Stage Editor
  2. Render Setup Selection and Editing
  3. Preview Selection Menu
    1. Physical
    2. Design Preview
    3. Disable Preview
    4. Options
  4. Machine ID Selection
  5. Design Preview
  6. All Outputs
  7. Connector Selection
With the Preview Selection Menu it is possible to switch between different Compositions,Previs Screens,Screens and Canvases which are defined inside the Render Setup. These will be then previewed inside the Renderer Window.
When working with a Previs scene the Composition preview might show a seemingly wrong aspect ratio, this is not a bug but rather a technical limitation. This is due to the Render Order, at the point of previewing the Composition the engine doesnt know yet which design size was set by the canvas. Thats why it will fall back to the Project settings Aspect Ratio.
Physical
This shows the currently active physical outputs configured in your Device Configuration. Use this to see what a single output will look like when played out in a Runtime. Inputs can be also previewed if configured inside your Device Configuration.
Design Preview
Disable Preview
Options
Enable all Physical Outputs: Will use all physical screens currently configured as outputs inside your Device Configuration and render your scene on it.
Lower Resolution for Previs: This will divide the Resolution inside a Previs by 4. Previs scenes can have very huge resolutions, to ensure good performance while working on it we introduced this option.
Show Bezel: Use this to show currently configured bezels coming from the Render Setup! inside the Rendering Window.
Changing the previewed machine ID will only render on Enabled Physical Outputs so make sure to enable this option inside the Preview Selection Menu!
Design Preview
The Design Preview will show all configured Screens,Compositions, Canvases and other machines defined in the Render Setup combined as one preview. This is especially helpful when working on bigger scenes using multiple Canvases.
All Outputs
Configuration of in and Outputs can be done inside the Device Configuration.
Connector Selection
  • Previs Screens
  • Screens
  • Compositions
  • Canvases
