Machine Signature
A Ventuz system (or machine) can broadcast its signature across the network to help control software finding other machines. If enabled in the Machine Configuration, an OSC Bundle is send periodically to the specified multicast IP address. All systems which are able to receive such UDP multicast packets can receive these bundles to find all Ventuz machines.
OSC Address /VENTUZ/MachineID
default IP addr Multicast 225.225.225.1
default IP port 19299
default interval 2 seconds
All the used commication ip's and ports are listed here.
with these arguments:
Arg
Index
OSC
Type
.NET
Type
Description
0 i Int32 Signature Version (1)
1 s String Machine Name (no Unicode support in OSC)
2 i Int32 Group ID
3 i Int32 Machine ID
4 T
F
Boolean True: Ventuz Designer
False: Ventuz Presenter/Runtime
5 i Int32 CLI Remoting IP port number, 0 if disabled
6 i Int32 .net Remoting IP port number, 0 if disabled
7 i Int32 Miranda/Vertigo Remoting IP port number, 0 if disabled
8 i Int32 OSC Remoting IP port number, 0 if disabled
9 i Int32 Number of IP addresses following from argument 10
10+ s String IP Address of the Ventuz Machine
Machine Signature Receiver .net Component
class Ventuz.Kernel.Remoting.MachineSignaturReceiver
  : Component, IDisposable, ISupportInitialize
The component continuously listens to the default UDP multicast address and port for any Ventuz Machine Signatures. All received signatures are stored in an internal cache and the user gets notified if a new signature has been received. If a certain signature has not been received for more than 5 seconds, it gets removed from the cache. The MachineSignaturReceiver provides two events for these notifications: SignatureReceived and SignatureExpired. The actual machine signature is managed by the MachineSignatur class which offers simple read-only properties to access the data.
  • Remoting
