2D Layers
  1. General information about 2D Layers
  2. Color Layer
  3. Gradient Layer
  4. Image Layer
    1. Color Space
    2. Hint
  5. SVG - Scalable Vector Graphics
    1. Usage
    2. Limitations
  6. Movie Clip Layer
  7. Movie Frame Layer
  8. Movie Stream Layer
  9. Live Video Layer
  10. Gradient Texture Layer
  11. Texture Loader Layer
  12. Texture Property Layer
  13. Spout Receiver Layer
  14. NDI Receiver Layer
  15. Common Layer Properties
    1. Blending
      1. Mode
      2. Opacity
      3. Blocked
      4. BlockedOnFullTransparency
      5. Layer Mask
        1. Mask
          1. Texture Loader
          2. Texture Property
          3. 1D Gradient
          4. SVG Loader and SVG Text
        2. Mask Properties
        3. Mask Vignette
        4. Mask Border
    2. Layout
    3. Mapping
    4. Effects
      1. Blending
      2. Mask
      3. Effect
        1. Effect Group
        2. Color Correction
        3. Filters
        4. Distortion
      4. Layer
Color Layer Fills the Layer with a Solid Color
Gradient Layer Creates a Gradient filled Layer - The gradient can be edited and reoriented
Image Layer Creates a simple Layer with an Image - for more properties choose the Texture Loader Layer
SVG File Layer Creates a layer to load SVG drawings
SVG Text Layer Creates a layer that is completely filled with a SVG drawing coming in as XML text
Movie Clip Layer Creates a layer to load in a Movie Clip
Movie Frame Layer Creates a layer to load in a Movie Clip and specify a single Frame inside the Properties
Movie Stream Layer Creates a layer to load in a Streaming Video Clip like a RTSP
Live Video Layer Creates a layer to show Live Video Streams - these Video Inputs have to be configured in the Ventuz Config Editor
Gradient Texture Layer Creates a Gradient Layer with a Gradient Texture node attached inside the Content Editor Area
Texture Loader Layer Creates a Texture Layer with a Texture Loader node attached inside the Content Editor Area
Texture Property Layer Creates a Texture Property Layer only - you need to connect any source node inside the Content Editor Area
Spout Receiver Layer Receives a RGBA texture via ​SPOUT
Color Layer
Gradient Layer
Image Layer
The Image Layer loads standard images and layouts them in Full Size per default. You would preferably use the Image Layer to bring images on screen because it does not generate MipMaps nor does it apply any kind of multisampling. While using the Image Layer you can adjust the color space and how to handle the alpha channel by changing the Property called Hint.
Color Space
The Color Space property defines how Ventuz converts the texture to the Project Color Space. Per default, Auto reads out the meta-data of the file. With the specific settings for primaries and transfer function, this can be manually overwritten. Unspecified does not convert any color data. For the most used formats / usecases there are presets to select.
Hint
With the Hint you can specify how to treat alpha values for the loaded Image, Texture or Video.
The Hint drop down menu has the following options available:
Alpha
The Alpha mode specifies the meaning of the image's or video's alpha channel.
  • Auto: The alpha mode gets detected from the file type and its embedded metadata
  • Uncorrelated: The content of the alpha channel is unrelated to the color channels (for example the color channels contain some color, and the alpha channel contains roughness).
  • Straight: The alpha channel contains opacity, and the colors are straight, i.e. not premultiplied.
  • Premultiplied: The alpha channel contains opacity, and the colors are premultiplied.
It's usually safe to keep this setting on "Auto", with one exception: If you know the alpha channel is going to get used for something else than alpha blending, you need to set it to "Uncorrelated". The texture loader can't detect this case on its own.
Flags
  • Premultiply straight alpha: If the image is set to or detected as straight alpha, colors will get premultiplied while loading the texture. This eliminates fringing around transparent edges in most use cases. Turn this flag off if your material setup requires non-premultiplied colors.
The Premultiply straight alpha flag doesn't have an effect on images that have uncorrelated or premultiplied alpha, as well as on DDS textures.
  • Fast Mipmaps: Using this option will improve loading time but ignore the gamma/transfer characteristics of the image when creating mipmaps. It is advised not to use this when using images with alpha or HDR color spaces.
Usage
Example:
      <g id="g14">
        <g id="g16">
        </g>
      </g>
    </g>
  </g>
</svg>
Output:
Limitations
Movie Clip Layer
Movie Frame Layer
Movie Stream Layer
Live Video Layer
The Live Video Layer offers a simple and effective way to add any configured live video to be feed into Ventuz. To use the Live Video Layer with your Webcam or SDI-Board, you would need to setup the Video Input Source in the Device Configuration. With the Live Video Layer you are able to create very quick side by side Video Feeds simply by adjusting the Layout of the layer itself. To select a specific Ordinal you can either click the Layer Icon or use the Ordinal drop down menu in the Video Property. You can Enable and Disable the Live Video by clicking the buttons in the Video Control section.
