Render To Disk
  1. GUI-based Render To Disk
    1. Overview
    2. Creating an Image Sequence
Ventuz supports two ways to create image sequences or video files from any Ventuz scene. The first is a GUI-based Render-To-Disk functionality available in Ventuz Designer. Second way is a dedicated Remoting API.
Restrictions
In Internal Software Key mode the Live Video background is not part of the Render To Disk result.
  1. Recording of user interaction or remote commands (only in interactive mode)
  2. Playout or rendering of the loaded scene with the previously recorded data.
In this second step, the actual creation of the output files takes place.
Overview
To start the GUI-based Render-To-Disk functionality, select Render To Disk in the Renderer menu of your Ventuz Designer. This will bring up a dialog which initially looks as follows: 1: Render Layout: Define here which output should be used for the capture. With Select... the Screens, the Design Preview, Compositions, Machine Output - all as defined by the local setup or Render Setup - or the local GPU output can be specified. When all <All Screens> or multiple outputs are selected, the rendering of each output will be saved in an additional file.
2: Control Section provides some scene initialization options and the main controls for the recording and playout steps. The Scene Events option specifies if the active scene should receive a Scene Activate event when the playout starts. If this option is either set to On Prepare or On Start, the scene will act as if it just has been loaded. The option On Prepare is only available in Interactive capture mode. In this case, the event gets fired before the initialization phase of the recorded interaction. Nodes like Scene Event, Movie Clip as well as state based Keyframe Animations react on Scene activation.
In Interactive mode, Start Capture starts the recording of the user interaction. The interaction recording is divided into two phases: in the first phase (preparation) the user can record, reset and initialize inputs; in the second phase, the inputs for the actual playout are recorded. If user interaction has been recorded, it can be played back by triggering the Play Interaction button. The actual playout to disk is started by pressing the Render To Disk button. The interaction capture of phase 1 is played back first and then afterwards the recording starts with phase 2 interactions.
3: Output
The Base Filename defines the naming for the image files written to disk. For image sequences, a five-digit number is automatically appended to the base name so that the resulting image names look as follows:
<baseFilename>_xxxxx.<containerFormat>
With Make unique Ventuz automatically appends a unique number to the basename for video files, to not overwrite prior renderings.
4: Video Format section provides options to specify the image or clip format of captured frames like resolution and frame rate as well as color and audio options. Four Image File Formats are currently available, all of them supporting an alpha channel: BMP, PNG, TGA, TIFF, EXR. Following movie formats are available: the QT Animation format writes a Quicktime Animation (loss-less RLE compression) in a MOV container; the HuffYuv writes a movie with the according codec to an AVI container; the XDCAM format creates movies in XDCAM 442 format to MXF container. Note that the XDCAM format only supports the standard 720p, 1080p and 1080i broadcast formats; DNxHD / DNxHR format creates movies in DNxHD - 440x/440/290/90 for 1080p, DNxHD - 220x/220/145 for 1080i/720p, DNxHR supports 444/HQX/HQ/SQ/LB formats with optional VBR (variable bitrate). Hap/ Hap Alpha and Hap Q wirte HAP movies to a mov container. H.264 (AVC), HEVC (H.265) and AV1 are using the mp4 container, due to compatibility reasons with other tools.
All video format settings of this section can be written and loaded to Render to Disk presets (.vr2dprest), by clicking on the top right corner (...) button.
Movie File Formats
Codec Container Audio
QT Animation mov 48kHz 16/24bit PCM stereo; separate wav file
HuffYuv avi 48kHz 16/24bit PCM stereo; embedded
XDCAM HD 422 mxf 48kHz 16/24bit PCM stereo; embedded
DNxHD mov 48kHz 16/24bit PCM stereo; embedded
DNxHR mov 48kHz 16/24bit PCM stereo; embedded
Hap / Hap Alpha mov 48kHz 16/24bit PCM stereo; embedded
HapQ mov 48kHz 16/24bit PCM stereo; embedded
ProRes mov 48kHz 16/24bit PCM stereo; embedded
H.264(AVC) mp4 48kHz 16bit PCM / 320 kbit/s MP3 / Opus, stereo; embedded
HEVC (H.265) mp4 48kHz 16bit PCM / 320 kbit/s MP3 / Opus, stereo; embedded
AV1 mp4 48kHz 16bit PCM / 320 kbit/s MP3 / Opus, stereo; embedded
H.264 and HEVC formats are rendered using gpu hardware acceleration! This is enabled for Nvidia (NVENC) , AMD (VCN) and Intel (Intel Quick Sync Video) gpus. The supported formats depend on the exact gpu model, mainly its generation. Refer to the gpu manufacturer for details.
