Performance Statistics
The performance statistics is a display rendered above the Ventuz output. It can be enabled from the designer or the live options to analyze performance problems in a scene.
This has been enhanced as of Ventuz 4.04.00.
Displays
The performance statistics contain a lot of information. In many cases displaying it all can be a bit overwhelming and requires a lot of screen real-estate. So individual sections can be enabled and disabled:
With all sections enabled, it can looks like this:
Here is an explanation of these sections. This is done with the drop-down button.
Performance
In general:
History Mode and Pause
To see spikes in performance better, enable the History Mode with the drop-down box. Pressing the pause key on keyboard will pause and continue the update of the bars. When the history mode is on and pause mode is on, use the page-up and page-down keys to scroll.
Interpreting GPU Measurement
Accumulated Bars Versus Detailed Timeline
Performance Impact of Measurement
System Information
For instance, the driver may need to round up the width of a texture to the next power of two, so a 640 pixel wide texture gets rounded to 1024, a substantial difference. Ventuz can not know this and reports the incorrect amount.
AV Inputs / Outputs
The states mean:
Movies
The states are:
The buffers show how many buffers Ventuz has allocated and how many frames in the future are available. If these buffers run dry, increase the number of buffers for that movie.
Logging
The console will work like a normal log file where messages printed will scroll endlessly.
This is useful to capture events and state changes.
Markup in Logging
The text-color can be changed with [tc:rgb] and [tc:rrggbb], where r, g and b must be replaced by web-style hex-colors. [tc:ff0000] would be red.
Logging Limits
Performance Measurement via Script
Logging
Performance Timing
using(Script1.MeasureCpu)
Example
Here is a complete example:
using System;
using Ventuz.Kernel;
using Ventuz.Kernel.Tools;
    private bool changed;
    public Script()
    public virtual void Dispose()
        changed = true;
    public bool OnEnable(int arg)
	return false;
	return false;
        if (changed)
            changed = false;
            return true;
        return false;
Scale To Preview
Interpreting the Performance Timing
The Relation Between Main Thread and CPU Percentage
Monitoring Movie Playback Performance
Why is my Audio Delay so big?
So for shortest delays:
Explanation of the Various Bars
Red(ish): Validation
Green(ish): Rendering
Blue(ish): Idle
Video Process:
Other
