or the Diagnostics tab inside the Configuration editor to analyze performance problems in a scene. The Diagnostics are a bit slimmer in there functionality then the Performance Statistics, but these are also accessible remotely using our Web-based Configuration Editor.
Configuration Editor:
Designer:
The performance statistics contain a lot of information. In many cases displaying it all can be a bit overwhelming and requires a lot of screen real-estate. So individual sections can be enabled and disabled and with the Frame Count the amount of visible frames can be adjusted.
In general:
Cores:Number of shader cores are reported by vendor specific API. This number may be incorrect for some architectures and is only used to give a rough estimate on how powerful a GPU is.
Group Granularity: Number of shader threads that are guaranteed to run in lockstep. Usable for shader optimizations.
Tex: Memory used in textures, excluding color and depth buffers.
Color/Depth: Memory used for rendertargets and depth buffers.
Geo: Memory used for vertices and indices of meshes.
Buffers: Memory used for buffers. Buffers are used for instance in the particle system.
Particles: Shows how much particles, either as a sprite or mesh, are calculated every frame. High numbers can impact the performance of your scene drastically. Generally speaking meshes are impacting performance more then sprites.
Creation Calls: Are an exceptionally expensive part of the DirectX API and should only happen during scene loading.
Shader: Shows the currently cached and compiled shader number.
Persistent Resources: are resources that accumulate and are never deleted until Ventuz is quit. VertexFormats and VertexConverters are cheap internal resources that should stay below 25. Shaders is the number of different shaders that have been used since Ventuz started.
The Video Phase will give you detailed information about the health of all current outputs.
1: The star * indicates which output is used as timing ressource for the Ventuz clock. A SDI output has highest priority, followed by a GPU output (except Preview window). Shared Surfaces or NDI has the lowest priority. The Preview Window is only used, if there is no other output.
The ! exclamation mark indicates the output which has focus currently.
The first letter code indicates what Ventuz has set:
Everything after that will show the output mode:
The following situations will always be "dwm" and should not be considered a problem:
2: Shows the current framerate the Output is using in Hertz.
3: Currently rendered resolution of that output.
4: The orange bar shows the shift of the video phase in percentage compared to the output with 0% shift. The values afterwards represent the shift in whole frames and partial numbers.
Queues are represented in different colors depending on there sync status:
Note: For some devices like GPU outs in fullscreen exclusive or specific SDI boards, this indication might not be correct. 5: Output device name and output number / output name
Composition: Shows the currently rendered Composition.
Screens: Currently rendered Screen(s).
Outputs: Used GPU's for the current rendering.
Render: Shows the current number of render steps more complex scenes will show a higher number.
These resolution numbers will be bound to your Render Setup when using only the Runtime, previewing the "Design Preview or enabling "Screens and Outputs without Scaling". Only the other previews inside the Designer are dynamically changing it to save performance!
Blitslow/Blitfast:
Shows the status and debugging information of the Custom Effect Shader node. If the shader fails to compile, information from the compiler are displayed with the line number. It also shows warnings/errors of the input comments parsing from Ventuz side.
The states mean:
The states are:
The buffers show how many buffers Ventuz has allocated and how many frames in the future are available. If these buffers run dry, increase the number of buffers for that movie. At the end of each line you can see the exact Cluster Clock when each Movie Started. Like the lead this is mainly useful to check syncronization of movies in a cluster. Next, Ventuz indicates with NVDEC if it uses the hardware decoding on the GPU and the used color space for the file.
Each line represents:
Shows the messages coming from the Log Node.
The statistics for the Particle System node.
The first count sums up all particles in a Stream. simvar / func shows if the stream is either a simulation or a functional system. emit counts the particles of the Emitter. linkout and linkin are particles which are written/read to a buffer for linkage between streams. sim are the particles in a simulation loop. repeat are particles created by a Repeater module. If a particle stream is split up in multiple parts (shader-wise, visualized by a grey line), this count lists up the number of particles in the split. sprites and meshes displays the renderer count of these types.
Use this option to identify which output is using which GPU and which connector.
GPU's are counted as an array starting with GPU 0 and connector 0. For example a scene rendered on GPU 0 using the third connector would read GPU 0:2.
These can also differ depending on what they are currently rendering. Preview windows will always show the "Preview" flag.
Detailed Timing Header
TIMING : 00:01:29:42 0005382 : +007 Drift, 258 drops, 257 multi frame drops, 4 drop clusters, 0 Resoft, 0 Resyncs, 3 Disjoint, sr Flip-Queue Histogram : 0:0 1:10 2:6 3:0 4:0 5:0 6:0 7:0 unchanged:4475 noinfo:2
Flip-Queue Histogram:
Analyses the queues of all outputs, and every frame it logs the most empty swap-queue. This allows to detect performance issues before a frame visibly drops: Especially if you configured a few extra buffers, you can see the queue decreasing in length without getting empty. This is an indication how "safe" you are running.
When running in the designer with render window and physical outputs, the render window will not be included.
Interpreting the Histogram:
If you see the slot "1" going up, you are having visible drops or are very near to dropping. Increases in higher slots should not be visible drops but temporary situations where rendering was slow but still some frames queued up for display, so no visible drop. By adding more extra-buffers things should shift to the safe side, at the cost of increased latency / lag. A good situation would be by adding two extra buffers, seeing the "1" and "2" slots at zero and the "3" slot showing some increases. You are running fine.
Detailed Timing Events
In addition to the header, the detailed timing will log events, basically whenever something went wrong.
Logs entries start with a timestamp:
WED-14:14 00:00:00:31 0000031
Day of week, Hour:Minute of the day, cluster-clock as timecode (HH:MM:SS:FF), Cluster-clock total.
The number in brackets is the number of frames that should have passed. +1 is normal, +3 indicates that 2 frames were dropped.
This is useful for benchmarking systems and scenes agains each other. It will only work with the main performance enabled, and it only reflects the CPU Main thread.
This function displays the fastest and the slowest frame of the last 10 frames, as percentage. This fastest frame is then analysed further across 60 frames, 900 frames and 3600 frames, which corresponds 1 second, 15 seconds and 60 seconds when running at 60 fps.
This method of testing removes peaks from the statistic.
These statistics are gathered in a separate thread so not to harm rendering performance directly, but there can be side effects that effect system performance that are hard to pin down. These stats will also show the current sync board status if one is configured and detected.
The sync board status is only available for NVIDIA Sync boards!
Clears the history of the Detailed frame time debugging.
Use this button when the rendering gets out of sync, to force Ventuz trying to resync everything.
Define where and what kind of information should be displayed.
Show on all Outputs:
Show only in preview window:
Show on all outputs, only relevant:
To add text inside the bar, put it after the numbers : [lb:10/100MB]. A special mode allows number from -100 to 0 be displayed as decibel : [lb:-12/dB].
When getting clever with markup, it might be a good idea to check in the render window and the web interface if both sides interpret the markup correctly.
using(Script1.MeasureCpu)
Here is a complete example:
using System;
using Ventuz.Kernel;
using Ventuz.Kernel.Tools;
private bool changed;
public Script()
public virtual void Dispose()
changed = true;
public bool OnEnable(int arg)
return false;
return false;
if (changed)
changed = false;
return true;
return false;
So for shortest delays:
Red(ish): Validation
Green(ish): Rendering
Blue(ish): Idle
Yellow(ish): Postprocessing
Video Process:
Other
