  1. Ventuz Configuration
    1. Machine Selection
    2. Live Options
      1. Ventuz Options
    3. Rendering Options
    4. AV Options
    5. Ventuz Config
    6. Project Management
  2. Machine Configuration
    1. Interaction
      1. General
      2. Windows Touch
      3. TUIO
      4. Cluster Networking
      5. Output Scaling
    2. Remoting
      1. Remoting 2 (.Net)
      2. Remoting 4
      3. Miranda
      4. CLI Remoting
      5. OSC Remoting
    3. Extended
      1. Culture Settings
      2. WebBrowser Settings
      3. Process Settings
      4. Tracking System
      5. Timecode Settings
      7. System Monitoring Settings
    1. Render Pipes
      1. Stream Modes
      2. Preview
    2. Video Inputs
    4. Software Watchdog
    5. Software Keying
      1. SDI 3G
      2. 4k
    7. Comprehensive Audio Mixing
    8. Video Setup independent from Ventuz Scene
  4. AV Configuration
    1. Video Outputs
    2. Video Inputs
    3. Video Options
      1. Standard Options
      2. Advanced Options
    5. Global Options
    6. Live Status
    7. Audio Devices
    8. Cross Points
    9. Device Mapping
  5. Render Setup Editor
    1. User Interface
    3. Coordinate Space
      1. Bezel and Overlap
      2. Split and Combine
      3. Machine ID
    6. Keyboard Shortcuts
  6. Warping and Soft-Edging
    1. The Ventuz Shaping Engine
      1. Performance Considerations
    2. The User Interface
      1. Navigation
      2. Global Toolbar
        1. Test Patterns
      3. Editing the Grid
        1. Selection
        2. Editing
        3. The Side-Toolbar
        4. Zooming and Panning
        5. Handle Modes
        6. Insert Rows and Columns
      4. Manipulating Layers and groups
        1. Subdivision
      5. Soft-Edges
        1. The gamma values
        2. Automatic Mode
        3. Manual Mode
      6. Per Output Settings
High-end projectors often have hardware to do this, but sometimes this is insufficient or comes with an inefficient user interface.
So to summarize:
Totally disabling shaping is of course the fastest.
Soft-edging will impact the speed of Ventuz only a little, and that impact is independent from the number of edges. Only while changing the edges with the editor, recreating the edge-texture might be noticable of course.
Shaping with the Ventuz Designer
When running the Ventuz Designer instead of the Ventuz Presenter, shaping is only active when the Production Preview mode is enabled.
The User Interface
  1. Toolbar for global tools
  2. Toolbar with control-point related tools
  3. Output (projector or other display) navigation
  4. Switch between output settings, warping and soft-edging
  5. Group and layer navigation
  6. Group and layer related properties
  7. Toolbar with group and layer related tools
  8. Grid Editor
Many operations have keyboard shortcuts, so most of the work can be done without looking at the user interface on your computer monitor, but at the outputs directly. These shortcuts will only work if the grid editor (8) has the keyboard focus. When it has the focus, an orange border is displayed around the grid editor.
The output navigation (3) displays a schematic view of the outputs. It will not try to faithfully represent the actual size and position of the displays, but indicates the general layout, like a subway map will not represent the actual distance between stations. For instance overlap is not shown here.
To change the current output, either click or click and drag in this area. When the grid editor has focus, use cursor + alt keys to change the current output.
The area marked with (4) can be used to switch between warping and soft-edging The output section contains color correction and other per-output settings.
Global Toolbar
These settings will effect the presenter / cluster even after the render setup has been left:
Nr Name Description
1 Enable warping If this is disabled, the whole warping engine is disabled
2 Enable soft-edging Disable only soft-edging. Usually one would switch off the edging until warping is done.
Nr Name Description
3 White background Fill the unused pixels of an output with white instead of black. This shows how many pixels are wasted because of the warping.
4 Highlight overlap areas Sometimes it is useful to highlight the areas where the outputs overlap because precise warping here is especially important.
5 Cut soft-edges This will cut the soft-edges in a way that the output of the two sides directly touch but not overlap. This is useful to check how well the outputs match colors. This requires that the warping has been done already.
6 Darken rendering / test image Sometimes the user interface overlay is hard to see over a bright rendering or test pattern. This button will darken the background to remedy this.
7 Solo Mode Like in an audio mixer, this disables all other outputs. Useful when there is confusion which output contributes to what. Also the test pattern will center to the solo output.
12 Show keyboard shortcuts Most users prefer to do as much as possible with keyboard alone. This option aids in memorizing the keys.
13 Screen GUI options Control extent and size of the user interface HUD provided on the outputs.
Nr Name Description
8 Enable test pattern Enable test pattern. In the editor, the test pattern is always shown. The presenter can show either test pattern or the Ventuz scene.
9 Multiply output color Each output is assigned a color. This will multiply the test pattern foreground color with the output color. If good colors are assigned to the outputs, this helps to identify outputs and figure out which of two overlapping outputs needs warping and which is correct.
10 Select test pattern There are many useful test patterns programmed already. If they are insufficient, user images can be used as test patterns.
11 Test pattern options Most test patterns have a range of options to configure the width and distance of lines, or the colors.
Test Patterns
Most test patterns offer a foreground and a background color. Also each output can be assigned a color. By pressing the Multiply output color icon in the global toolbar, the foreground color will be multiplied with the output color. For this to work it is best to choose a bright color as foreground color.
By default grid and checker test patterns will not perfectly fit, the last row and column will be cut off. By pressing Fit corners, this will be corrected, at the price that the aspect ratio is not guarantied to be 1:1.
