String Splitter
The split is performed at every occurrence of the characters specified in Custom. This means that if your Custom string is e.g. *#- the characters *, # and - are separators. This also means that you cannot specify a whole word as separator!
If Lines or Tabs are checked, additional splits will be performed at the end of each line or at each tab respectively.
IsNullOrWhitespace provides feedback about the length of the string to handle the special case of an empty string in your scene's further logic.
  • String Operation Nodes
