Video
Live Video
The property Ordinal specifies the device which provides the video frames. The list of these devices can be edited in the Video section of the Audio Video Configuration. The methods Disable and Enable pause and resume the video input stream and shows in pause state either the last frame, black or white depending what you configured in the Board Options . The Live Video Node provides the live video frames in the Texture output property. This one has to be bound to a Texture node.
VideoRunning: Set if the video node is running and updates the video frames. If one has paused the video by calling the Disable method this property will be unset. Please note that all Live Video nodes that accesses the same physical video stream will changes their VideoRunning state if just one node has called Enable or Disable.
Configuring Ancillary Data (Timecode, etc)
To read ancillary data from an SDI input, first check Enable Ancillary Input in the Machine Configuration. Then click on Edit Custom Model at the bottom of the properties window of the live video node. This allows to add reading certain kind of information:
LTC_ LTC timecode RP 188 Deltacast, DVS, Black Magic
VIT1 VITC timecode field 1 RP 188 Deltacast, DVS, Black Magic
VIT2 VITC timecode field 2 RP 188 Deltacast, DVS, Black Magic
Interpreting AFD Information
0000 0 undefined 1 undefined
0001 2 reserved 3 reserved
0101 10 reserved 11 Reserved
0110 12 reserved 13 Reserved
0111 14 reserved 15 Reserved
1100 24 reserved 25 reserved
The reason for this encoding is that some hardware operates with 8 bit and not the full 10 bit, throwing away the two least significant bits.
Movie Clip
Overview
The Movie Clip node gives the Ventuz operator more control over initialization and playback of movie clips. It provides frame accurate playback for use in Ventuz Cluster setups, is able to play the most common video container formats like WMV, AVI, MOV and MKV, and is capable of playing Quicktime movies in Ventuz. For all full list of supported video codecs, see Supported Video Formats. The video decoder in this node is based on the FFMPEG project and provides the best performance compared to pre-installed DirectShow and WMF decoders.
Configuration
Buffers
Interlacing
Color Space
Usually Ventuz will automatically detect color space and range. But some codecs give false information, and some clips are badly encoded. These options allow to override the automatically detected. When using these options, be careful not to do more harm than good! These options do not apply to RGB encoded clips or images.
Color Space is one of the YUV color spaces. The difference between these is largest for saturated colors, so when in doubt use clips with color bars to check. On normal material the difference is often hard to see.
Name Description
auto use automatic detection (recommended)
BT601 used by NTSC & PAL
BT709 used by modern HD standards
SMPTE240M interim specification, replaced by BT709 to which it is similar
FCC FCC version of NTSC, basically BT601 rounded to two decimals
Many codecs encode YUV in a limited Color Range from 16 to 235 (Y) or 240 (UV), emulating the footroom and headroom of an analog signal. As color space, this is usually detected automatically. If this is wrongly detected, a significant change in contrast and brightness is seen, and the Color Range option can be used to override.
Advanced
Disable Threading
For most codecs, each MovieClip node will create as many threads as there are cores available. If many clips are played back, this is counterproductive as these threads get in each others way. Also they may steal time from the Ventuz main thread, causing stutter.
Enable Audio Compensation
Often the audio hardware is not perfectly in sync with the video hardware. In such cases, the audio must be slowed down or sped up a little to compensate when playing back long video clips. This is called Audio Compensation and is explained in detail at the Sound Nodes.
Property Description
The Movie Clip node provides several input properties for managing and controlling playback and output properties which inform about the state of the active movie clip.
In the category Movie, the input property File specifies the movie file to play. Enabled prepares the node for the actual playback. If a file is specified and the node is disabled, the clip file will be parsed to retrieve information about duration, resolution, etc. No textures are reserved in this state and the actual decoder is not initialized. A movie clip can however only be played back if the node is enabled! If the file contains multiple video streams, one can be selected with the VideoStream property.
The property AutoPlay specifies if playback should start immediately after the node is enabled and all necessary resources are initialized. Async defines if all necessary initializations should happen in the background to avoid render stalls.
