Performance Statistics and Diagnostics
  1. Statistics Options
    1. Performance
    2. System Information
      1. Node Limit
    3. GPU Basic Statistics
    4. GPU Advanced Statistics
    5. Video Phase
    6. Output Information
    7. Custom Postprocess
    8. AV Inputs / Outputs
    9. Movies
    10. Tracking
    11. Layer Processing
    12. User Log
    13. Watches
    14. Label Outputs
    15. Detailed Frame Timing Debug
    16. Average Timing
    17. Force GPU Stall
      1. History Mode and Pause
      2. Interpreting GPU Measurement
      3. Accumulated Bars Versus Detailed Timeline
      4. Performance Impact of Measurement
    18. Scale To Preview
    19. Stats that may slow rendering
    20. Clear Timing Debug
    21. Resync Swap Queues
      1. Per Output Stats
  2. Logging
    1. Markup in Logging
    2. Logging Limits
  3. Performance Measurement via Script
    1. Logging
    2. Performance Timing
    3. Example
  4. Interpreting the Performance Timing
    1. The Relation Between Main Thread and CPU Percentage
    2. Monitoring Movie Playback Performance
    3. Why is my Audio Delay so big?
  5. Explanation of the Various Bars
The performance statistics is a display rendered above the Ventuz output. It can be enabled from the Designer or the Diagnostics tab inside the Configuration editor to analyze performance problems in a scene. The Diagnostics are a bit slimmer in there functionality then the Performance Statistics, but these are also accessible remotely using our Web-based Configuration Editor.
Configuration Editor:
Designer:
Statistics Options
The performance statistics contain a lot of information. In many cases displaying it all can be a bit overwhelming and requires a lot of screen real-estate. So individual sections can be enabled and disabled and with the Frame Count the amount of visible frames can be adjusted.
Performance
In general:
  • Bright bars near white represent windows overhead in designer and runtime.
System Information
Node Limit
Cores:Number of shader cores are reported by vendor specific API. This number may be incorrect for some architectures and is only used to give a rough estimate on how powerful a GPU is.
Group Granularity: Number of shader threads that are guaranteed to run in lockstep. Usable for shader optimizations.
Tex: Memory used in textures, excluding color and depth buffers.
Color/Depth: Memory used for rendertargets and depth buffers.
Geo: Memory used for vertices and indices of meshes.
Buffers: Memory used for buffers. Buffers are used for instance in the particle system.
Particles: Shows how much particles, either as a sprite or mesh, are calculated every frame. High numbers can impact the performance of your scene drastically. Generally speaking meshes are impacting performance more then sprites.
Creation Calls: Are an exceptionally expensive part of the DirectX API and should only happen during scene loading.
Shader: Shows the currently cached and compiled shader number.
Persistent Resources: are resources that accumulate and are never deleted until Ventuz is quit. VertexFormats and VertexConverters are cheap internal resources that should stay below 25. Shaders is the number of different shaders that have been used since Ventuz started.
Video Phase
The Video Phase will give you detailed information about the health of all current outputs.
1: The star * indicates which output is used as timing ressource for the Ventuz clock. A SDI output has highest priority, followed by a GPU output (except Preview window). Shared Surfaces or NDI has the lowest priority. The Preview Window is only used, if there is no other output.
The ! exclamation mark indicates the output which has focus currently.
The first letter code indicates what Ventuz has set:
  • 'w' floating window
  • 'f' fullscreeen desktop rate
  • 'X' fullscreen exclusive
  • 's' swap sync
  • 'o' SDI / NDI / other (that dont have a window)
  • 'r' preview window
Everything after that will show the output mode:
  • fse : (medium) full screen exclusive - fullscreen in exclusive mode, changes on the output needs to re-initialize outputs, results in flickering on outputs.
  • fso : (good) full screen optimizations - borderless window promoted to fullscreen. We recommend using fso mode; this mode works best with multiple outputs and their synchronization.
  • dwm : (bad) display window manager - composition. synchroneity not guaranteed
  • blt : (bad) some other path
The following situations will always be "dwm" and should not be considered a problem:
  • floating window outputs
  • runtime preview window
  • designer preview window, unless switched to fullscreen (which will be of the fso kind).
2: Shows the current framerate the Output is using in Hertz.
3: Currently rendered resolution of that output.
4: The orange bar shows the shift of the video phase in percentage compared to the output with 0% shift. The values afterwards represent the shift in whole frames and partial numbers.
