Shortcuts
  1. Default Shortcuts
    1. Application
    2. Edit
    3. Global Show Control
    4. Timeline
    5. Playlist
  2. Assign Keys
  3. Assign GPIs
  4. Remove Keys/GPIs
  5. Assign Shortcuts to a Macro
Starting with Ventuz Director V5.4, the shortcut manager was revamped to allow e.g. multiple keys per command. The shortcut manager can be found in the main menu under Tools / Shortcuts. The shortcut layout is stored in the user settings on a machine. To transfer a layout to other users and/or machines, use the export and import buttons.
The list below shows the most important default keyboard shortcuts. To reset a shortcut layout, use the "default" button.
Default Shortcuts
Director comes with a default set of shortcuts for the most common commands, most of them can be remapped, but some are uneditable and marked with X in the following tables.
Actions that can not be remapped are grayed out.
Application
Key Search Term Description Editable
Ctrl +  N show Create new show
Ctrl +  O show Open existing show
Ctrl +  S show Save current show
Ctrl +  Shift +  S show Save As current show
Ctrl +  1 (...9) channel Make channel 1 listen to user operations (take keys, cue, ...)
Alt +  F4 application Exit application
Ctrl +  Alt +  + view Activate next window layout
Ctrl +  Alt +  - view Activate previous window layout
F11 view Cycle fullscreen modes
F11 +  Shift view Cycle fullscreen modes (reversed)
+ (on number pad) shotbox Open ShotBox
Edit
Ctrl +  C edit Copy
Ctrl +  V edit Paste
Ctrl +  X edit Cut
Ctrl +  Z edit Undo
Ctrl +  Y edit Redo
Global Show Control
F1 showcontrol Take
F1 +  Shift showcontrol Take and cue duplicate
F2 showcontrol Update
F2 +  Ctrl showcontrol Toggle on-air editing mode
F2 +  Shift showcontrol Cue duplicate of on-air item
F3 showcontrol Take Out
F3 +  Ctrl showcontrol Clear
F3 +  Shift showcontrol Take out and cue duplicate
Timeline
F5 timeline Play
F5 +  Ctrl timeline Pause
F6 timeline Rewind
F7 timeline Forward
F8 timeline Jump to start
F8 +  Ctrl timeline Jump to end
Ctrl +  A timeline Select all items on timeline
Ctrl +  D timeline Deselect all items on timeline
Playlist
F4 playlist Restart playlist
Ctrl + Shift +  Up playlist Move all selected items one row up
Ctrl + Shift +  Down playlist Move all selected items one row down
Alt + Ctrl + Shift + Up playlist Move all selected items to the top of the playlist
Alt + Ctrl + Shift + Bottom playlist Move all selected items to the bottom of the playlist
Ctrl + A playlist Select all playlist items
Delete playlist Delete selected items
Assign Keys
Every command can handle up to 3 triggers. To assign a new trigger to a command simply follow these steps:
  • select a command in the list
  • either assign a key by pressing it on your keyboard
  • or choose the key and modifier from a list of keys
  • press Assign
Keys that are not on your keyboard can be assigned through the provided list
Assign GPIs
To assign a GPI trigger follow the steps above and select VTZ_GPI_Pxx from the provided key list.
The GPI configuration and the assignment of the pins is documented here.
Remove Keys/GPIs
To remove a key or GPI from a command follow these steps:
  • select a command from the list
  • select one of the assigned keys/GPIs
  • press Remove
Macros are created within the Macro Editor, every defined macro or group of macros is reflected inside the Shortcuts Editor with its name and Shortcuts or GPI Trigger can be assigned.
