Ventuz 6 Quick Guide
  • Ventuz 5 Migration Guide
Ventuz 6 Designer
Ventuz 6 Node Reference
Ventuz 6 Configuration Editor
Ventuz 6 Director
Value Switches
Multi Switch This node processes multiple inputs and passes the result to the output. One can handle multiple input groups with a single index.
Value Switch
Multi Switch
Single, Double, Integer, Boolean, String, Event, Texture.
All types
Last Changed
The output value is always the last changed value of the input group.
Integer/Float/Double
Sum
The sum of all input Values.
Min/Max
The minimum/maximum input value.
Average
The average value of all input values.
For integers one can define whether to round (Average) or always choose the next lower (AverageFloor) or next higher (AverageCeiling) integer.
Boolean
AllOn/AllOff
Output is true if all input booleans are true/false.
AnyOn/AnyOff
Output is true if at least one input boolean is true/false.
SingleOn/SingleOff
Output is true if exactly one input boolean is true/false.
String
Concat
The concatenation of all input strings.
Longest/Shortest
The shortest/longest string.
FirstNonEmpty
The first string by index that is not empty. With FirstNonEmptyTrimmed all leading and trailing whitespace characters of that string are removed.
Texture
First Valid
The first valid texture by input index.
  • Switch Node
  • Dispatcher Nodes
