Migration Guide
  1. Ventuz Migration Helper
    1. General
    2. Migration
    3. Config Import
      1. Render Setups
  2. Designer Resolve Mechanism
  3. Config Changes
    1. Files
    2. Machine ID
    3. Workflow Changes
      1. Outputs vs Pipes
      2. Render Setup Editor and Mapping Outputs
  4. Designer/ Runtime Changes
    1. Removed Nodes
    2. Removed Properties
    3. Deprecated Nodes
    4. Changes in Work-flow
    5. Changes in Text Rendering and Layouting
    6. Removed Render Engine Features
Ventuz Designer and Runtime always guarantees Backwards Compatibility and thus are always able to load scenes and presentations created in previous Ventuz versions.
However, if upgrading from one major Ventuz version to the next, there can be some (breaking) changes in functionality and work-flow to be considered. These changes can be grouped in three categories:
  • Removed functionality which causes major differences.
  • Changes in work-flow when building scenes and configuring a Ventuz Machine.
  • Changes in scene logic which make scenes behave and/or look slightly different.
Since Ventuz 6.0 the folder locations and structures for settings, configurations and caches changed. All versions starting with Ventuz 7 come with a small utility located in the installation folder: VentuzMigrationHelper.exe
With following startup options it' possible to specify which settings/files should be migrated:
-noui : start without UI
-v5 : migrate from a Ventuz 5 installation
-onlyonce : test if migration has been performed before and do not migrate again
-all : migrate all settings/configs
-des : migrate Designer User Settings
-dir : migrate Director User Settings
-res : migrate Resolution Presets
-mc : migrate Machine Configurations
-id : migrate Custom SystemID
-vms : migrate VMS Settings
-rep : migrate Repositories
-lic : migrate SOFTWARE LICENSES
-fnt : migrate Fonts and Emojis Cache
-ow : overwrite existing files
Migration
This utility allows to copy all according files from the Ventuz 5 or 6 locations to the new Ventuz 7 folders. On the first run of the Ventuz 7 installer this utility is started automatically and allows to select the items that should be copied. When the migration has finished a report is presented. This report is located in C:\Users\Public\Documents\Ventuz7\Logs. On every next installer run the utility checks if a migration already has been performed (by checking the existence of the migration report file) and does not show up anymore. But it's possible to start this tool manually and perform a migration again.
The Tool is only started post installation if a Ventuz 5 or 6 installation is found on the system and no migration has already been performed
Files and settings that can be migrated are e.g.:
  • Designer and Director User Settings like Layouts and Shortcuts
  • Resolution Preset File used in Designer
  • Custom !SystemID
  • VMS Settings
  • Software licenses
  • Machine, Hardware and Render Setup configurations (converted to the new Ventuz 7 file formats)
  • Repositories
  • Font & Emoji Caches
Config Import
During the Migration process all configurations that are found are already converted and imported, but you might have backuped some of your Ventuz 6 configurations and want to manually convert them.
To do so:
  • Start the Migration Helper
  • click on Config Import
  • select the configuration files that you want to import and convert into Ventuz 7
Render Setups
Starting with Ventuz 7 Render Setups are not global anymore but moved into the Ventuz Project structure. Therefor you will not find a Render Setup folder in C:\Users\Public\Documents\Ventuz7\Configurations anymore. However, this also means that Render Setups are converted but cannot be imported to the correct location. Per default converted Render Setups are located in C:\Users\Public\Documents\Ventuz7\Configuration\V6_Imports\RenderSetups
and have to be applied to a Ventuz Project manually. This can be either done by creating a
RenderSetups
folder inside your Ventuz Project and adding the desired *.vren
files or by using
Import to Project
inside Project Properties.
Ventuz helps to find and resolve nodes in a scene that are removed, deprecated or changed for this version. The Scene Statistics' Issues Tab lists nodes that cause errors or issues. The same time, these nodes are marked in Hierarchy and Content Editor with a red or orange frame - depending on the error level. The node's tooltip gives a hint too.
The context menu of the node - Click  to open it - will show an Auto-Resolve Issue entry if Ventuz can resolve it automatically. This will replace the node with it's new version when possible. Auto-Resolve is usually possible for nodes that have a counterpart in the new version and are not bound to other nodes.
Config Changes
Files
  • .avc: The Audio Video configuration is replaced by the Device Configuration with the file extension .vdev.
  • .vrs: Render Setups completely changed in the backend, nevertheless they keep their name but change the file extension to .vren.
The File Formats are not compatible but you can import and convert the old configuration files with the Migration Helper, the Configuration Editor and in Ventuz Designer.
  • .vmc Machine Configuration all TUIO related configuration options moved into Device Configuration since Ventuz does support multiple parallel TUIO devices with Ventuz 7.0 or later
Machine ID
In the past Machine ID 0 was implicitly creating a preview of the active Render Setup, called Cluster Preview. This has changed with Ventuz 7.0 release. Machine ID 0 is now the first machine inside a [Cluster Ventuz Cluster] and only showing the part of a Render Setup that is configure in the Output Mapping
Workflow Changes
Outputs vs Pipes
One of the major changes since Ventuz 7 is based on how you create and playout multiple contents on multiple parallel outputs.
Check the following pages to get used to the new workflow:
  • Render Setup Editor Ventuz 7
  • How to setup multiple screens and outputs
  • How build scenes for multiple outputs
Removed Nodes
These are Nodes which do not work anymore as their functionality has been removed:
  • TextureText Node (deprecated since Ventuz 4.0)
  • RenderTarget (deprecated since Ventuz 4.0)
  • RenderTarget Reference (deprecated since Ventuz 4.0)
  • Viewport (deprecated since Ventuz 4.0)
  • View (deprecated since Ventuz 4.0)
  • Projection (deprecated since Ventuz 4.0)
  • Texture (deprecated since Ventuz 4.0)
  • Image Filters & Transforms (deprecated since Ventuz 4.0)
  • TextureGenerator (deprecated since Ventuz 4.0)
  • ImagesToCubeTexture (deprecated since Ventuz 4.0)
  • !Html2Image (deprecated since Ventuz 4.0)
  • hard-coded Shader nodes like VertexNoise or Corona. (deprecated since Ventuz 4.0)
Removed Properties
  • SystemID Node:
    • Machine related output properties. Replaced by Render Setup Relation Node.
      • Width and Height: Replaced by Render Setup Relation Node.
      • Aspect: Replaced by Render Setup Relation Node.
      • Render Setup Mode: deprecated.
  • Layer Nodes:
    • Layer size related output properties since a Layer can be renderer multiple times with different resolutions
    • Project size related output properties
    • Device size related output properties since a Layer can be renderer multiple times with different resolutions
  • Scene Event Node:
    • On Deactivate event removed. The on deactivate is not running through a new validation until the scene becomes active again.
Deprecated Nodes
  • Matrix Rotation/Scaling/Translate Nodes. Use Matrix Transformation Node instead.
  • Removed Permanent Seal for Containers. Use Password Seal instead.
  • Ranks for external Chroma Keying are now inherited from Layer groups to their children.
  • Vertical text alignment was wrong for Center, LastLine and Bottom if the LineSpacing property was not 1
  • Custom character spacing could have caused strange text layouts.
  • The legacy engine mode that emulated the Ventuz 4 engine to provide backwards compatibility with scenes created in earlier versions of Ventuz has been finally removed. Scenes can still be loaded and therefor upgraded but will not render properly.