Queues are represented in different colors depending on there sync status:
  • Green = queue has the optimal number of frames
  • Red = Queue is buffering too many or too few frames - there might be a frame offset on the output
  • Gray = optimal number of frames not available. This information is only available for fullscreen modes and certain SDI vendors(Deltacast and Blackmagic). For instance it is not available for NDI streams.
Note: For some devices like GPU outs in fullscreen exclusive or specific SDI boards, this indication might not be correct. 5: Output device name and output number / output name
Output Information
Composition: Shows the currently rendered Composition.
Screens: Currently rendered Screen(s).
Outputs: Used GPU's for the current rendering.
Render: Shows the current number of render steps more complex scenes will show a higher number.
  • Active: Shows the currently rendered resolution.
  • Total: The size of the renderer window which could be rendered.
These resolution numbers will be bound to your Render Setup when using only the Runtime, previewing the "Design Preview or enabling "Screens and Outputs without Scaling". Only the other previews inside the Designer are dynamically changing it to save performance!
Blitslow/Blitfast:
  • Blitfast copies the whole screen 1:1
  • Blitslow can cut parts of the source and copies to parts of the destination, potentially with scaling and rotation, therefore slower. Slow does not mean really slow, it just means a bit slower.
Custom Postprocess
Shows the status and debugging information of the Custom Effect Shader node. If the shader fails to compile, information from the compiler are displayed with the line number. It also shows warnings/errors of the input comments parsing from Ventuz side.
AV Inputs / Outputs
The states mean:
  • Running: stream is running
Movies
The states are:
  • error: the stream failed
  • busy: Internal operation
  • empty: No file was loaded
  • loadmeta: loading metadata
  • loadinfo: prepare playback
  • active: normal playback
  • pause: playback is paused
  • seek: seeking
The buffers show how many buffers Ventuz has allocated and how many frames in the future are available. If these buffers run dry, increase the number of buffers for that movie. At the end of each line you can see the exact Cluster Clock when each Movie Started. Like the lead this is mainly useful to check syncronization of movies in a cluster. Next, Ventuz indicates with NVDEC if it uses the hardware decoding on the GPU and the used color space for the file.
Tracking
Layer Processing
Each line represents:
  • rendering a scene
User Log
Shows the messages coming from the Log Node.
Watches
Label Outputs
Use this option to identify which output is using which GPU and which connector.
GPU's are counted as an array starting with GPU 0 and connector 0. For example a scene rendered on GPU 0 using the third connector would read GPU 0:2.
These can also differ depending on what they are currently rendering. Preview windows will always show the "Preview" flag.
Detailed Timing Header
TIMING :  00:01:29:42 0005382 : +007 Drift, 258 drops, 257 multi frame drops, 4 drop clusters, 0 Resoft, 0 Resyncs, 3 Disjoint, sr
Flip-Queue Histogram : 0:0 1:10 2:6 3:0 4:0 5:0 6:0 7:0 unchanged:4475 noinfo:2
  • Drift : difference of the frame counter from the main display and the cluster clock. This is reset when the machine starts and the first time it is corrected by a network cluster clock. This allows to monitor how machines in a cluster drift apart - if they are not correctly synchronized.
  • drops : total frames dropped
  • multi frame drops: When dropping more than one frame, this counts this as a single drop
  • drop clusters : all drops within 30 frames are counted as a "drop cluster", so that something like a "double-stutter" is counted only once. Often operating system activities are cause of such drop clusters.
  • Resoft : "Soft Resync Queues" event, see below.
  • Resyncs : "Resync Queues" event, see below
  • Disjoint : "Disjoint Timestamps" event, see below.
  • the letter 's' or '-'. Send ClusterClock. Indicates that the local timing is considered stable enough to send the cluster clock to other machines. During resync events or changes in the swap-queue the cluster clock is not send so to not confuse other machines
  • the letter 'r' or '-'. Receive ClusterClock. Indicates that the local timing considered stable enough to receive the cluster clock from another machine.
Flip-Queue Histogram:
Analyses the queues of all outputs, and every frame it logs the most empty swap-queue. This allows to detect performance issues before a frame visibly drops: Especially if you configured a few extra buffers, you can see the queue decreasing in length without getting empty. This is an indication how "safe" you are running.
  • unchanged : The same as last frame or better (more entries in the swap-queue). Only changes for the worse are reported
  • noinfo : We could not get information from the operating system. Microsoft comments "Statistics are not reliable in many multiple monitor scenarios, as well as scenarios where other fullscreen apps are running." - which is not very helpful.
