  1. Templates
  2. Template Hosts
    1. Project Templates
    2. Scene Templates
    3. Animation Templates
      1. Animation Groups
  3. DataModel
    1. DataItems
      1. Data Items Meta Data
        1. General Properties
        2. Constraints
  4. Addressing Templates
  5. Data Formats
    1. XML
    2. JSON
    3. BIN
Template Engine
Auto-routing between states
Templates
A Template is an entity that describes both a logical and visual part that can be activated in conjunction with its corresponding data population. Every scene automatically defines a Scene Template, which represents the scene without any dynamic data defined for it. All other templates in the scene are defined by Present States of an animation logic and are usually associated with some amount of dynamic data. All Templates defined by a scene are organized in a hierarchical order that also declares their relationship between each other (Concurrency, Dependency, Independency). Templates are always organized in so called Template Hosts. Template hosts are organized in a host-tree where each host has exactly one parent host (except the root) and has one or multiple sub-hosts.
Relationships
  • Concurrent: Templates defined in the same template host are concurrent. These templates can only exist one at a time, so two concurrent templates are mutually exclusive.
  • Dependent: Templates defined in the same host-branch are dependent. These templates depend on one another. Thus a dependent template may only be called up if its parent template has already been activated. If the parent template is not activated, calling the child dependent template will activate first the parent, then the child.
  • Independent: Templates defined in different host-branches are independent.
Template Hosts
Project Templates
If the template engine is used Scene-comprehensively, it defines the root of the host-tree. For every scene that is injected into the project template host one Template is defined. So all scenes managed by this host are concurrent: there's none or one scene active at a time.
Scene Templates
Animation Templates
Animation Groups
DataModel
  • System Templates defined in the Project Template Host do not have a DataModel
  • Scene Templates defined by the scene have exactly one DataModel. This is the default.
  • Animation Templates have
    • exactly one DataModel if the declaring animation node is not grouped, or
    • zero or more DataModels defined by the grouped animations but no default !DataModel!
Animation1
Group2_Animation2
Group2_Animation3
Data Items
DataItems
Name C# Type Modes Description Attributes
Animation - - The Animation item defines a field that addresses a possible sub-template. The actual value of this field is null or a data instance (TemplateData) of a sub-template. Required
Trigger - RW A Trigger can be either an asynchronous event sent out to the remote client (R), a trigger sent from the remote client to Ventuz (W) or both (RW).
Group - (RW) A Group contains multiple sub-DataItems and acts like a folder. The mode is the sum of all sub-items only defines if the items below are readable and/or writable. The group itself has no value.
Float float RW A floating point value Default, Min, Max, Speed
Double double RW A double precision floating point value Default, Min, Max, Speed
Integer int RW An integer value Default, Min, Max, Speed
Boolean bool RW A boolean value Default
String string RW A string value Default, MaxLines, MinLines
Enum string RW A string value of type that matches the values of an enumeration. The possible values are define in the field Elements. Default, Elements
Color Color RW A color value Default, Alpha
Asset Uri RW A general Uri value that addresses one or multiple asset pools AssetPools
FloatArray float[] RW An array of float values Default, MinLength, MaxLength
DoubleArray double[] RW An array of double values Default, MinLength, MaxLength
IntegerArray float[] RW An array of integer values Default, MinLength, MaxLength
BooleanArray bool[] RW An array of boolean values Default, MinLength, MaxLength
ByteArray byte[] RW An array of byte values Default, MinLength, MaxLength
StringArray string[] RW An array of string values Default, MinLength, MaxLength
All Data Items are described by meta data that can be edited in the Property Editor after  clicking it. For example the Ventuz Director uses them to display Template and Project Data properly for the operator of the program. In Remoting you can use the Data Model's Meta Data to accomplish similar results. Below you can see how Ventuz handles these meta data.
General Properties
Data Types Value Effect
all empty string Not used in the automatic naming.
!X Shows the value of this data item in the display name of the page instead of in its description.
float, double fX Fixed point number with X decimals. X defaults to 2.
cX Currency with X decimals. X defaults to 2.
eX Exponential notation with X decimals. X defaults to 6.
nX Number with X decimals. X} defaults to 6.
p Percentage. Note that the displayed number is therefore multiplied by 100.
integer dX Integer number with minimum X digits. X defaults to 1.
xX Hexadecimal number with minimum X digits. X defaults to 1.
boolean X;Y X if true, else Y.
string, enumeration X Show string truncated to X characters. Do not truncate if 0.
