Machine Configuration
  1. Ventuz Configuration
    3. Machine Selection
    4. Messages
  2. Status
    1. General
    2. Cluster Status
    3. Logs Quick access
  3. License
    1. License Manager
  4. General Configuration
    1. Overview
    2. Group Selection
  5. Machine Configuration
    1. General
    2. Remoting
    3. DMX
    4. Extended
  6. Device Configuration
    1. General
    2. Video
    3. Touch
    4. Tracking
    5. Audio
    6. Pipe Mapping
    7. Preview Window
    1. Project Management
  8. Live Control
    1. General
    2. Scene Control
    3. Project Data
    4. Live Options
    5. Diagnostics
    6. Stream Out Viewer
The Machine Configuration defines common settings that are not changed very often. Different configurations can be activated and edited in the overview window. The Machine Configuration file extension is .vmc.
Remoting 4
Miranda
CLI Remoting
Deprecated
The Command Line Interface (CLI) is a very simple TCP text based interface to control very simple actions in Ventuz Runtime. This protocol still exists in Ventuz 8 but does not support the entire set of functionality (such as Template Engine, Live Option, etc). It is recommended to use Remoting 4 for new client applications. Ventuz Director uses Remoting 4 as well.
OSC Remoting In
EnabledEnables the OSC remoting in interface.
PortDefines the UDP/IP port to use for receiving OSC messages.
Multicast AddressIf specified, the OSC Remoting listens to a UDP Multicast group. If left blank, UDP Unicast is used.
OSC Remoting Out
EnabledIf enabled, externalized events are sent as an OSC message.
PortDefines the UDP/IP port to be used for sending events.
Multicast AddressDefines the UDP/IP address to be used for sending events.
DMX
General DMX settings
Receive project dataEnables the DMX Support for the Project Data Channels
UniverseSets the DMX universe the Project Data listens to.
ChannelSets the BaseChannel for the universe configured above.
Art-Net
Enable Art-Net Sets up the Art-Net driver.
Network Address / Netmask Specifies the network used for Art-Net.
Unicast Destinations When Unicast is set as DMX send mode, the IP Addresses in this list will be used.
DMX send mode Newer versions of Art-Net support auto detection of connected devices, older do not. The preferred send mode setting is Auto: Ventuz registers itself in the network as Art-Net node and automatically finds other nodes to send to. If that does not work because there are unsupported nodes in the network, the send mode can be set to either Broadcast - to broadcast the DMX data to the network - or Unicast to send the data to all IP Addresses in the list below.
Limit rate to DMX The original DMX protocol is a serial bus, which usually can not transfer more that 40 updates per second over the cable. With network based protocols like Art-Net Ventuz can update data at full frame rate. Especially older Art-Net to DMX interfaces are struggling with high data rates. Limit rate to DMX restricts Ventuz to a maximum of 40 DMX data updates per second. It will be a multiple of the frame rate.
Art-Net net / Subnet Art-Net specification separates the universes into 128 Nets, 16 Subnets and 16 Universes. Net and Subnets are specified in this setting. Ventuz then offers up to 256 input and output universes.
Unused Channels This setting specifies if unused output channels output 0: Black Out, or the last set value: Keep Last.
sACN
Enable sACN Enables sACN support.
Send Mode sACN is capable of configuring itself. It only demands the network to allow multicast, which is common nowadays. Multicast is the preferred setting - no further network setting are needed. In special cases, Unicast can be used to send DMX packets to specific destinations.
Unicast Destinations When Unicast is set as Network mode, the IP Addresses in this list will be used.
Input / Output Universe sACN supports up to 63999 universes. The Universe determines the start universe to be used, the Count determines how many consecutive universes are used. In Ventuz, universes mapping starts at 0, so the sACN start universe will be mapped to 0. Exception: When Art-Net and sACN are enabled the same time, sACN universes start at 16, as the first 16 universes are used by Art-Net.
Synchronize Outputs With this option enabled, a synchronization packet is send after the data is send. This will tell connected devices to update all received data at once instead of one universe after the other. This is useful especially for bigger LED panels where the received data span across multiple universes but actually represents one image.
Limit rate to DMX See Art-Net
Unused Channels See Art-Net
Extended
Culture Settings
High Quality 2D TextEnables high quality, resolution independent 2D text rendering for the costs of performance. See Text2D
Character SetsSelects the Unicode ranges to be used when using Font and Typefaces.
Timecode Settings
Timecode Format Specifies the string formatting for timecode properties in Ventuz Designer/Runtime
Progress Visualization Settings
Color Encoded by Machine ID Choose whether the squares and the line are colored according to the machine id or not.
Logging Settings
Log Write Level Specifies the maximum log level of messages that are written to file. The level order is Debug > Info > Warning > Error > Fatal > None!
Log File Options Specifies if logging should be appended to an existing file or if a backup of an existing file should be created. In the backup case the maximum number of backup file can be specified. If files exceed this number the oldest backups are deleted.
  • Ventuz Configuration
  • ​TUIO
  • ​Open Sound Control
