Matrix
Rotation XYZ This node provides a matrix to rotate around the X, Y or Z axis.
Scaling This node provides a matrix to scale along the X, Y and Z axis.
Translation This node provides a matrix to translate along the X, Y and Z axis.
The Matrix Nodes provide special types of matrices that can be used as Input Properties for the World Transformation, View and Projection Nodes.
Matrix Operation
The Matrix Operation node is usually used to multiply matrices and thus perform a concatenation of matrix transformations. It can, however, also perform element-wise division, addition or subtraction.
Vector Transform
