Math Effects
Linear This node interpolates linearly between a start and target value.
Decay This node interpolates linearly between a start and target value. In contrast to Linear the gradients for increase and decrease can be set individually.
Damper This node interpolates between a start and target value with ease-in and ease-out.
Oscillator This node oscillates around a target value, beginning at a start value.
Ease This node interpolates between a start and target by using common easing functions.
Ease Morph This node blends a Begin and Target value according to a specified easing function based on the Morph value.
Clipping This node clips and maps a range of values to another value range.
Delay This node transfers values from input to output with a customizable delay.
Linear
Interpolates linearly between the current value of the Value output property and the value of the Target input property. The interpolation is automatically started when the Target value changes and finishes after the amount of seconds specified in Duration. Once the interpolation is completed, the Reached event is fired.
By checking the !UseTarget2 property, the interpolation will use the value of Target2 instead of Target as the interpolation goal.
Decay
Damper
Oscillator
The Oscillator node is similar to the Linear Node in that it performs an interpolation between the current output value and the target value. It uses a spring-mass type equation to guide the interpolation. The interpolated value will close in on the target value, overshoot it, reverse velocity, overshoot it, while at the same time slowing down until the target is reached.
Ease
The Ease node is similar to the other interpolation nodes in that it performs an interpolation by the well known easing functions like Back, Bounce, Elastic, etc. The Function and Mode properties select the easing mode and interpolation type. Some easing functions require additional parameters. If such a function is selected the required parameters show up in the Property Editor while others are hidden.
Overview of all supported easing functions:
Ease Morph
The Ease Morph node blends Begin and Target based on the Morph value by the well known easing functions like Back, Bounce, Elastic, etc. The Function and Mode properties select the easing mode and interpolation type. Some easing functions require additional parameters. If such a function is selected the required parameters show up in the Property Editor while others are hidden.
The supported easing functions are identical to the ones of the Ease Node.
Delay
Clipping
