the Unreal Live Link.
    The Depth defines the threshold of this keyer: everything behind this threshold is keyed out, while everything in front is left in the rendering as it is. When Apply to Fill is disabled the keyer applies to the layer's alpha channel only and leaves its color channels as they are. This is useful for Augmented Reality setups with any sorts of external chroma keying. Show offers debug visuals to get an idea of what is happening inside the shader. You can see the resulting Key as well as the scene's depth. Softness, Choke and Edge Softness work in the same way as the according properties on the Color Difference Keyer Layer Effect. When Enable Anti Alias is turned on, the effect will have aliased edges to smooth out the Alpha. With this disabled, the resulting key is either 0 or 1 - an FXAA algorithm is used to fade this smoothly when its enabled. The Fxaa Sub Pixel property changes this algorithm's parameter as described in the Anti Aliasing reference page.
    3D Property
    • DefaultCamera: with this drop-down menu you can set the Projection to Perspective or Orthogonal. You can also set the XY Relation which will affect Destination Coordinate System to which to render: You may get it from the Layer Layout Properties, from the Project settings or the Device which is in this case the Renderer Window. The Relation Area defines the Source Area in which you define your 3D Elements.
    • DefaultLight: This determines default lighting should be used and the position. You can select None which is common if you use Image Based Lighting, Inclined which sets the default light over the shoulder and straight which sets the light facing straight from the camera to the center.
    With the Engine drop-down menu you can switch to High Dynamic Range. If you are working with the HDR Engine the 3D Layer Root will show different properties than for the Standard Engine. The Engine will then switch internally into a 16bit floating point precision which makes it possible to make proper use of real HDRi's (High Dynamic Range images).
    You will mostly notice an advantage working in HDR when using real HDRi's or especially when working with the IPP-Effects like Bloom and Image based Lensflares. These Effects will then work properly since real bright pixels are available for sampling and applying the named effects.
    Unfold or Right Click the Engine property to show HDR specific properties. You can adjust the Exposure level then, which is basically the same like with a real photo camera. High Exposure (plus values) settings will let more light into the camera lens and the scene looks brighter. Low Exposure (minus values) will let less light travel trough the camera lens, the scene will be darkened. Since we are working in 16f it is now possible to reduce the color banding by enabling the Dither. FrustumCulling works the same way as in the Standard Engine mode.
    Another Property group called ToneMapping is now available. In the drop-down menu you can switch between Reinhard, Linear and Filmic tonemapping. The default Reinhard tone mapping lets you adjust the Whitepoint which sets the luminance level to use as the upper end of a tone mapping curve. The Whitepoint is mostly adjusted by artists to create a more colorful result. Linear and Filmic have no properties to change since they are based on fixed internal formulas, except for the PreserverAlpha. Linear renders really linear colors from 0 to infinity, while our monitor use colors at gamma around 2.2 from 0 to 1. When using the Filmic tone mapping, it happens that in the real world the Film itself is not capable of capturing the whole intensities, it uses a characteristic curve, it does not capture the intensities linearly. Film tone mapping, therefore, is an artistic tone mapper which emulates the natural film. There is a real advantage when using the Filmic Curve: You have Crisp blacks, a saturated dark end and nice highlights.
    • ​Chromatic aberration
    • Layers IPP Color Corrections
    • Layers IPP Filter