  • 0..9 : the counter is increased when the swap-queue gets worse (emptier) than last frame. The information is taken after a new frame is added to the queue, so it should never be empty.
When running in the designer with render window and physical outputs, the render window will not be included.
Interpreting the Histogram:
If you see the slot "1" going up, you are having visible drops or are very near to dropping. Increases in higher slots should not be visible drops but temporary situations where rendering was slow but still some frames queued up for display, so no visible drop. By adding more extra-buffers things should shift to the safe side, at the cost of increased latency / lag. A good situation would be by adding two extra buffers, seeing the "1" and "2" slots at zero and the "3" slot showing some increases. You are running fine.
Detailed Timing Events
In addition to the header, the detailed timing will log events, basically whenever something went wrong.
Logs entries start with a timestamp:
WED-14:14 00:00:00:31 0000031
Day of week, Hour:Minute of the day, cluster-clock as timecode (HH:MM:SS:FF), Cluster-clock total.
  • (+001) : dip 3 Queues 3 4 : one of the queues was not full, no drop
  • (+003) : Queues 1 2 : one of the queues was empty, visible drop.
The number in brackets is the number of frames that should have passed. +1 is normal, +3 indicates that 2 frames were dropped.
  • Disjoint Timestamps : Timing information from GPU is unusable. In the past this happened when GPUs change their clock frequency, but modern GPUs don't link timing information to core clock speed. Nowadays this indicates some operating system action.
  • Soft Resync Queues (3) : If some GPU outputs go out of sync compared to others, the rendering is shown for two frames on some outputs to bring them back in sync. Number in brackets is the bitmask of the queues that needed synchronization, in this case 1+2 = queue 0 and queue 1.
  • Resync Queues : Hard resnyc all GPU outputs by recreating all swap chains. Used as a last resource when all fails. Will cause flicker for exclusive fullscreen / swap sync outputs.
  • Clusterclock adjusted from network by XXX : another machine corrected the clusterclock.
  • clusterclock jumped : if clusterclock changes by more than 1000 frames, this is logged. Usually result of adjustment from network.
  • GHOSTDROP Present Error GetLastPresentCount Error FLWO Error Closterclock message are for internal debugging and support.
Average Timing
This is useful for benchmarking systems and scenes agains each other. It will only work with the main performance enabled, and it only reflects the CPU Main thread.
This function displays the fastest and the slowest frame of the last 10 frames, as percentage. This fastest frame is then analysed further across 60 frames, 900 frames and 3600 frames, which corresponds 1 second, 15 seconds and 60 seconds when running at 60 fps.
This method of testing removes peaks from the statistic.
Force GPU Stall
Scale To Preview
These statistics are gathered in a separate thread so not to harm rendering performance directly, but there can be side effects that effect system performance that are hard to pin down. These stats will also show the current sync board status if one is configured and detected.
The sync board status is only available for NVIDIA Sync boards!
Clear Timing Debug
Clears the history of the Detailed frame time debugging.
Resync Swap Queues
Use this button when the rendering gets out of sync, to force Ventuz trying to resync everything.
Per Output Stats
Define where and what kind of information should be displayed.
Show on all Outputs:
  • Show information about everything configured on all outputs
Show only in preview window:
  • Shows all configured information only on the Preview Window
Show on all outputs, only relevant:
  • Only shows information corresponding to that output on that output
Logging
Markup in Logging
To add text inside the bar, put it after the numbers : [lb:10/100MB]. A special mode allows number from -100 to 0 be displayed as decibel : [lb:-12/dB].
When getting clever with markup, it might be a good idea to check in the render window and the web interface if both sides interpret the markup correctly.
Logging Limits
Logging
Performance Timing
using(Script1.MeasureCpu)
Example
Here is a complete example:
using System;
using Ventuz.Kernel;
using Ventuz.Kernel.Tools;
    private bool changed;
    public Script()
    public virtual void Dispose()
        changed = true;
    public bool OnEnable(int arg)
	return false;
	return false;
        if (changed)
            changed = false;
            return true;
        return false;
  • The CPU percentage includes all video decoding.
  • The status of each movie player can be displayed. Check if there are more active movie players than expected, or if movie players are switched on and off unnecessarily.
  • Transfering the image from the CPU where it is decoded to the GPU and performing the color space conversion takes some time on the GPU, displayed as dark-green bar in the performance timing.
  • Most likely the input is set to "autodetect". So Ventuz must assume the longest possible frame to buffer.
  • If the framerates match perfectly, the buffer must hold exactly one frame. If they don't match, the buffer must hold the duration of both input plus output frame to handle worst case scenarios.
