Ventuz Machine Service
  1. How to connect
  2. Configure Windows Service
  3. Process Modes
  4. Notification Icon
  5. Project Management
  6. IP Filter / Access Restrictions
  7. VMS Machine Discovery
  8. VMS Command Summary
    1. HELP
    2. HELO
    3. STATE
    4. INFO
    5. ID
    6. GETCFG / SETCFG
    7. CLOCK
    8. KILL / KILLALL
    9. INST
    10. SCAN / SCANSTATE
    11. PROJ
    12. SCENES
    13. SM
    14. START
    15. HW
    16. OPT
    17. LST / ACT / GET / SET / DEL / REN
    18. EXIT
  • Get information about installed Ventuz software (such as Version, installation paths, etc)
  • Get information about the available hardware of the System (video and audio boards, gamepads, MIDI interfaces, etc)
  • Get information about all Ventuz Projects and Scenes found on the system.
  • Read, write and rename all configuration files (Ventuz config, Machine config, AV config and Render Setups)
  • Start and Stop (kill) Ventuz Runtime Processes
  • Get information about the currently running Ventuz process (resolution, number of pipes, cluster clock)
  • Sending a heartbeat every 5 seconds as a UDP Multicast message for automatic machine discovery and state monitoring.
  • The VMS is mainly used to configure a system remotely, but it is also used to configure the local system! Ventuz Machine Config uses VMS for any configuration task.
  • Ventuz Director uses VMS to launch and maintain the Ventuz process running on the local system and/or remote systems. Via the VMS project management VMS is able to locate projects by their location on disk and/or by their project ID. This is important to ensure that a group of machines (Cluster) renders the same project!
  • Custom remote applications or automation adapter can use the VMS to control the projects and processes of a local and/or remote system by utilizing the VMSClient class.
How to connect
VMS runs as a multi-client TCP server on port 20405 (Ventuz 5 VMS listens on port 19405. A list of ports used by Ventuz can be found here: VentuzIpPorts). The actual communication protocol is text based (UTF-8) and accepts simple human readable commands. A user can use a ​telnet client like ​Putty or ​Microsoft Telnet Client to connect to VMS.
Disable VMS
Configure IP Restrictions
Process Modes
  • Service: Windows service started with the Windows system when enabled. This is the default way of using VMS
  • Notification: VMS acts only as a notification icon in the Windows notification bar. It communicates with the local VMS service only. If no VMS service is running the notification icon is gray on show the error No Connection to VMS
  • Application: VMS runs as a local application within a Windows session. It also display a notification icon in the Windows notification bar. Only application mode the notification icon has the menu entry Exit to close the application.
SYSTEM USER
<none> <none> -app -notify
No VMS is running Service Application Application Notification
VMS Service is running exit 2 Notification Notification Notification
VMS Application is running exit 2exit 1exit 1exit 1
VMS Notification is running Serviceexit 1exit 1exit 1
Notification Icon
Error xxxx0000 No connection to Ventuz Runtime or Designer
Warning 0000xxxx Connection Ventuz Runtime or Designer, but no renderer/project loaded
Ok 00000000 Ventuz is up and running.
VMS Service is not running. No connection from VMS notification to VMS service.
  • Scan Projects: Re-scan all configured project folders for Ventuz Projects.
  • Configure: Configure the connected VMS
  • Exit: Closes VMS (only available in Process-Mode)
Project Management
  • by default (no parameters) any remote IP and local IP has access to VMS
  • VMS can be restricted to a set of remote IP addresses. Only single full qualified IPv4 or IPv6 IP addresses can be specified. If you want to gain access from multiple remote IP address you have to add multiple restrictions parameters. Wildcards or patterns are not allowed. Mistyped or misspelled addresses are ignored. If any remote IP is specified the localhost is always included in the list! So local access is always possible, even if access has been restricted to certain remote IP addresses.
    -192.168.1.100 -192.168.1.101 -192.168.1.102
  • VMS can be restricted to be only accessible by the local system (no remote access allowed, any specified remote IP is ignored!) by specifying the command line parameter
    -local
route print
This ​Microsoft support page explains how to change the metric of network adapters.
VMS Command Summary
HELP
HELO
HELO
250 Completed [104]
VZ_108290380002111_BFEBFBFF000106A5_00426-065-0527052-86603 Hello [192.168.3.140:50613]
  • Constant text "VZ"
  • Mainboard serial number (Win32_BaseBoard.SerialNumber)
  • Processor ID (Win32_Win32_Processor.ProcessorId)
  • Windows Product ID (Win32_OperatingSystem.SerialNumber)
STATE
STATE
211 Status [37]
Error [00040000]: ErrorDisconnected
INFO
INFO
200 Ok [636]
<VentuzInfo>
  <Version />
  <MachineName>LOCAL(VBOX-DOC2013)</MachineName>
  <Mode>Designer</Mode>
  <EditionName>Ventuz 4 V4.00.00 x64</EditionName>
  <GroupID>0</GroupID>
  <MachineID>0</MachineID>
  <RateNum>60000</RateNum>
  <RateDen>1000</RateDen>
  <PipeModes>
    <PipeMode>OffScreen</PipeMode>
  </PipeModes>
  <ProcessID>1292</ProcessID>
  <ProcessGUID>a6cd8d0d-c2d3-4d88-b1ef-54cb3593df75</ProcessGUID>
  <SystemID>VZ_108290380002111_BFEBFBFF000106A5_00426-065-0527052-86603</SystemID>
  <ProjectGUID>15e6698c-7726-4be1-9ede-3ee1c58d9005</ProjectGUID>
  <ProjectName>Hockey</ProjectName>
</VentuzInfo>
ID
ID
200 Ok [20]
VBOX-DOC2013, 0, 0
ID NEW-NAME 1 2
200 Ok [17]
ID has been set
ID
200 Ok [16]
NEW-NAME, 1, 2
GETCFG / SETCFG
GETCFG
200 Ok [130]
<VMS>
  <ProjectPath>C:\Users\Public\Documents\Ventuz4\Projects</ProjectPath>
  <ProjectPath>G:\PROJECTS</ProjectPath>
</VMS>
CLOCK
CLOCK
250 Completed [7]
23470
KILL / KILLALL
INST
INST
200 Ok [390]
<Installations>
  <Installation Version="4.00.00" Build="181">
    <InstallationDir>C:\Program Files\Ventuz Technology Group\Ventuz 4\</InstallationDir>
    <DesignerPath>C:\Program Files\Ventuz Technology Group\Ventuz 4\Ventuz.exe</DesignerPath>
    <RuntimePath>C:\Program Files\Ventuz Technology Group\Ventuz 4\VentuzPresenter.exe</RuntimePath>
  </Installation>
</Installations>
SCAN / SCANSTATE
SCAN
200 Ok [18]
Scan started ...