The Scrub property enables scrubbing. In this mode the clip will follow the value of SeekTo directly. If the clip is configured for reverse play, it is possible to seamlessly scrub forwards and backwards as long as the decoding can keep up with the speed. Obviously the computer needs to be able to decode the clip at double speed if it is supposed to scrub at double speed, scrubbing backwards is even a bit slower. If the clip is configured to buffer all frames, scrubbing will never stutter.
The properties in the category Audio can be used to adjust the audio playback of the movie clip and to select a playback device for the audio channel. Audio playback can be completely disabled with the Audio property and the volume can be adjusted with the Volume property. If the file has multiple audio streams, one can be selected with the Stream property in the Audio category.
Several output properties inform about the movie characteristics and initialization and playback states.
In the category Movie, the Width and Height of the movie frames are provided. FPS provides the frames-per-seconds encoded in the movie and Duration its duration in seconds. If a movie clip has meta-date embedded, this information is made available in XML format by the Meta property. All of this information is available even if the node is not enabled because they are gathered in an initial file parse step. The Meta property can be evaluated with the XPath and XML nodes.
The Position property provides the active playback position in seconds. This property is set to -1 if the node is not enabled or if the movie file cannot be parsed or decoded.
The IsLoaded property is set to true if the movie file has been loaded successfully. Additionally, the Loaded event is fired. If a movie clip cannot be played for any reason, the Error event is fired. The IsEnabled property is set to true if enabling the node has succeeded without errors. IsPlaying is set to true during playback and set to false if the playback is paused or the end of the clip is reached. Every time the clip loops, the Looped event fires. When Loop is disabled and the clip reaches the End position, the Completed event is fired. Completed is not fired should the clip reach or pass the End position in Loop mode. The Seeked event is fired if a seek to a new position has finished and the movie is ready for playback again. The property Texture provides the current video frame and has to be bound to a Texture node. The MemoryMB property tells the amount of memory used for audio and video buffers. This may increase during playback if the clip is badly encoded.
Synchronous Seeking in a Cluster
When seeking a high-bitrate movie or multiple movies at the same time, it is very likely that the computer is not fast enough to immediately continue playback at the new position. This is especially problematic if multiple machines in a cluster are supposed to playback parts of the same movie clip.
A save method to do seeking is to pause the movie, seek, then wait a second for things to settle and send the play event.
Depending if the machine is part of a cluster, the movie clip node will behave differently:
Not in a cluster (GroupID zero): The movie will pause until enough frames are decoded to guarantee smooth playback.
In a cluster (GroupID not zero): If seeking failed to happen in time, a second seek is made to a time in the future, hoping that it's enough. This is like shooting clay pigeons, don't shoot where it is, but where it will be. If things went right, the first decoded frame will be slightly in the future, and displayed until real-time and movie-time are synchronized again.
ErrorCodes
Ok Everything is fine
NoVideo No video stream found
Movie Stream
The Movie Clip node can not play back true video live-streams, that is what the Movie Stream node is for. Instead of opening a particular file like the Movie Clip node does one must input an URL address to a Live Stream on a Server.
The two can be easily confused. For instance, Youtube videos must be used with the Movie Clip node, as they can be seeked. Technically speaking, Youtube is just a file server for movie files. Still some other streams using the same primary protocol (http) are true live-streams and require the Movie Stream node. Rule of thumb: If it can't seek, use Movie Stream.
The Movie Stream does not need as many Input Properties as the Movie Clip, since looping, seeking or restarting the stream is not possible. The according properties and fired events are left out in the Movie Stream node. All other Properties as well as the Configuration are similiar to the ones of the Movie Clip.
Supported Protocols
Unsupported Protocols
Movie Frame
The Movie Frame node is almost the same as the Movie Clip node except that this node does not play movies in the common way. Instead, it accesses single frames of a video stream by frame index. The main application of this node is fast seeking within a movie clip that is optimized for such an operation, like Quicktime Animation movies.
Image Sequences
Configuration
Smooth Loops
The Loop property allows to specify a loop start point. The initial value of this property is -1, which disables this feature.
Performance
When playing backwards and forwards:
