Value Switches
Multi Switch This node processes multiple inputs and passes the result to the output. One can handle multiple input groups with a single index.
Value Switch
The Value Switch Node is the equivalent of the Switch Node for the scene Content. It is used to switch between the values of the Value input properties based on the Case property. Input Value properties can be added/deleted with the methods at the bottom of the Property Editor or in the context menu of this node. Please refer to the Switch Node for more information.
Multi Switch
Single, Integer, Boolean, String, Event, Texture.
The + and - buttons on the bottom of the property window add and remove additional input values to all groups. All groups of a Multi Switch Node have the same number of input values.
All types
Last Changed
The output value is always the last changed value of the input group.
Integer/Float
Sum
The sum of all input Values.
Min/Max
The minimum/maximum input value.
Average
The average value of all input values.
For integers one can define whether to round (Average) or always choose the next lower (AverageFloor) or next higher (AverageCeiling) integer.
Boolean
AllOn/AllOff
Output is true if all input booleans are true/false.
AnyOn/AnyOff
Output is true if at least one input boolean is true/false.
SingleOn/SingleOff
Output is true if exactly one input boolean is true/false.
String
Concat
The concatenation of all input strings.
Longest/Shortest
The shortest/longest string.
FirstNonEmpty
The first string by index that is not empty. With FirstNonEmptyTrimmed all leading and trailing whitespace characters of that string are removed.
Texture
First Valid
The first valid texture by input index.