DNxHR Specifications
Preset Quality / Resulting Bit
DNxHR 444 Finishing Quality - 12-bit 4:4:4
DNxHR HQX High Quality - 12-bit 4:2:2 UHD/4K Broadcast-Quality
DNxHR HQ High Quality - 8-bit 4:2:2
DNxHR SQ Standard Quality - 8-bit 4:2:2
DNxHR LB Low Bandwidth - 8-bit 4:2:2
Apple ProRes Specifications
Apple ProRes 4444 XQ Highest-quality version of ProRes for 4:4:4:4 image sources (including alpha channels)
Apple ProRes 4444 Extremely high-quality version of ProRes for 4:4:4:4 image sources (including alpha channels)
Apple ProRes 422 HQ Higher-data-rate version of ProRes 422 that preserves visual quality at same high level as 4444 but for 4:2:2 image sources
Apple ProRes 422 High-quality compressed codec offering nearly all benefits of ProRes 422 HQ, but at 66 percent of the data rate
Apple ProRes 422 LT More highly compressed codec than ProRes 422, with roughly 70 percent of the data rate
Apple ProRes 422 Proxy An even more highly compressed codec than ProRes 422 LT
For detailed specifications refer to ​Apple ProRes Specs
For Render-To-Disk in XDCAM, DNxHD/DNxHR and Apple ProRes formats an additional encoding License Option is required! Please contact Ventuz Sales for license questions.
The Color Space option is only available if the project is set to HDR color space in the Project Properties. Choosing a suitable color space allows to render out HDR content. The available color spaces depend on the selected output format.
Option Description
No alpha Don’t include alpha channel in output
Straight Output “normal”, unpremultiplied alpha
Premultiplied with lifted Alpha Output premultiplied alpha, adjust alpha if there is additive content (works everywhere but desaturates additive highlights)
Premultiplied with additive Headroom Output premultiplied alpha, keep additive content (preserves image but might not work with some other products)
The Audio Format specifies if audio should be written; either as separate file or embedded. This depends on the video codes: image sequences can only have a separate audio file. This file is always two channel, 48000Hz PCM, 16 or 24 bit (XDCam can only have embedded 24 bit audio) that contains the audio passed to the first stereo pair of the Ventuz audio output device. The formats with mp4 container support also MP3 and Opus as embedded format. See also Audio Devices
The Frame Rate value defines the frame rate of the image sequence. A value of e.g. 30 will generate 30 images for every second of rendering. If 1001 Timing is enabled, the resulting frame rate is calculated by FPS * 1000 / 1001. This provides the possibility to capture with frame-rates like 59.94 and 29.97. There is an important difference regarding timing between the Interactive and Time-based mode: In Interactive mode, the rendering timing during the input recording and playout phase is based on the FPS settings in the active Ventuz Project. This is necessary because the input is recorded during normal rendering with the Project frame-rate. To provide a correct animation timing of dynamic elements like Damper or the Interaction nodes, the rendering during a playout is done with the same frame-rate. This means that in the Interactive mode capturing with e.g. 30 FPS will capture every second frame if the rendering/timing FPS is 60. In Time-Based mode timing and capture FPS are equal according to the value set in the FPS box. This makes it possible to create image sequences with e.g. 120 FPS.
In Interactive mode, the Frame Rate value cannot be changed. It is taken from the frame-rate configured in the Ventuz Device Configuration. Thus it is not possible to capture interaction in a scene running at 60 FPS and create a playout with 50 FPS!
5: Render and Statistics
A Render-To-Disk profile (.vr2d) with all settings and recorded user interaction can be saved and loaded for re-uses. Such a profile is not scene-dependent and can be used with any other scene.
Render To Disk starts the render and writing process.
  1. Configure the Render-To-Disk dialog as required and press the Start Capture button.
  2. The button changes to Start Recording and a reminder to prepare the scene so that recording can be started is shown. This preparation phase is also recorded but will not be captured during playout.
  3. After triggering Start Recording, the recording start time will be saved as well as all user interaction with the scene. During recording, a red R will be flashing in the upper right corner of the Renderer output. If all user interaction has been fed in or the required recording duration has been reached, press the Stop Recording button.
  4. If recording succeeded, the Render to disk and Play Interaction buttons will be enabled. Play Interaction will start a playback of the recorded interaction data. Make sure that the scene is in the same state as when the recording started - otherwise the interaction playback might not match the scene states.
  5. The concluding playout of the image sequence is triggered by pressing Render to disk. Again make sure that the scene is initialized to the same state as when the recording started if this is not already handled by the recorded preparation phase.
  • Snapshot node
  • Texture Saver node