Variable Meaning
!{0}, !{4} Position of the color keys
!{1}, !{5} Red-Value of the color keys
!{2}, !{6} Green-Value of the color keys
!{3}, !{7} Blue-Value of the color keys
!{8}, !{10} Position of the Alpha keys
!{9}, !{11} Value of the Alpha keys
The difference with the Image Layer is that the Texture Loader Layer also adds a Texture Loader Node to the Content Area. To load an image into the Layer you would need to specify it in the Texture File Property. The ColorSpace and Hint properties are multi-option drop-down menus used for setting how the image's color and alpha channel information are loaded. Both properties work similarly to Image Layer.
The SPOUT Receiver Node receives an RGBA Texture that can be bound to e.g. a Material Node.
Every SPOUT Sender available is added to a List, with the Sender Name Property you can select the sender you want to receive the Texture from. In the outputs you get a list of all currently available senders. This list is updated once during initialization of the node. If needed you can update the list again using the Update Sender List Method.
Not a Color Textures loaded with this option will not be touched or converted internally into any other colorspace
sRGB defines to use the Texture in the sRGB colorspace, which is the standard for Images, Videos and most Textures.
Linear loads the Texture in Gamma 1.0.
2.006 RGBA
NDI Receiver Layer
The NDI Receiver provides the texture of a chosen NDI source together with several meta data. The Source property defines which NDI source to use - it can be provided either as a string or using the dropdown menu that is accessed by  clicking the arrow on its right.
Low Bandwidth limits the input to 640x360 pixels which saves bandwidth between the source and Ventuz and is meant to be used e.g. for preview cases. Low Latency disables frame buffering that is used to stabilize the incoming framerate. If enabled it may cause stuttering on the input depending on the NDI source and the network environment, but the frames will be processed by Ventuz without any delay.
Audio Stream
Blending
Blend Modes
Mode
Opacity
Blocked
Layer Mask
Mask
Texture Source
Texture Loader
Texture Loader Presets
Image/Texture
Description
Internal resource name
Image/Texture
Description
Shape Circle
Shape Triangle
Shape Pentagon
Shape Cross
Spike Star
Checker
internal://images/checker.png
Checker Blue
Checker Dots
internal://images/dots.png
Lines
internal://images/lines.png
Noise
internal://images/noise.png
Alpha Glow Full
Alpha Glow Half-Full
Alpha Glow
Alpha Glow Half-Sharp
Alpha Glow Sharp
Square Blur Sharp
Square Blur Sharp
Square Blur Medium
45 Degree
Linear In/Out
Linear
internal://Images/linear.png
Dimple
internal://images/dimple.png
Pimple
internal://images/pimple.png
Liquid
internal://images/liquid.png
Woodchip
Image/Texture
Description
Image/Texture
Description
Lensflare Ghost Colors
Lensflare Star
Lensflare Dirt
Image/Texture
Description
Image/Texture
Description
Incidence 1D Lambert
Incidence 1D Rainbow
Incidence 1D Specular
Incidence 2D Smooth
Incidence 2D Steps
Incidence Diffuse
Incidence Diffuse Anisotropy
Incidence Specular
Incidence Blue Back
Celshading Steps
Image/Texture
Description
Image/Texture
Description
Hatch Lines
Hatch Curves
Hatch Letters
Texture Property
1D Gradient
Gradient Presets
Image/Texture
Description
String representation
Image/Texture
Description
B/W Ramp
White Alpha Ramp
Black Alpha Ramp
White Highlight
B/W Reflection
B/W Reflection 2
Cholor Chrome
Color Hard Edge
Cholor Spectrum
Color Ramp
Alpha Ramp
A;a0:(1);a1:(0)
Alpha In/Out
A;a0:(0);a0.5:(1);a1:(0)
Alpha Biased In/Out
A;a0:(0);a0.25:(1);a1:(0)
Alpha Bars
SVG Loader Presets
Image/Texture
Description
Ventuz Logo SVG
internal://images/ventuz.svg
Mask Properties
Mask Vignette
Mask Border
Layout
Mapping
Effects
Blending
Mask
Effect
Effect Group
Color Correction
Filters
Distortion
Layer
These Properties may vary for the different Layer-types. The most common Property is the Orientation Property which makes it possible to Rotate the Layer in any direction or Mirror and Flip it. There are several Layer-specific properties depending on the Layer Type. The Image Layer has Properties like the TextureFile and ColorSpace/Hint which control the color space and alpha mode, while for example the Constant Color Layer has a TextureColor Property. As mentioned before, each Layer Type may vary in the Layer Properties.
  • Gradient Editor
  • Texture Node
  • LUTs
  • ​SPOUT
