| View | ||
| drag | Pan | |
| wheel | Scroll vertically | |
| CTRL wheel | Scroll horizontally | |
| Selection | ||
| click | Node | Select Node with children |
| CTRL click | Node | Add Node without children |
| SHIFT click | Node | Add Node with children to selection |
| CTRL + SHIFT click | Node | Add Node without children to selection |
| UP | selected Node | Select upper sibling Node |
| DOWN | selected Node | Select lower sibling Node |
| LEFT | selected Node | Select parent Node |
| RIGHT | selected Node | Select first child Node |
| Editing | ||
| CTRL + X | selected Nodes | Cut selection to clipboard |
| CTRL + C | selected Nodes | Copy selection to clipboard |
| CTRL + V | selected Node | Paste from clipboard below |
| CTRL + V | no selection | Paste from clipboard |
| CTRL + P | selected Nodes | Duplicate selection |
| CTRL + SHIFT + P | selected Nodes | Duplicate selection and keep sources |
| DELETE | selected Nodes | Delete/Unlink selection |
| SHIFT + DELETE | selected Nodes | Unlink selection |
| click hold | Node | Show context menu |
| click | Node | Collapse/Expand children |
| CTRL + L | selected Nodes | Collapse/Expand children |
| CTRL + A | selected Nodes | Toggle Inactive state |
| CTRL + B | selected Nodes | Toggle Blocked state |
| CTRL + R | selected Nodes | Set Render Point |
| Naming | ||
| double | Node | Edit name |
| F2 | selected Node | Edit name |
| ENTER | name editing | Confirm name edit |
| ESC | name editing | Cancel name edit |
| Annotations | ||
| CTRL + E | selected Node | Edit Node Annotation |
| CTRL + E | no selection | Edit Container Annotation |
| double | Annotation | Edit Annotation |
| drag | Annotation | Drag Annotation |
| drag | Annotation border | Resize Annotation |
| ESC | Annotation editing | Cancel edit |
| click anywhere | Annotation editing | Confirm edit |
| click | Annotation X | Delete Annotation |
| empty annotation | Annotation editing | Delete Annotation |
| Containers | ||
| double | Container arrow | Navigate into Container (down) |
| click Navigate Next | over Container | Navigate into Container (down) |
| click | over Container | Navigate into Container (down) |
| CTRL + D | selected Container | Navigate into Container (down) |
| double | Container root | Navigate one Container level up |
| click Navigate Back | free area | Navigate one Container level up |
| CTRL + U | Navigate one Container level up | |
| click | free area | Select current Container |
| click | free area | Show Container overview |
| CTRL + M | selected Nodes | Merge selection to new Container |
| CTRL + SHIFT + L | selected Container | Seal/Unseal Container |
| CTRL + SHIFT + X | selected Node | Expose Icon to upper level |
| Drag&Drop | ||
| drag | selected Nodes | Drag selection |
| drag | selected Nodes | Drag selection special |
| Drag&Drop Hierarchy Nodes from same or other Scene, Repositories or Toolbox | ||
| drop | Drop-Target (arrow) | Copy/Move |
| drop | Interface Container | Exchange if dragging an Interface |
| drop special | Drop-Target (arrow) | Special operation |
| SHIFT drop | Drop-Target (arrow) | Move |
| CTRL drop | Drop-Target (arrow) | Copy |
| CTRL + SHIFT drop | Drop-Target (arrow) | Link |
| CTRL + ALT drop | Drop-Target (arrow) | Reference Copy |
| All drop operations for Nodes allow to stamp Nodes to the drop target multiple times by clicking while holding | ||
| Drag&Drop Properties or Methods from Property Editor | ||
| drop | Node | Show sources popup (Binding) |
| hold hover | Node | Select Node |
| hold hover | Container arrow | Navigate into Container (down) |