SCANSTATE
250 Completed [16]
Scan completed
PROJ
PROJ
200 Ok [44129]
<Projects>
  <Project VPR="false" ID="96077cdf-573b-4f5e-8869-5dcb6e1c4768" FullPath="C:\Users\Public\Documents\Ventuz4\Projects\__HELP__\VentuzHelp\Help1.vzp">
    <VentuzVersion>4.0.0.0</VentuzVersion>
    <Name>Help1</Name>
    <Author>Ventuz</Author>
    <Copyright>2019 Ventuz Technology</Copyright>
    <Category>Ventuz</Category>
    <ThumbnailBase64>iVBORw0KGgoAAAA..........ggg==</ThumbnailBase64>
  </Project>
</Projects>
SCENES
scenes 15e6698c-7726-4be1-9ede-3ee1c58d9005
200 Ok [216]
Templates/FS_LineUp, Templates/FS_Promo, Templates/FS_Scoreboard, Templates/InGame
SM
SM 15e6698c-7726-4be1-9ede-3ee1c58d9005 Templates/FS_Promo
200 Ok [44778]
<SceneModel DisplayName="templates/fs_promo" ThumbnailArea="0,0,1,1" Thumbnail="iVBORw0KGgoA........JRU5ErkJggg==" xmlns="http://www.ventuz.com/Ventuz/SceneModel/1.0">
  <SceneModel.DataModel>
    <DataModel>
      <Animation AnimationName="FS_Promo" Name="FS_Promo" Label="Control" />
    </DataModel>
  </SceneModel.DataModel>
  <SceneModel.DataModelScene>
    <DataModel>
    </DataModel>
  </SceneModel.DataModelScene>
  <SceneModel.Animations>
    <AnimationModel Name="FS_Promo">
      <AnimationModel.DataModel>
        <DataModel>
          <String Default="7:30" MinLines="1" MaxLines="1" RegEx="" Name="Time" Label="Time" Description="Event start time." Mode="RW" />
          <String Default="VHL NIGHT" MinLines="1" MaxLines="1" Name="Title" Label="Event" Description="Event title" Mode="RW" />
          <String Default="LIVE" MinLines="1" MaxLines="1" Name="FirstLine" Label="FirstLine" Description="FirstLine" Mode="RW" />
          <String Default="Event Location" MinLines="1" MaxLines="1" Name="SecondLine" Label="SecondLine" Description="SecondLine" Mode="RW" />
          <String Default="City" MinLines="1" MaxLines="1" Name="ThirdLine" Label="ThirdLine" Description="ThirdLine" Mode="RW" />
          <String Default="NIGHT" MinLines="1" MaxLines="1" Name="LogoSubtitle" Label="3D league subtitle" Description="3D subtitle below the league logo" Mode="RW" />
          <Visual Images="True" Textures="True" Movies="True" Scenes="True" Required="True" Name="Visual01" Label="Left_TeamVisual" Description="The left team visual commonly used for the home team logo." Mode="RW" />
          <Visual Images="True" Textures="True" Movies="True" Scenes="True" Required="True" Name="Visual02" Label="Right_TeamVisual" Description="The rightt team visual commonly used for the guest team logo." Mode="RW" />
          <Visual Images="True" Textures="True" Movies="True" Name="Visual" Label="BGD_Still" Description="Background image" Mode="RW" />
        </DataModel>
      </AnimationModel.DataModel>
</SceneModel>
START
START 15e6698c-7726-4be1-9ede-3ee1c58d9005
200 Ok [23]
Process started [680]
HW
The HW command gives detailed information about available hardware, available licenses and installed cultures on the VMS system. The returned XML document is used by the Ventuz Configuration tools to remotely configure the system. The hardware information also contains details about the screen screen configuration of the graphics adapter. (​Eyefinity or ​Mosaic configuration)
HW
200 Ok [60438]
<MachineHardware>
  <License>
    <Outputs>2</Outputs>
    <OutputsSDI>2</OutputsSDI>
    <OutputsIVGA>2</OutputsIVGA>
    <Cluster>true</Cluster>
    <Misc />
    <OffscreenOnly>true</OffscreenOnly>
  </License>
  <Gamepads />
  <SerialCOMs />
  <MidiInputs>
    <Device Name="LoopBe Internal MIDI" />
  </MidiInputs>
  <MidiOutputs>
    <Device Name="Microsoft GS Wavetable Synth" />
  </MidiOutputs>
  <BoardsBinarySource>Enum</BoardsBinarySource>
  <BoardsBinary>PDw8 ...
