This can be achieved easily by Uploading a Ventuz Presentation using the dialogue in the Project Management tab. Click Upload in the top right corner and upload the appropriate VPR file.
While it is possible to configure the graphics driver to treat multiple outputs as one logical output, it is not necessary since Ventuz 7.
NVIDIA calls this Mosaic technology, AMD calls it Eyefinity. If this kind of setup is desired, configure the graphics card settings directly on the machines that need it using the appropriate graphics card software. These settings cannot be changed by Ventuz.
After the physical outputs have been configured, inside of the graphic card's software. Click on the Presentation File (VPR) that was uploaded in the first step of this section. In the panel on the right, click + New.... Choose a name and click OK. In this example, "ClusterSetup" is used. Clicking OK will automatically open the Render Setup Editor.
In the left menu, select Default Screen and then click Delete Selected Screen(s). This screen is not needed for this setup.
Delete the first Machine. Click on the Red Garbage Can. This will help in utilizing the built in Wizard to create and assign Screens to Outputs.
In the bottom drop-down menu, select the first screen in the setup: Rhombus_1_1
Click Add.
To get an aspect-correct rendering you will need to get into the Design Preview. But beware if "preview without scaling" is not enabled then this is just a estimation done by Ventuz. To give you a idear on how it will look like. Enabling "preview without scaling" will ensure to display the correct aspect ratio. Just note that on bigger and more demanding scenes this can cause your performance to drop inside the Designer.
Cluster ID 01.02 means that this machine has the Group-ID 01 and the Machine-ID 02, the following number shows the current value of the cluster clock, and the clock from 01.01 indicates that the current clock master has Machine-ID 01. On a client system, the type of the cluster clock is colored GREEN, on a master system it is BLUE.
route change 224.0.0.0 mask 240.0.0.0 <IP of network card here> metric 25
// disable Timeout Detection & Recovery
KeyPath : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\GraphicsDrivers
KeyValue : TdrLevel
ValueType : REG_DWORD
ValueData : 0
| Effect | Cluster Compatibility | |
| Grayscale Color Grading Color Correction Gain Posterize RGB Posterize HSV Color Difference RGB Noise Delay all Masks | | works in cluster without problems |
| Mosaic Blur Glare Dropshadow Edge Detection Lens Distortion Distortion RGB Distortion 2D Displacement Noise Distortion | | works with Effect Bleed only |
| Feedback | | often fails in cluster with an Effect Bleed - depending on parameters |
| Crashzoom Polar Distortion Kaleidoscope Distortion | | does not work with an Effect Bleed |
