![]() | Touch Translation | Single touch gesture to translate an axis. |
![]() | Touch Rotation | Single touch gesture to rotate around an axis. |
![]() | Touch Orbit | Single touch gesture to rotate around multiple axis at the same time. |
![]() | Touch SphereOrbit | This is a more specialized version of the Touch Orbit node intended for spherical displays and other Globes. |
![]() | Touch Transformation | Two-touch gesture to translate, rotate and scale at the same time. |
![]() | Touch Transformation 3D | Two-touch gesture to translate, rotate and scale at the same time - especially built for use in VR. |
These four interaction nodes form the set of transformation gestures. They operate in an object-based fashion so to activate them a touch has to hit a mesh/font/volume that is part of the subtree spanned by the interaction node. At first glance it might seem an unnecessary duplication to have dedicated translation and rotation nodes when the Touch Transformation can handle all of these transformations. However, they all are custom tailored to special use cases and achieve different effects.
Use for: Slot machine style wheels, volume knob style elements, steering wheel, ...
Use for: Product presentation, earth globes, ...
The Touch Orbit node enables the user to rotate in multiple axis at the same time. A vertical movement of the touch will tilt the object where a horizontal movement rotates the object around its Y-axis. One particularity of this node is that the tilt is always done by rotating the X-axis of the gesture, not object space. This has the effect that while rotating the object, the tilt is always constant with respect to the viewer. It is thus ideal for doing a product presentation or any other situation where the user should be able to tilt the object but nonetheless be unable to look under the object. In addition, the object can be scaled by doing a two finger pinch/stretch.
The rotation is measured in degree Azimuth and degree Inclination, the former being the rotation around the Y-axis of the object and the latter the amount of tilting. Both these values as well as the amount of scaling can be restricted by using the respective Limit properties.
LimitActive activates all limits at the same time. If only a selection of properties should be restricted, simply set the other limit properties to very large values like plus and minus ten to the power of thirty.
Due to numerical reasons, the Inclination is restricted from -90 to +90 degrees even when the LimitsActive property is false. This also avoids that the object ever is upside-down.
It differs in tracking, coordinate system and filtering:
When a touch starts, the point on the 3d mesh that is hit is remembered, and when moving the finger around the object is rotated in such way that the finger will always "stick" on the original hit location. If the finger moves outward so that the object can not be rotated in such way, the interaction stops.
The old orbit node would translate any movement in X or Y to rotation around those axis, which is more useful for small objects that one wants to rotate fully around.
There are 3 RotateModes
Default: Use one finger to rotate.
LockPole: Use one finger to rotate, but lock the north-south axis.
TwoFingerRotate: Allow two finger gesture to rotate. This may be problematic on large globes with noisy input, so it is not the default mode.
When not using LockPole, the north-south axis will become quickly misaligned, which might be a problem for your presentation. There is a normalization feature to re-align the object:
NormalizeDelay : a delay in seconds when the normalization kicks in, set to 0 to disable.
NormalizeSpeed : the speed at which the node rotates to re-align.
This node reports rotation as longitude and latitude, which is more useful for dealing with geo-coordinates than the azimuth / Inclation model used by the old orbit node
Touch input goes through some custom filtering that is unique to this node. The steps are, in this order:
ThresholdAngle: any input smaller than this angle is ignored. This can be used to filter noisy input.
Delay: Input is delayed by this many seconds. This is very effective at filtering stuttering input. This works by remembering the last time the touch stopped moving - after thresholding. Then the object is rotated from the old position where it was when touch stopped changing to the new position where is should go over the specified time, with a simple ease-out. While touching continously, it moves to the new position at a speed matching the behavior for a touch that has stopped moving.
Damping: A simple low pass filter to be used during the interaction.
Inertia: A simple low pass filter that is used after the interaction. Set to 0 to stop the orb immediately after interaction. This will override damping after interaction, but even with inertia disabled the delay feature will still work.
Delay and Damping will ensure that eventually the object will be rotated such that the hit point is exactly under the finger, if possible, within the accuracy given by the threshold angle. Inertia will rotate the object beyond that point.
ThresholdAngle and Delay work together very well, as thresholding can introduce stuttering for slow movements and Delay is very good at filtering that away.
Suggested Values:
The current rotationis given as Longitude and Latitude, or in matrix form as World.
For debugging, there are the output properties TouchLongitude and TouchLatitude that hold the last intersection before any filtering. It can be useful to bind a marker to test Touch when installing a system.
The enabled property ApplyTransformationCenter makes sure that rotation and scaling is applied to the center of the two touches. If it is disabled the transformation is applied to the center of the object.
Use for: Full transformation of objects in 3D space with VR Controllers; free rotation in 2D screen mode.
This node is an extension of the Transformation and Orbit node to provide full transformation in 3D space (e.g. Virtual Reality). With an appropriate controller it is possible to translate objects on all three axes. Additionally a free rotation is implemented and scaling with a second touch provider (second controller or two fingers in screen mode). The rotation is based on Quaternions and allows a free and intuitive rotation of objects. But this technique also implies that it is not possible to limit rotation on the XYZ axes. It is only possible to disallow the complete rotation via the DisableRotation property.
In 2D screen mode this node behaves slightly different than the Transformation and Orbit node:
All these nodes can be reset to specific values. This means that their transformation outputs can be overridden from the according input properties. All node have the following Reset parameters in common: ResetOnLoad specifies if the transformations should be reset if the scene is loaded. The ResetAnimation property determines how the reset should be performed. All standard easing function known from the Ease Node are available. The duration of this transition can be controlled by the ResetDuration property. Set ResetDuration to zero seconds to let the reset jump to its specified values. The ResetPolicy flags control if reset can be performed if a touch is active and if an object can be touched during a reset animation.
