Ventuz Configuration
    1. Project Browser
    2. Configuration
    3. Live
  3. Machine Selection
  4. Messages
  5. General
  6. Cluster Status
  7. Logs Quick access
  8. License Manager
  9. License Management
    1. Registering & Activating
    2. Update License
    3. Expired License
  10. Overview
    1. Configuration Files
  11. Group Selection
The Ventuz Configuration Editor enables the configuration of a Ventuz system for production. The Configuration Editor allows for the administration of multiple configurations and easy switching between them. The Ventuz Configuration Editor can be found in the Windows Start menu, or in the Tools menu of Ventuz Designer.
The editor is capable of configuring and controlling remote systems utilizing the Ventuz Machine Service. An installed, started, and accessible VMS is mandatory to configure all systems. The Ventuz Configuration is Project independent and configures all settings related to the Ventuz system. Most of the settings are hardware related but it also contains rendering, network and identification settings.
The Ventuz Configuration Editor consists of three pages: Project Browser, Configuration, Live.
Project Browser
The Project Browser shows the used Designer Projects (.vzp), Director Shows (.show) and Runtime Presentations (.vpr). On the left side you can either see the recently used files or browse projects, shows, presentations based on their categories. Every displayed file type allows to be started with the associated application. This can be done clicking the button in the lower right corner of the displayed tiles. Presentations (.vpr) can only be started with the Ventuz Runtime, Director Shows (.show) can only be started with the Ventuz Director whereas Designer Projects (.vzp) can started with the Ventuz Designer or Director because Director Shows are always initially created based on Designer Projects. Clicking on a tile in the browser gives provides you further information for the associated file.
On top of the browser page you will find a row of buttons to perform certain actions:
New project Provides a dialog to configure and create a new Designer Project
Kill Ventuz Runtime Allows to stop running Designer and Runtime (this button is only visible if either Designer or Runtime is running)
Refresh Reloads the browser content. This can also be achieved by pressing F5 key.
Rescan Starts s project scan in the configured VMS search paths and updates the browser content if new projects have been found.
Upload Allows to upload VPR files to a remote machine where Ventuz is installed.
Configuration Configure the project search paths for the VMS project scanner.
Configuration
The Configuration page consists of the following sections:
Status: Here you can the basic information about the Ventuz Machine Service (running), the selected configurations and the (running) Runtime. At the bottom of this page you have the possibility to download log files for the different Ventuz applications.
Generall: Set the Name, numeric ID and Group values and Tag string here to identify this Ventuz machine in a network and assign it to a Ventuz Cluster if necessary.
Machine: Select or create new Machine Configurations here.
Device: Select or create new Device Configurations here.
Render Setup: Select or create a new Render Setup for an existing project or presentation here. It's also possible to start any of the listed projects and presentations.
Live
The Live page consists of the following sections:
Scene Control: This page gives you the possibility to to load scenes from the active project to the ScenePorts of the active LayoutScene.
Project Data: Here you can modify the Project Data of the active project and create presets from these data sets.
Live Options: This section allows to enable and modify certain parameters that can be changed during Ventuz Runtime is running without the need of changing the Machine Configuration or Device Configuration. These are e.g. the Statistics or some Rendering options. For a full description to Live Options.
Diagnostics: Here you can see the Performance Statistics as they are usually displayed on the render output. This comes handy if you do not have visual access to the render output.
The address is as following:
http://IP Address:22404 Via the Web Browser you can access the Configuration Editor directly by entering the IP of the Ventuz machine and the Port
http://localhost:22404 Open the Configuration Editor via your local VMS on your machine
http://192.168.4.25:22404 sample address for the Web Configuration Editor on another machine
  • Launching Designer or Director
  • Project Properties or Maintenance
  • Editing Shaping/Warping within Render Setups
  • Editing Render Setups on touch screen devices is limited
Machine Selection
Messages
Ready waiting for input signal, ready to go
Presync, Syncing stabilizing stream, synchronizing multiple streams together
Running stream is running normally
Disabled disabled either by the Live Video Node or by the software watchdog.
Bypass bypass relays activated
Error some error condition, see log for details.
Name Bits Per Pixel Comment
YUV422 10 bit 21.3 best quality
YUV422 8 bit 16 best speed
YUVK4224 10 bit 32 best quality with alpha
YUVK4224 8 bit 24 best speed with alpha
RGBA 8 bit 32 used as quality option when YUVK4224 10 bit is not available
RGB 8 bit 24 used for some webcams (windows media foundation devices)
YUV422 8 bit with separate alpha 24 used for iVGA, same quality and speed as YUVK4224 8 bit
Input -> Ventuz The delay from input to the Ventuz renderer
Ventuz -> Output The delay from the Ventuz renderer to output
Input -> Output The delay from the input and the output
Status
The Status page from the Configuration or Live tab gives you detailed information about the current state of your selected machine(s).
