Ventuz is a realtime WYSIWYG design application. The Renderer Window shows the rendering result of the Scene/Presentation and updates it every frame. Additionally some information can be displayed as overlay graphics like Performance Statistics or Transformation Gizmos for the in-renderer editing.
On the top right of the Ventuz Designer User Interface there is a row of buttons. A short hint to their functionality can be found in the list below.
![]() | Preview Selection Menu | Menu to change the currently previewed Compositions / Screens or Outputs |
| Pixel Snoop | This Tool picks the color of a certain pixel and copies the information to the clipboard, see PixelSnoop | |
| Video Scopes | Turns the Video Scopes on and off | |
![]() | Wireframe | Turns the Wireframe-mode on and off |
![]() | Statistics | Shows / hides the Statistics for the current scene, like CPU Usage |
![]() | Input Diagnostics | Turns on the Input Diagnostics |
![]() | Bounding Boxes | Shows / hides the bounding boxes |
![]() | Show Key | Toggles the render output to show the Key signal |
![]() | Fullscreen | When activated the render window will be shown in full screen |
![]() | Zoom | Enables the 2D Zoom function for the Renderer Window. |
![]() | Show/Hide Tooltips | Show or hide tooltips in Editing modes - like coordinates and labels. |
![]() | In-Render Edit Mode | As long as In-Render Edit Mode is activated, objects can be moved, rotated and scaled inside the render window |
![]() | Show non-render objects | All objects in the scene will be rendered including hidden objects like lights and cameras |
![]() | Translate | Switch to translation mode. In-Render Edit Mode has to be activated |
![]() | Rotate | Switch to rotation mode. In-Render Edit Mode has to be activated |
![]() | Scale | Switch to scale mode. In-Render Edit Mode has to be activated |
![]() | Local Coordinate Gizmos | Toggles the orientation of the Transformation Gizmo in the renderer to Local |
![]() | World Coordinate Gizmos | Toggles the orientation of the Transformation Gizmo in the renderer to World |
![]() | Parent Coordinate Gizmos | Toggles the orientation of the Transformation Gizmo in the renderer to Parent |
![]() | Autoselect | 2D Editing - Automatically select Layers under the mouse cursor - else use Alt+click. LMB |
![]() | In-Scene Editing | Enables the 2D In-Scene Editing (2D) for 2D/3D Layers |
![]() | Snapshot to File | Takes a screenshot and saves it to disk |
![]() | Snapshot to Clipboard | Takes a screenshot and copies it to the clipboard |
![]() | Render to Disk | Opens the Render To Disk Tool |
All rendering options are also available as Live Option in the Configuration Editor.
Video Scopes are great to accurately color grade your scene, to check, if its in specific color space boundaries or to inspect an incoming video signal. These tools won't lie to you like your eyes and monitors might. They provide exact representations of what elements make up your image, from color values to brightness. The scopes always apply to what's visible in the Render Window , and are only available if the preview window is set to a single composition/screen/input/output. In the Design Preview and All Outputs mode the scopes are not available. The color space of the scopes is the same as the selected preview.
To activate the Video Scopes use this button:
Next to the button, with the small dropdown arrow, the different scopes can be activated and configured.
The horizontal axis represents the tonal range from lowest to brightest value with the amount of pixel on the vertical axis.
The Histogram comes with two options as shown in the picture above: R,G,B overlapped, overlaps the color values in one graph showing how much of each brightness is in the image. R,G,B Luma shows each color in a separate graph with the addition of a luma channel as segment.
The waveform monitor draws each column of the image (x-axis) on the x-axis of the waveform. The brightness value is represented by the y-axis. The pixel for each column are drawn over each other, so the brightness on the waveform gives information about how many pixel have the same level. Depending on the color space, the color value (y-axis) is displayed in nits (for linear color spaces) or percentage (SDR).
It has the same two modes as the Histogram, R,G,B Overlapped and R,G,B Luma. And also an adjustable brightness slider, which increases the brightness of the drawn pixel, so areas with few pixel are easier to investigate.
A vectorscope provides more information about the color properties of a video image. A vectorscope contains markings that indicate the degree of hue and saturation in an image. The further the markings are from the center, the more saturation you have in your image.
The vectorscope has two different modes, one displaying it in YUV (the most common way) and YCbCr which is how the signal will actually look. Most commonly used for testing of SDI signals and color grading. The RGB color space is converted to a !YUC/YCbCr color space.
Zoom scales on the saturation axis (the radial axis from the center), to better check a narrow color foot print. The Brightness slider increases the brightness of the drawn pixel, to better see colors with few pixel.
The CIE Chromaticity show the pixel color values of the frame, regardless of brightness. The drawn boundaries represent the color gamut of the preview renderer's color space. Note: This color space is dependent on the selected preview and the project color space or physical output.
Additionally it is possible to add another graph for comparison via the CIE auxiliary gamut menu and to adjust the brightness.
To change between Window and Fullscreen mode press Alt + Enter.
To switch into the In-Render-Edit Mode press TAB.
If the In-Renderer Editing is enabled, it is possible to select/move/rotate/scale objects directly in the Renderer window by clicking and dragging the corresponding object handles. Note that in this mode the scene logic does not receive any Mouse and Keyboard events!
When you scale, move or rotate an object with the Transformation Gizmo, Ventuz will apply these changes to the next axis in front of that object, but only if that axis has only one Object as its child. If there is no such axis or if there is no axis existent at all, Ventuz will place one in front of the transformed Object.
When clicking in the rendered image Ventuz performs a raycast and selects the first hit object in 3D Space and jumps to the corresponding Node in the Hierarchy Editor.
You can move the camera with Keyboard-shortcuts and Mouse, when the In-Render-Edit Mode is active.
As soon as any of the cameras is active, you can see a Camera Info Panel in the bottom of the Render Window.
To navigate the Free Flight Camera, hold the right mouse button hold and use W,A,S,D to move the camera around.
If you just hold the right mouse button drag and move the mouse around, you would Pan & Tilt the camera, like rotating your head. (The camera info panel will say: FLY)
You can also increase/decrease the speed of movement for the Free Flight- and Walk Through Camera by holding the hold and scroll the scroll. You can see the Speed value in the camera info panel change. Hold Shift or Ctrl to increase/decrease the Fly-/Walk speed for a moment.
To make use of the Orbit Camera you must have an object selected. Hold ALT & drag, left mouse and move the mouse around. (The camera info panel will say: ORBIT)
Use CTRL+ TAB or this button
to enable the 2D zoom function for the Renderer Window.
Use the mouse scroll wheel to zoom in and out or the middle mouse button to pan the view. The current zoom percentage will be shown in the lower left corner of the renderer window. Use R to reset the view.
You can use any of the above described cameras to create a camera in in the Hierarchy! Just fly to your desired position, adjust your camera in Free Flight Mode and press Ctrl + INSERT. A new camera will be create inside the active 3D layer.
The isolate Mode is basically the Render Point functionality. Doubleclick doubleclick any object in the Render Window. This will set a Render Point for the selected Object, all other parts of the scene tree are ignored. The navigation and shortcuts are listed below. Doubleclick doubleclick the selected object again to leave the Isolate Mode
Selecting a node and pressing CTRL + R will set the Render Point to that Node. Additionally you can activate the Render Point in the Hierarchy/- Toolbar or select the Set Render Point from the context menu with a click on the selected Node. The Render Point defines teh isolated subtree in the Hierarchy. For the following screenshot it means the V_Mesh02 is isolated and centered in your Rendering Window.
To isolate a Layer from its composition select it and press CTRL + R. You can also press the Isolate button on the Layer Tool Bar. It allows you to view and edit the Layer outside the context of your already finished composition without changing the actual surrounded logic.
Move the camera:
drag Rotate object ALT + drag Orbit around object drag Rotate camera Ctrl + ALT + drag Roll camera ALT + drag Pan camera ALT + drag Zoom camera doubleclick Leave Isolation Mode / Remove Render Point
Following is a list of all Shortcuts:
| Tab | Toggle In-Renderer Editing |
| R | Switch to Rotation Mode |
| T | Switch to Translation Mode |
| L | Switch to Scaling Mode |
| drag | rotate camera (rotate head) |
| hold + W,A,S,D | Move/Walk around - Free Flight Cam (if heightlock enabled: Walk Through Cam) (Shift & Ctrl faster/slower *10) |
| hold + E,C | Fly up/down (increase/decrease height) |
| Num * | Toggle height lock |
| hold + scroll | change movement speed (Fly-/Walk- cam only) |
| Alt + drag | Rotate Camera (around targeted point (Orbit Camera)) |
| Alt + drag | Zoom/FOV Camera (toward targeted point) |
| Alt + drag | Pan camera (move targeted point) |
| Ctrl + Alt + drag | Roll camera |
| Num1 | Front View |
| Num3 | Side View |
| Num7 | Top View |
| Num2 and Num8 | Rotate around x-Axis (Turn Up/Down) |
| Num4 and Num6 | Rotate around y-Axis (Turn Left/Right) |
| Num , | Focus on selected Object (only with selection) |
| Num5 | Toggle Orthographic / FOV (only with selection) |
| Num0 | Toggle Free Flight Cam / Active Cam |
| Num9 | Reset Roll |
| Num Enter | Reset Free Flight Cam |
| Num / | Toggle On Screen Camera Help |
| Ctrl + insert | Create a camera of the actual Free Flight Camera |
| Hold Ctrl + Shift | Pixel Zoom |
