Effect
Effect Applies an Image Post Processing Effect to a part of the Hierarchy Tree.
Properties
With the Blending Property you can change how the resulting Texture of the Node should be blended onto the rest of the scene. There are five Blending Modes of which you can choose. The Gain property defines a factor which the texture should be multiplied by before blending.
Resolution changes the size of the used Render Target. This can drastically reduce the impact on the GPU Performance and Memory. Especially with Distortion effects like Blurring you will most of the times not need the full resolution of the Layer. Lastly the AntiAliasing Property Group can adjust the used Anti-Aliasing for the resulting texture.
Limitations
  • Its subtree does not affect or use the Z-Buffer of the rest of the Layer, so the Z-Testing will not work between those two.
  • It does not work properly together with 3D Layer Effects. Especially the Screen-Space Ambient Occlusion will not be applied and occluded correctly.
  • Like the Blending Node its blend modes are only applied to objects inside the same layer and not to other layers. The Glow Blending is an exception to this.
  • Blending Nodes
  • Anti-Aliasing
  • IPP Color Corrections
  • IPP Distortions
  • IPP Filters
