Template Port
Template Port This node provides access to the Template Engine from within the scene logic
Data
Template Control
Output properties
Count indicates the amount of takes available, if no or an invalid Data is set the property shows the default value 0. Current shows the current state of the template -1 means that a template is cueing. Duration provides the duration of the transition from the present template to the next one.
Descripton gives the user defined description of the template.
