![]() | 3D Reference | This Layer Renders another 3D Layer a second time, but with the possibility to use another Layout, Camera, IPP Effects, Mask etc. |
| Image/Texture |
These Properties may vary for the different Layer-types. The most common Property is the Orientation Property which makes it possible to Rotate the Layer in any direction or Mirror and Flip it. There are several Layer-specific properties depending on the Layer Type. The Image Layer has Properties like the TextureFile and ColorSpace/Hint which control the color space and alpha mode, while for example the Constant Color Layer has a TextureColor Property. As mentioned before, each Layer Type may vary in the Layer Properties.