The image test pattern allows you to specify a directory that contains any pictures you prefer as test patterns. It is important that all presenters in a cluster and the computer that runs the shaping editor have the images at the exact same path. Using a network share is the simplest way to ensure this. If the image could not be loaded, a dummy image with color gradients is generated.
Editing the Grid
Selection
To select points, left-click on them. Pressing shift while doing so will add to the selection. When clicking besides the points, a rectangle is drawn as the mouse moves, and the points in the rectangle are selected. Again, pressing shift while doing so will add to the selection.
Pressing A + control will select all points, D + control deselects all points except the control point where the cursor is. The cursor can not be hidden and the control point at the cursor is always selected.
In addition to the primary control points at the cross-sections of the grid, there are control handles for finer control over the mesh. These are only visible, and can only be clicked on, when the associated primary control point is selected.
When working with the keyboard, using the cursor keys will move the cursor, and the cursor is also selected. Pressing 'b' will enter box-selection mode, again use the cursor to change the box size. To move the cursor to a control handle, use cursor keys + control.
Editing
The control points can be moved with the mouse just as they are selected, that is left mouse button or left mouse button + SHIFT. Holding CTRL while moving the mouse will limit the movement to either the x or y axis. This works by pressing CTRL before or after clicking left mouse button. To move the points with the keyboard, use the Cursor keys + SHIFT.
For a warping layer, there is a way to move a control point without warping the image. This allows to move a point to a feature of the projection screen, and warp from there. With the mouse, use right mouse button + CTRL. With the keyboard, use Cursor + SHIFT + CTRL.
Here a summary:
Mouse Keyboard Description
Cursor select point
SHIFT Cursor move selected points
left mouse button click on point select only this point, then move
SHIFT left mouse button click on point add point to selection, then move
CTRL left mouse button click move only horizontally or vertically
left mouse button click not on point B, then Cursor box selection
CTRL right mouse button click CTRL Cursor move without warping
middle mouse button click pan
middle mouse button wheel zoom
The Side-Toolbar
Nr. Keyboard / Mouse Descriptions
1 Insert row (right of cursor)
2 Insert columns (below cursor)
3-7 A U K L S Handle Modes, see below
8 X Reset selected points to default position
9 CTRL-Z Undo
10 CTRL-SHIFT-Z or CTRL-Y Redo
11 middle mouse button wheel up Zoom in
12 R Reset zoom and pan
13 middle mouse button wheel down Zoom out
Zooming and Panning
Handle Modes
Name Color Shortcut Description
Linked Green A Both sides have same direction and stretching
Straight Yellow U Both sides have same direction, but can be stretched differently
Unlinked Red K Both sides are completely independent, allowing for kinks and different stretching
Linear Pink L Handles are automatically calculated for linear interpolation
Default Brown S Handles are automatically calculated for maximum smoothness
With most modes, the change of a handle is local and effects only the area of the surrounding 3x3 control points. In default mode, the change effects a 5x5 surrounding. This mode is useful for the 2x2 and 3x3 layers where this does not matter.
Please note that the handle modes are changed by this action: when inserting a single row into a 5x5 grid, the distances between the rows is different and the linked handle mode can not be used any more, it is automatically changed to straight where that is required.
  1. Adds a new group. There can be only one warping group, but multiple soft-edging or masking groups.
  2. Adds a new layer. If the new layer is finer than the finest layer, it will become the new finest layer. Some editing done to the finest layer may be lost. It is best to subdivide the current finest layer once substantial editing has been done.
  3. Allows to rename the layer.
  4. Removes the selected group.
  5. Removes the selected layer. If the layer is not the finest layer, no editing is lost by this, as the finest layer holds all the information for creating the mesh.
  6. Reverts the whole group to default.
  7. Creates all soft edges, or reverts them to default when they already exist. Press this when the overlap has been changed in the render setup.
Subdivision
By pressing the '+' icon in the layer navigation, the finest layer can be subdivided in X, Y or both. This will insert a row and / or columns between every existing pair of rows / columns: a 5x5 point grid turns into a 9x9 point grid.
As 33x33 is the finest allowed layer, any layer with more than 17 points either horizontally or vertically can not be subdivided any more.
Soft-Edges
The gamma values
  1. Apply the white spline
  2. Apply the separate red / green / blue splines
  3. Apply the gamma value
  4. Apply the separate red / green / blue gamma values
Automatic Mode
Manual Mode
In manual mode, only one edge can be edited at time.
Per Output Settings
Name Description
Gain For color correction, a value that is used to multiply the rendering pixels
Lift For color correction, a value that is added to the rendering pixels, before contrast is applied
To change all 3 (red, green and blue) sliders at the same time, press the alt key while dragging with the mouse. This will change the color values while trying to preserve the ratios between the colors, so brown will always stay brown and not become more and more pale-white as values increase.
The Quality section mainly controls how fine the warping mesh is to be tesselated. The defaults are set for quite high quality, when using more precise values you should check for wasteful over-tesselation with the Show Wireframe option.
Name Description
Max Level Maximum subdivision when creating the mesh from the finest layer
Position Error Acceptable difference for the vertex positions between perfect Beziér interpolation and the actual mesh, in pixels
Mapping Error Acceptable difference for the UV mapping between perfect Beziér interpolation and the actual mesh, in pixels
Ramp Error Acceptable difference for ramp colors between perfect Beziér interpolation and the actual mesh, in color values ranging from 0 to 255
Dither Mode Enable dithering to improve ramp quality. Temporal dithering will change the dither pattern every frame, that usually gives better results but may result in undesirable artifacts.
Show Wireframe Shows the wireframe of the warping mesh. Useful for checking if the level of subdivision is reasonable or insane.