-X Show string truncated to X characters and show elipsis for truncated characters.
color c Known color name or expressed as Red, Green, Blue values.
# Hexadecimal string.
array 0 "X" Show number of values followed by X
csv Show values as comma separated list.
asset nx File name with extension.
n File name without extension.
uri Full file path.
Constraints
Data Types Property Usage
all Default The initial value of the data item.
float, double, integer Max Maximum possible value. Value will be set to Max if it is greater.
Min Minimum possible value. Value will be set to Min if it is less.
Speed Change speed when using drag and slide to change the value.
string Choices You can add a comma seperated list of values to change the text box to a combo box, so that the user can choose from predefined values as well as type a custom text.
MaxLines Maximum number of lines. Will be truncated to this number of lines if it is exceeded.
MinLines Minimum number of lines. Will be truncated to this number of lines if it is underrun.
RegEx A regular expression that the given text is tested against so that only input of a certain form is allowed. If it does not match the text cannot be set.
color Alpha Whether alpha can be defined as well or not.
enumeration Elements Comma separated list of elements that the user can choose from. Note that Default must be present in this list.
array MaxLength Maximum allowed number of values in the array.
MinLength Minimum allowed number of values in the array.
asset AssetPools The allowed asset pool to choose from. All assets that are not associated with any of the chosen pools will be ignored. Misc allows any type of file. This also filters the list of assets in the shotbox of the Ventuz Director when it was opened by  clicking on the asset channel.
Required If set it disallows to leave this data item empty.
  • Template Engine - BaseUri: All elements of the Template Engine can be addressed by an absolute Uri. These Uris always start with this base uri:
    ventuz://templates
  • Template Hosts: The absolute address of any template host is constructed as a full path of the entire host chain. All names of the hosts are combined with an uri path separator ("/") and also end with a trailing slash ("/")
    • Project Host: Usually there is no need to address the project template host, if required this Uri is its address. It only differs in the trailing slash to indicate that a template host is addressed.
      ventuz://templates/
    • Scene Hosts: The name of this host uses the Scene Identity of the scene it belong to. The Scene Identity is the lower case filename of the scene file without extension. Special characters are Url-encoded where the path separator "/" is replaced by "|".
      ventuz://templates/<sceneidentity>/
      Examples:
      ventuz://templates/scene1/
      ventuz://templates/scene2/
      ventuz://templates/folder|scene3/
      Please note that the Project Template Host does not have a name! Therefore the first path segment after the base uri is always the name of the Scene Template Host regardless if the scene host is parented in a project host or not!
      Two scenes saved as .\Scenes\Folder\Scene1.vzs and .\Scenes\Folder_Scene1.vzs would result in an identical Uri address for their template hosts: ventuz://templates/folder_scene3/. Injecting these two scenes into a project template host will cause an error to be thrown!
    • Animation Hosts: The name of an Animation Host is defined by the Animation DataItem of the parent DataModel. By default this name is bound to the name of the actual Animation Node (or Animation Group Node), but this name-binding could be released by the user and a different name could be applied. If the DataItem is grouped within a DataGroup, the full path inside the declaring DataModel is used. A dot (".") is used as path separator.
      ventuz://templates/<sceneidentity>/<AnimationDataItem>/
      ventuz://templates/<sceneidentity>/<AnimationDataItem>/<AnimationDataItem>/.../
      Examples:
      ventuz://templates/scene1/Animation1/
      ventuz://templates/scene1/DataGroup.Animation.DataItem/
      ventuz://templates/folder|scene3/DataGroup.Animation.DataItem/
      ventuz://templates/folder|scene3/DataGroup.Animation.DataItem/DataGroup.DataItem/
      Two Animations bound to a DataModel as /DataGroup/Animation1 /DataGroup_Animation1 would result in an identical name for their sub template hosts: ventuz://templates/scene1/DataGroup_Animation1/. The Scene Model Validator will cause an error to be thrown!
