Animation Editor Shortcuts
  1. Channel Tree
  2. Value Area
  3. Time/Diagram View
  4. Logic View
View
L Switch to Logic View
T Switch to Time View
D Switch to Diagram View
V Switch to Data View
Drag&Drop
Channel Tree
View
 drag Pan
Slice
double  or F2 Slice name Rename Slice
Channels
click  Channel Select
SHIFT click  Channel Multi-Select
CTRL + A Channel Select all
UP,DOWN,LEFT,RIGHT Channel Navigate Selection
double  Channel Rename
 drag Channel Drag&Drop, rearrange
CTRL  drag Channel Drag&Drop, duplicate channel
DEL Channel Delete selected Channels
 hold Channel Open context menu
click  Channel Collapse/Expand Folder
CTRL + P Channel Duplicate selected channels
CTRL + Q Channel Select all Channels which have the same parent
CTRL + SHIFT + INS Channel Insert new folder
CTRL + SHIFT + F Channel Create Single Channel
CTRL + SHIFT + I Channel Create Integer Channel
CTRL + SHIFT + B Channel Create Boolean Channel
CTRL + SHIFT + E Channel Create Event Channel
CTRL + SHIFT + T Data Channel Create String Channel
CTRL + SHIFT + O Data Channel Create Color Channel
CTRL + SHIFT + M Data Channel Create Enum Channel
CTRL + ALT + SHIFT + F Data Channel Create Single Array Channel
CTRL + ALT + SHIFT + I Data Channel Create Integer Array Channel
CTRL + ALT + SHIFT + B Data Channel Create Boolean Array Channel
CTRL + ALT + SHIFT + Y Data Channel Create Byte Array Channel
CTRL + ALT + SHIFT + T Data Channel Create String Array Channel
CTRL + ALT + SHIFT + U Data Channel Create Asset Channel
Time
 drag Time value Move Timeline
Drag&Drop
Value Area
View
 drag Pan
State
double  State name Edit State Name
Values
double  Value box Edit Value
 drag Value box Edit Value
Time/Diagram View
View
double  Zoom into View
 drag Pan
Ctrl  drag Zoom box selection
double  Toggle between Time and Diagram View
Timeline
click  free Area Set Timeline
 drag free Area Move Timeline
CTRL  drag free Area Move Timeline, limited to State Markers
 drag SHIFT free Area Move Timeline without refreshing editor
SPACE Play forward from current timeline - Pause
SHIFT SPACE Play backward from current timeline
J or Left or PgDw free Area move back 1 frame
Shift + (J or Left or PgDw) free Area move back 10 frames
Control + (J or Left or PgDw) free Area move to previous keyframe on selected channels
K or Right or PgUp free Area move forward 1 frame
Shift + (K or Right or PgUp) free Area move forward 10 frames
Control + (K or Right or PgUp) free Area move to next keyframe on selected channels
State Marker
State Marker name Select State Marker
 drag State Marker name Move State Marker
double  State Marker name Select State Marker and Jump
DEL selected State Marker Delete State Marker
S Create Hard-State and State Marker at current position
SHIFT S Create Soft-State and State Marker at current position
Keyframes
Keyframe Select Keyframe
Keyframe while moving it reset the current movement operation
SHIFT Keyframe Add Keyframe to Selection
SHIFT  drag free Area Selection Box
 drag Selection border Scale Selection in time
INSERT Create Keyframes on selected channels
DEL Delete Selected Keyframes
double  Keyframe Edit or change Keyframe value
Auto Keyframe
+ Activate Auto-Keyframe
Templates
M Data Change Set a template data change point
Time View only
View
 wheel Zoom time
Keyframes
 drag Keyframe Move selected Keyframes horizontally
CTRL  drag Multiple Keyframe Move selected keyframes in staggering mode.
Diagram View only
View
 wheel Zoom time and scale
CTRL  wheel Zoom time only
SHIFT  wheel Zoom scale only
Keyframes
 drag Keyframe Move selected Keyframes horizontally and vertically
SHIFT  drag Keyframe Move selected Keyframes vertically
CTRL  drag Keyframe Move selected Keyframes horizontally
Spline Handles
 drag Spline handle Move Spline Handle horizontally and vertically
CTRL  drag Spline handle Move Spline Handle horizontally only
double  Spline handle Open spline context menu
click  Spline handle Open spline context menu
Logic View
View
 wheel Zoom
 drag Pan
States
double  free Area Create Hard-State
SHIFT double  free Area Create Soft-State
S Create Hard-State
SHIFT + S Create Soft-State
click  State Select State
double  State Jump to State
 drag State Drag State
double  State name Rename State
 drag State name Change name location
B selected State Set Begin State
E selected State Set End State
P selected State Set Present State
N selected State Set Normal State
DEL selected State Delete State
R selected State Route the animation one step to the selected state.
Annotations
 drag Annotation borderResize Annotation
Connections
 drag State Create Connection
click  Connection HandleSelect Connection
double  Connection HandleNavigate to Connection
 drag Connection HandleMove Connection Handle
CTRL  drag Connection Handle Change Connection Style
Drag&Drop