  • If the input has the same framerate as the output, is genlocked, and set to synchronous, the delay will be either 2 or 0 samples.
  • If the framerate is a 1000/1001 timing like 59.94 Hz (drop frame timing), a 2 samples buffer must be inserted because input and output might in a different phase when it comes to audio-frame lengths.
  • When using Blackmagic boards, an extra video-frame of audio-delay is inserted. this is because unlike all other supported vendors, the Blackmagic SDK handles audio and video with separate timing.
So for shortest delays:
  • don't use autodetect, specify video format manually
  • have input and output at the same frame-rate (but may be different resolution)
  • genlock input and output and set input to "synchronized"
  • If you have the choice, use a timing without drop-frames.
Red(ish): Validation
  • Validation : update bindings and nodes
    • ContentValidation : content nodes
    • HierarchyValidation : hierarchy nodes
  • ResourceLoad : Sending resources (Texture, Geometry) from CPU to GPU.
Green(ish): Rendering
  • RenderSetupBegin : Overhead before rendering can start
  • RenderSetupEnd : Overhead after rendering has finished. This includes Warping.
  • Render : walk the hierarchy nodes and find out what needs to be rendered (recording)
    • Main : render the recording for the main rendering pass
    • Mirror : render the recording for simple mirrors (no rendertarget)
    • FxMirror : render the recording for effect mirrors (with rendertarget)
    • CubeReflection : render the recording 6 times to build a cubemap reflection
    • Shadowmap : render the recording for spot and directional shadows
    • PointShadowmap : render the recording 6 times to build a cube-shadow-map.
    • BoundBoxCalculation : bounding box calculation needed to determinate the size of directional shadowmaps.
  • Glow : Glow node
  • BlurTextureSimple : Blur Texture Simple node
  • HLSLShader: HLSL Shader node
  • TextRendering: Text nodes
  • MovieClip : CPU to GPU transfer and color space conversion during movie replay
Blue(ish): Idle
  • Present: wait for next frame.
  • PreventD3DQueuing: wait for GPU to prevent the GPU from queuing up multiple frames.
  • ResourceLock : wait for GPU to have access to some GPU resource (Texture, Geometry)
  • Blit : A CPU stall that can occur in RenderSetupEnd. This is just an artifact of the measurement method.
  • HardGpuStall : force synchronization of CPU & GPU when GPU Stall option is enabled.
  • BeginVideo : waiting for video at the start of a frame
  • EndVideo : waiting for video at the end of a frame
Yellow(ish): Postprocessing
  • PreparePostProcess: Analyze effects & layers and figure out how to combine various shaders
  • PostProcess: actually execute the postprocessing
  • Some postprocessing shaders take longer than others and are marked individually
    • Blur: Shaders in postprocessing that blur the image
    • Downsample: Shaders in postprocessing that downsample the image to trade of quality for speed for the blurring.
    • DoF: Shaders that implement depth of field.
  • ResourceGen : A resource gets update, and is none of the below:
  • TextureResourceGen : Texture resource update
  • TextResourceGen : Text resource update : this happens when text or layout changes
  • GeometryResourceGen : Geometry resource update
  • XMLResourceGen : XML/XPath/XSLT resource update
  • ShaderResourceGen : Shader resource update
Video Process:
  • InputHandling : Processing for Inputs, excluding DMA and colorspace conversion
  • InputDma : DMA transfer for input streams
  • InputColorSpace : Color space conversion for input streams
  • OutputHandling : Processing for Outputs, excluding DMA and colorspace conversion
  • OutputDma : DMA transfer for output streams
  • OutputColorSpace : Color space conversion for output streams
  • EndFieldGpuStall : Synchronization between CPU and GPU at the end of a frame
  • WaitForFrame : Processing during waiting for frame (for all streams)
  • Wait : Idle time during waiting for frame (this time is used by other threads)
  • FinishFrame : Processing at the end of a frame (for all streams)
Other
  • Runtime (gray) : The Ventuz Runtime. All major processing should have it's own color, this catches smaller tasks that seemed unimportant to measure individually
  • no bar (transparent) : When in Accumulated Bars mode, the times do not add up to 100%. These gaps are time spend with other processes or in the user interface. Especially in the designer, a lot of time may be spend in the user interface when there is mouse-movement.
  • InputProcessing (gray) : processing of touch events.
  • PerfMon (gray) : performance monitor rendering.
  • Live Options
  • Compositions
  • Render Setup
