Mesh Loader
3D Geometries which cannot be expressed by the primitives available in Ventuz (i.e. Rectangle Node, Cube Node, ...) are usually modeled in dedicated 3D modeling programs and then imported into Ventuz. The Mesh Loader accepts a file name of a Ventuz Mesh file (*.vzm) and is responsible for loading and rendering the mesh. If a mesh is split into multiple subsets, the Subset property can be used to either render all of them (value set to -1) or only the subset at a dedicated index.
For a discussion on importing non-vzm files (i.e. OBJ, COLLADA, ...) see Importing of 3D Geometry.