This includes:
  • the ID and Group number
  • the IP Address
  • the currently running project
  • the installed Ventuz version
  • which product is running, e.g. Ventuz Designer
  • and the output pipe with the current frame rate and other configuration settings
  • overview of running VMS services and possibility to edit them
With the Snapshot button in the bottom right corner, a snapshot of the current Ventuz Runtime rendering will be displayed and is also downloadable.
Cluster Status
If a Group is selected in the Machine Selection tab, this window will display the information overview of each machine in parallel.
Logs Quick access
The Logs Quick access provides all the different application Logs. By pressing the Log button you can download the log file. They are also saved in the Ventuz configurations folder next to the Configuration Files on your harddrive.
License
License Manager
In the License section the system Ventuz license can be added, updated or unregistered.
This License Manager in the Configuration Editor has the some functionality as the standalone application installed with Ventuz.
With the Copy button all license information are copied to the clipboard.
Sometimes it might be necessary to press Update to reach out to the Ventuz License server to verificate your license after a change.
License Management
When you are running your license for the first time or if your dongle does not contain any license keys, you must click on Enter License, and a new screen will appear (see below). The same goes with system and TPM licenses. Please enter the license key information listed on your license certificate in this form. Optionally, you can also enter a custom license label for your internal license management.
Update License
Expired License
If you try to run Ventuz Designer, Director or Runtime and are presented with the Ventuz License Manager with red text in the license panel this is an indication that your Maintenance period has expired and the version of Ventuz that you have installed is too new. In such a case please contact your Ventuz reseller or ​sales@ventuz.com. Highest available version under Maintenance indicates which is the most recent version of Ventuz that will run with your current license. You can download older versions here: ​https://www.ventuz.com/resources/downloads/
General Configuration
Overview
The General configuration tab contains information about the Ventuz Machine.
It defines the Machine Name of the machine as well its numeric ID and GroupID.
The ID determines which machine will be Master and which Client(s) in a Machine Cluster. The lowest ID will be set as Cluster Clock Master. The ID is also used to select the correct part to be rendered in the multi-machine Render Setup. With the Live Options, the ID can be changed while the runtime is active.
The GroupID must be set to a value greater than zero if a machine is part of a Cluster (group). Only machines with a GroupID can interchange their timing (cluster clock) to synchronize Remoting, animation and movie playback. For proper synchronization a valid Cluster Option is required.
The Tag is used by the Runtime to determine the Layout Scene that is to be used.
Configuration Files
The Machine Configuration and Device Configuration files are selectable and editable in the Configuration Editor.
New creates a new configuration file. It is possible to upload a file from the hard-disk, also a duplication of an existing configuration file can be done in the creation dialog. With Activate the selected configuration is activated and will be applied, also while the runtime is running.
With pressing the Cogwheel Icon the selected configuration will be opened in the editor. If you want to edit the configuration directly without the interface, you can edit the JSON file via the UI, by pressing the Paper Icon. With the Pencil Icon an existing, not activated, configuration can be renamed. With the next button the configuration file is saved to hard-disk. The Red Bin Icon deletes the configuration.
All Ventuz configuration files are stored in the system's public documents folder in the Ventuz8\Configuration directory. On most systems this path is:
C:\Users\Public\Documents\Ventuz8\Configuration\
Except the Render Setup files are stored within the Content\Project\RenderSetups folder structure within the Project.
If you upload your configuration file to a remote machine with creating a new configuration it will be saved at the remote machine locally in the same folder structure.
In the Ventuz configuration folder multiple files and folders are stored.
All Ventuz configuration files are human-readable and can be opened with a text editor.
.vcfg Ventuz Config This file contains the Ventuz Config consisting of Machine Configuration, Device Configuration, Render Setups
.vdev Device Configuration The Device Configuration contains the configuration of IO devices.
.vmc Machine Configuration This file is project independent that handles and configures all settings related to the Ventuz system
.vren Render Setups This file contains the Render Setup created in the Render Setup Editor.
.vnetcfg Network Configuration This file contains the port numbers to be used for the Ventuz network protocols.
Group Selection
If a Group / Cluster is selected the General Configuration section shows an overview of the machines configuration.
It is possible to see the activated configurations and Render Setups for each machine and the VMS status for each machine. The machines can be sorted by each category. With the arrow at the end of each machine line, the Configuration Editor will switch to this machine for editing configurations.
The red marked bar indicates that status or the configurations of both machines is not according to each other. In this case the runtime of the first machine is not running.
  • CommandLineOptions
  • HowTo/HowToClusterRendering