    Absolute address of Templates uses the address of their Template Host plus the name of the template. The resulting Uri can be distinguished from Template Host addresses by the lack of the trailing slash "/" (they addressing a file not a path). The name is the actual name of the present state defined in the Animation Logic.
    ventuz://templates/<scene_identity>/Scene
    ventuz://templates/<scene_identity>/<Animation_DataItem>/<TemplateName>
    Examples:
    ventuz://templates/scene1/Animation1/Template1
    ventuz://templates/scene1/Animation1/Template2
    ventuz://templates/scene1/Animation1/Animation2/Template3
    The Scene Template has always the reserved name "Scene". This name cannot be changed by the user. Other Scene template may be added in the future (Global, Constant, etc
    All templates defined in a template host must be unique. If multiple Animation Nodes are grouped all Present States must have a unique name across all animations within that group. Otherwise an error will be thrown.
  • DataItems
    To address a DataItem the engine must know which DataModel is addressed. A DataModel is addressed by the Template Host that declares it and by the name of the DataModel which is an empty name for the default DataModel. The DataItem itself is addressed by the fullpath within the DataModel where groups (folders) are separated by ".". An address of a DataItem is expressed as a file within the folder defined by the Template Host. There are three ways to qualify a DataItem-Address:
    1. Default: (first character is a dot ".")
      ".group.group.item"
    2. DataModel-Qualified: (first character is "$" followed by the name of the DataModel)
      "$DataModelname.group.group.item"
    3. Template-Qualified: (first character is a letter or an underscore "_")
      "TemplateName.group.group.item"
Examples:
.Text1
Animation1/Template1.Line1.Text
Animation1/Template1.Line1.Color
Animation1/Animation2/$Group2.Headline.Text
Data Formats
In order to store and transfer a complete set of data, we plan to integrate multiple different data formats for being compatible to different platforms and integrators:
Ventuz supports three different data formats: XML, JSON and BIN. all of these formats are 100% compatible to each other and the user can decide which format he wants to use. All three formats are text based and the receiver (Ventuz) can easily decide which parser to user. It simply looks to the first non-whitespace character: "<" for XML, "{" for JSON and any other for base64-BIN
The JavaScript Object Notation (​JSON.org) has some advantages and disadvantages compared to XML:
  • JSON has strong types (number, boolean, string, arrays, etc) where XML only has text. Without XML-Schema a XML reading application must interpret all data as text, because it doesn't know if a value is a number or an array of floats.
  • JSON doesn't support attributes for objects. Since our Template Data is using attribute to add meta and user data to a data instance, we introduce a notation to handle such data: every named field starting with a '@' character for its name is handle as attribute for the current object. Attributes must appear before any normal data field in order to help parsers only to read the metadata without interpreting the actual data structure.
  • JSON doesn't support namespaces. That's why we introduce a reserved attribute name "@". It is used to store that template URL. In XML we use the attribute "ns" to make it easier for XML handlers. Template Data in XML always fall into the default namespace ("").
XML
<VTD ns="ventuz://templates/ingame/Scene">
  <LowerThird_Center ns="ventuz://templates/ingame/LowerThird_Center/NS2LAdd">
    <FirstLine>First Line</FirstLine>
    <FirstAdd>Addon Text</FirstAdd>
    <SecondLine>Second Line</SecondLine>
    <Visual01>ventuz://scenes/Assets/logos/FrankfurtSnakes.vzs</Visual01>
    <Visual02>ventuz://images/Assets/sponsorlogos/HH.png</Visual02>
  </LowerThird_Center>
  <UpperThird ns="ventuz://templates/ingame/UpperThird/Scoreboard">
    <Banner ns="ventuz://templates/ingame/UpperThird/Scoreboard_Banner/Banner2LAdd">
      <FistLine>First Line</FistLine>
      <Visual>ventuz://scenes/Assets/logos/HP.vzs</Visual>
    </Banner>
  </UpperThird>
</VTD>
JSON
	"@": "ventuz://templates/ingame/Scene",
	"LowerThird_Center": {
		"@": "ventuz://templates/ingame/LowerThird_Center/NS2LAdd",
		"FirstLine": "First Line",
		"FirstAdd": "Addon Text",
		"SecondLine": "Second Line",
		"Visual01": "ventuz://scenes/Assets/logos/FrankfurtSnakes.vzs",
		"Visual02": "ventuz://images/Assets/sponsorlogos/HH.png"
	"UpperThird": {
		"@": "ventuz://templates/ingame/UpperThird/Scoreboard",
		"Banner": {
			"@": "ventuz://templates/ingame/UpperThird/Scoreboard_Banner/Banner2LAdd",
			"FistLine": "First Line",
			"Visual": "ventuz://scenes/Assets/logos/HP.vzs"
BIN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  • Remoting
  • HowTo build a Template
