Distortion effects generally move pixels or their color values to another position, depending on different parameters. Most importantly you can find Lens Distortions here to cancel out any artifacts coming from camera lenses. This page works as a reference for this kind of effects.
A standard 2D displacement effect, it displaces the Image or Layer pixels according to the Luminance information of an external image or Movie file. Due to this, it is always a good idea to use a very contrasted image to see the effect to its full strength. Generally a Black Texture will move the pixels to the top left while a white texture will move them to the bottom right.
This effect allows for tiling the rendering, making it repeat itself. By using the following parameters:
The OpenCV Lens Distortion effect supports the full OpenCV distortion model. The inputs correspond to the outputs coming from cv::calibrateCamera (https://docs.opencv.org/3.4/d9/d0c/group__calib3d.html#ga3207604e4b1a1758aa66acb6ed5aa65d) and cv::calibrationMatrixValues (https://docs.opencv.org/3.4/d9/d0c/group__calib3d.html#ga87955f4330d5c20e392b265b7f92f691) in the following way:
