Located on top of the Content Editor is a Menu Bar:
![]() | Container Level Up | Navigates to the next higher Container level |
![]() | Container Level Down | Navigates into a selected Container or Layer |
![]() | Small Nodes | Displays certain nodes in a smaller version or vice versa |
![]() | Collapsed | Collapses all bound nodes behind the selected one |
![]() | Uncollapse | Uncollapse all bound nodes from the selected one |
![]() | Select bound animation channels | Selects all bound animation channels from that node with the corresponding Keyframe Animation |
![]() | Merge to Container | Merges the Selection into a Container |
![]() | Seal Container | Seals the selected Container |
![]() | Node Family | Group nodes in Families by drawing a gray rectangle around them |
![]() | Edit Annotation | Adds an Annotation to the selected Node |
![]() | Show Annotations | Toggles the visibility of Annotations |
Two nodes are connected by a line if at least one property of a node is bound to a property of another node. The binding relationship can be bidirectional in which case both ends of the line have an arrow head. To remove a binding, click on the line and a list of all bound properties opens. By selecting one of the entries, the respective binding will be removed. To remove all bindings of a node, select the node and press SHIFT + DEL or select Unbind from the Edit Menu.
Sometimes you want to add a node in between an existing connection of two nodes. To do so you can just grab a node from the Toolbox and drop it on a Binding if there is only one connection that fits the value type, the node is inserted, otherwise you get a list of available possibilities.
After some time working with the Content Editor you might notice that some nodes are hidden at times - they are collapsed behind other nodes. Nodes are collapsed behind Content nodes automatically when they are not a direct or indirect source of any of the selected Hierarchy Nodes. You can uncollapse a node stack by right-clicking it. You can uncollapse all currently visible node stacks in the Content Editor with CTRL + SHIFT + X. You might have to do this repeatedly to uncollapse the whole network of nodes in the Content Editor.
Copy
Content Nodes can be copied by simple CTRL + C, CTRL + V.
To copy a single content node without the bound content select the node with CTRL.
CTRL + P will duplicate the node and place the copy next to the original one.
CTRL + SHIFT + P duplicates the node and creates binding to the existing source nodes.
Zoom
Since the number of content nodes in a scene can get quite large, the Content Editor only visualizes a part of the network. By moving the mouse wheel, the user can zoom in or out of the network. Pan the Content Editor by pressing .
The position of the individual nodes can be arranged by the user by clicking and dragging nodes. Each node can be assigned a name by double-clicking on the node name or pressing F2. As with the Hierarchy Editor, parts of the network can be collapsed by clicking on a node. To reach the Context menu, press and hold for a few seconds.
Content nodes can be drawn in a Small version to save space in the Content Editor. Just press CTRL + T to toggle the size of a Content node.
Since complex scenes can require a large rendering hierarchy, Ventuz offers a number of features to give further structure to a scene. The Content Editor can group nodes in Families by drawing a gray rectangle around them. This does not change the functionality but is simply a visual queue to the user that these nodes belong together. To create a family, select multiple nodes in the Content Editor and then either right click and hold untill a menu pops up or press CTRL + SHIFT + F. It is also possible to use the Create Family button in the toolbar on the top of the Content Editor. And pressing the Eye icon (Window Options) in the upper right corner of the Content Editor allows to en/disable, besides other things, the option to always show all family members when one corresponding node is selected.
Compared to the Hierarchy nodes the Content nodes have only very few node decorations:
| Icon | Decoration | Description |
| Red Corner | Indicates that a Node has an Annotation if Annotation Visibility is turned off in the toolbar. |
| Gray Triangle | Indicates that a Node has an 'invisible' binding to the Main Animation, Template Data, Scene Data or Project Data. |
When coloring is not enough, the user can also add a "note" to a node by selecting it and then choosing Edit Annotation from the toolbar or the context menu (press and hold until the menu appears) or press CTRL + E. The box can contain any HTML or Markdown formatted text, thus being the ideal place to leave notes (i.e. keyboard shortcuts, ...) to the person that will actually run the show or to a colleague also working on the same scene. For more information about Annotations take a look at this Page
