  1. Ventuz Configuration
    1. Machine Selection
    2. Live Options
      1. Ventuz Options
    3. Rendering Options
    4. AV Options
    5. Ventuz Config
    6. Project Management
  2. Machine Configuration
    1. Interaction
      1. General
      2. Windows Touch
      3. TUIO
      4. Cluster Networking
      5. Output Scaling
    2. Remoting
      1. Remoting 2 (.Net)
      2. Remoting 4
      3. Miranda
      4. CLI Remoting
      5. OSC Remoting
    3. Extended
      1. Culture Settings
      2. WebBrowser Settings
      3. Process Settings
      4. Tracking System
      5. Timecode Settings
      7. System Monitoring Settings
    1. Render Pipes
      1. Stream Modes
      2. Preview
    2. Video Inputs
    4. Software Watchdog
    5. Software Keying
      1. SDI 3G
      2. 4k
    7. Comprehensive Audio Mixing
    8. Video Setup independent from Ventuz Scene
  4. AV Configuration
    1. Video Outputs
    2. Video Inputs
    3. Video Options
      1. Standard Options
      2. Advanced Options
    5. Global Options
    6. Live Status
    7. Audio Devices
    8. Cross Points
    9. Device Mapping
  5. Render Setup Editor
    1. User Interface
    3. Coordinate Space
      1. Bezel and Overlap
      2. Split and Combine
      3. Machine ID
    6. Keyboard Shortcuts
  6. Warping and Soft-Edging
    1. The Ventuz Shaping Engine
      1. Performance Considerations
    2. The User Interface
      1. Navigation
      2. Global Toolbar
        1. Test Patterns
      3. Editing the Grid
        1. Selection
        2. Editing
        3. The Side-Toolbar
        4. Zooming and Panning
        5. Handle Modes
        6. Insert Rows and Columns
      4. Manipulating Layers and groups
        1. Subdivision
      5. Soft-Edges
        1. The gamma values
        2. Automatic Mode
        3. Manual Mode
      6. Per Output Settings
Render Setup Editor
The Render Setup Editor is part of the Ventuz Configuration and is used to create an XML configuration for complex display walls. The content for such display walls may come from a single or from multiple Ventuz machines.
Generally speaking the Render Setup Editor is used to solve following problem: Display Ventuz content correctly on an arbitrary complex display wall built up of N displays connected to M machines.
The editor basically consists of three parts: the Toolbar on top with some edit commands, the Display Editor in the center to arrange machines and displays and the Statusbar at the bottom with some additional information for the selected object.
The display wall shown in the example consists of 4x3 displays and has a total resolution of 5120 x 2160 pixels. It is built from 3 machines: two machines have a 2x2 display setup, the third machine has a 4x1 display setup.
The dashed frame marks the visual border of the whole Cluster or Render Setup respectively. On top of this frame the visual resolution of the Cluster is displayed. (The Cluster always has the default name CLUSTER.)
The broad frame marks the visual border of one machine. Below this border the machine name, its visual resolution and its position is displayed (more details below)! Each display has its name written in the center; if a display is selected its coordinates are shown too. The name and the assigned color can be changed by editing the properties (CTRL + SHIFT + E or Edit properties in the toolbar).
The Toolbar at top of the editor contains several button. From left to right their functionality is as follows:
To create a new Render Setup launch the New Setup dialog. This can be done by pressing CTRL + N or clicking on the first button in the Toolbar. This will bring up the following dialog:
The New Setup dialog consists of two tabs: Simple and Advanced.
In Simple mode one has to specify the number of displays per machine, their arrangement and the resolution per display. Finally the number of machines has to be given. Clicking Create will arrange the machines from left to right in the Display Editor.
In Advanced mode first of all one specifies the display arrangement for the whole Cluster and the resolution per display. In Advanced mode it is possible to specify a Bezel or Overlap area for displays with frames or projectors. The unit of these values is pixels.
In the next step the total display arrangement must be distributed over a certain number of machines.
In the Machine section one has to specify the display arrangement per machine if there are multiple possibilities for the whole cluster with N machines.
Example: a cluster of 4x2 displays with 2 machines can be created from 2 machines with 4x1 displays aligned vertically or 2 machines with 2x2 displays aligned horizontally.
It is possible to create Bezel values from the physical dimensions of a display. To open this Bezel Helper dialog click on the button left to the bezel values.
From the display size with frame and without frame (only the visible pixel area) this dialog calculates the horizontal and vertical bezel values.
The maximum visual resolution for a Ventuz machine is 16384 x 16384 pixel!