  <Adapters>
    <Adapter Ordinal="0" Vendor="NVidia" GpuCount="1" Width="1920" Height="1080">
      <Output X="0" Y="0" W="1920" H="1080" />
    </Adapter>
    <Adapter Ordinal="1" Vendor="NVidia" GpuCount="1" Width="1920" Height="1080">
    </Adapter>
  </Adapters>
</MachineHardware>
OPT
  OPT
200 Ok [3892]
  <Trigger Name="Log" Label="Log Stream Statistics" Description="Outputs useful audio and video statistics to the Ventuz log." Mode="W" />
    <Integer Default="0" Min="0" Max="2147483647" Format="0" Name="ID" Label="ID" Mode="RW" />
    <Enum Elements="&lt;None&gt;, 3Screens, 4800, 8ktesting, 9x16, Dual, DualScreen, &quot;Full HD&quot;, HD, UHD, UHD1, Wall" Format="0" Name="RenderSetup" Label="Render Setup" Mode="RW" />
  </Group>
    <Boolean Default="False" Format="Yes;No" Name="Wireframe" Label="Wireframe" Mode="RW" />
    <Boolean Default="False" Format="Yes;No" Name="Stats" Label="Show Statistics" Mode="RW" />
    <Group Name="STATS" Label="Statistic Options">
      <Boolean Default="False" Format="Yes;No" Name="StatsPerf" Label="Performance Statistics" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsSysInfo" Label="System Statistics" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsGPUInfo" Label="GPU Statistics" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsAVInOut" Label="AV Input/Output Statistics" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsMovie" Label="Movies Statistics" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsHistory" Label="Bar History" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsAccuBars" Label="Accumulated Bars" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsStallGPU" Label="Force GPU Stall" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsUser" Label="User messages" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsWatches" Label="Watches" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsScaleToPreview" Label="Scale to Preview" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsLayerProcessing" Label="Layer Processing" Mode="RW" />
      <Boolean Default="False" Format="Yes;No" Name="StatsTracking" Label="Tracking" Mode="RW" />
      <Integer Default="0" Min="1" Max="10" Format="0" Name="StatsFrameCount" Label="Frame Count" Mode="RW" />
    </Group>
    <Boolean Default="False" Format="Yes;No" Name="InputDiag" Label="Show Input Diagnostics" Mode="RW" />
    <Boolean Default="False" Format="Yes;No" Name="BoundingBoxes" Label="Show Bounding Boxes" Mode="RW" />
    <Boolean Default="False" Format="Yes;No" Name="Alpha" Label="Show Key" Mode="RW" />
  </Group>
      <Integer Default="0" Min="0" Max="10000000" Format="0" Name="SoftwareWatchdogTimeout" Label="Software Watchdog                                  Timeout" Mode="RW" />
    </Group>
      <Group Name="DX_0" Label="DirectX DirectX Out automatic">
        <Enum Elements="None, Low, Medium, Best" Format="0" Name="Multisampling" Label="Multisampling" Mode="RW" />
        <Color Default="0, 0, 0, 127" Alpha="True" Format="c" Name="BorderColor" Label="Border Color" Mode="RW" />
        <Integer Default="0" Min="0" Max="256" Format="0" Name="EffectBleed" Label="Effect Bleed" Mode="RW" />
        <Boolean Default="False" Format="Yes;No" Name="VirtualFullscreen" Label="Virtual Fullscreen" Mode="RW" />
        <Boolean Default="False" Format="Yes;No" Name="ShowPointer" Label="Show Mouse Pointer" Mode="RW" />
        <Boolean Default="False" Format="Yes;No" Name="PreventQueuing" Label="Prevent D3D Queuing" Mode="RW" />
      </Group>
    </Group>
  </Group>
</DataModel>
OPT .REN.Wireframe
200 Ok [7]
False
OPT .REN.Wireframe True
200 Ok [6]
True
  • VC: Ventuz Configuration, contains name, id and group id as well the names of the active sub-configurations.
  • MC: Machine Configuration, contains culture settings, touch settings, remoting options
  • AV: AV Configuration, Audio/Video input and output, other hardware and pipe mappings.
  • RS: Render Setup, multi-screen video wall and multi-projection setups.
EXIT