Automatic Render Setup from VMS
There is an additional way to get an initial Render Setup if one creates a new entry in the Ventuz Configuration. The Ventuz Machine Service (VMS) is able to retrieve the display configuration from NVIDIA and AMD graphics cards. It reads the Mosaic or Eyefinity configuration and creates a corresponding display arrangement in the Render Setup editor.
For the example above the initial Render Setup from the VMS will look as follows:
As there is no information about the visual relationship of the machines to each other, they are arranged horizontally from left to right. To achieve the final result you just have to move the 4x1 machine to the bottom of the other two.
Coordinate Space
The machines and displays in the Render Setup Editor lie in a pixel-based coordinate space. The origin of this coordinate space is the top-left corner of the cluster bounding-box. The cluster bounding-box is the smallest bounding-box containing all machines. The X coordinate advances to the right; the Y coordinate to the bottom. Note that even if you move the whole cluster configuration to other coordinates than [0;0], it is reseted to [0;0] before it is saved to file. The position of the whole cluster does not affect the render output of Ventuz with the according Render Setup configuration
loaded! For a single machine Render Setup this coordinate space matches the coordinate space of a full-scene Viewport in Ventuz.
The origin of the world coordinate space in the according Ventuz scene is always in the center of the cluster bounding-box.
Logical vs. Visual Resolution
In the context of the Render Setup configuration we will talk about Logical and Visual Resolutions.
These terms will be explained here.
The logical resolution of a machine is defined by the Mosaic or Eyefinity configuration of the graphics board. A 2x2 display setup with a resolution of 1280 x 720 px per display has a logical resolution of 2560 x 1440 pixel.
The visual resolution however is defined by final position of the displays in the Render Setup configuration. In the example below the displays are arranged horizontally and have bezel between each other. This leads to the visual resolution of 5420 x 720 pixel.
Manipulating a Render Setup
Bezel and Overlap
It is possible to adjust the amount of bezel or overlap between displays interactively in the Display Editor. If multiple displays are selected a Shifting Frame is drawn around the selection. It has a handle on each side to change the bezel/overlap horizontally or vertically.
The values in the handles are related to the last selection and are reseted on a new selection. The display shifting can also be performed with the Arrow keys and a pressed Shift key! Double-clicking on a handle brings up a dialog to set the bezel/overlap values in pixel or in percent of the display size.
Split and Combine
Machines and Displays can be split into fragments to create complex display arrangements. The Split Dialog, which is available in the Context Menu or in the Toolbar, provides two splitting procedures. This is useful or even necessary for screens which have an internal daisychaining mechanism which allows you to link multiple screens from one output.
Split by Divide: The selected items are divided equally by the specified horizontal and vertical divisors. This splitting procedure works only if the division results in integer values!
Split by Fill: The selected items are split into parts of a specific size. If the initial item cannot be filled completely by the specified size, the remaining areas are assigned to a part of its own and can be deleted afterwards.
Split by Cut: The selected items are split by performing cuts from left, right, top and bottom according to the specified values. If all four values are larger than zero the split will result in nine items.
Split machine or display parts can be combined again if they have the original relation of proximity and the selection is a rectangle. The Combine command is available via Context Menu or keyboard shortcut CTRL + SHIFT + C.
Machine ID
The machine ID makes sure that a Ventuz scene can determine which part of an overall cluster content should be rendered. Currently the machine IDs are assigned automatically. If a new machine is added to an existing Render Setup configuration the smallest free ID is taken. In the actual version it is not possible to assign a custom ID to a machine. If this is necessary, you have to edit the Render Setup XML file (.vrs).
View
middle mouse button drag Pan
middle mouse button wheel Zoom
middle mouse button double-click Reset Pan an Zoom
CTRL + F Zoom to Fit
CTRL + R Reset Zoom
Selection
left mouse button click Select
left mouse button click+drag Rectangle Selection
right mouse button click Context Menu
CTRL left mouse button click Single SelectionSelect parent item
CTRL left mouse button click Multi SelectionAdd/Remove to/from selection
Editing
SHIFT left mouse button move Move selection without snapping
CTRL + N Create New Setup
CTRL + Z Undo
CTRL + Y Redo
CTRL + + Add Machine
DELETE Delete Selection
CTRL + SHIFT + E Single Selection Edit properties
CTRL + SHIFT + S Split Selection
CTRL + SHIFT + C Multi Selection Combine Selection
CTRL + SHIFT + R Reset selection
, , , Move selection by 10 pixel
CTRL + , , , Move selection by 1 pixel
SHIFT + , , , Change distance by 10 pixel
CTRL + SHIFT + , , , Change distance by 1 pixel
