How To Get Ventuz Running
  2. Requirements
  3. Ventuz License Features
  4. Installer
  5. Using the Designer
  6. Layer, Hierarchy and Content
  7. Properties
  8. Conclusion
Requirements
  • Windows 10 with latest service pack installed. Neither Windows XP nor Vista are supported from Ventuz 3 upward and Windows 7 and Windows 8 from Ventuz 7 upward.
  • Graphics Card: This can either be a consumer or professional grade card but it should have dedicated graphics memory. Although it is technically possible to run Ventuz on even a cheap built in laptop 3D chip (as long as it supports DirectX 11), those chips can exhibit weird behavior for demanding 3D applications. If you plan to run Ventuz in a professional environment, we recommend buying a professional card such as an AMD Radeon Fire Pro or nVidia Quadro. Trust us, in the long run they will be cheaper than hunting down weird last minute problems just before running a show...
  • Latest Graphics Card drivers installed
  • A user account with administrator rights. Depending on your machine's security policies, it may suffice to have an ordinary user account.
For this How To, we'll assume that you haven't purchased a license yet and simply requested a PLE or Community license key as described on the Getting Started page.
Installer
All installers can be found on the ​Ventuz Download page. Get the latest one as it will contain all bugfixes and features available at that point.
Using the Designer
Nodes are the building blocks for constructing a Ventuz scene. Each node has a name, an icon and some function it fulfills. There is, for example, a node to create a 2D Image Layer. Click on the Layer tab inside the Toolbox and locate the icon next to the label saying "Image Layer".  Left-click on the icon and hold the mouse button. Continue to hold the button and move the mouse cursor straight up to the Layers Editor on top of it. Release the mouse button and you should see a checker image in the render output. You have added your very first node to a scene. To change the image you can just on the image thumbnail that opens a Fileopen Dialog.
Add a 3D Layer to your scene and press the Edit button. Also switch the Workspace to 'Logic. Again press SPACE to open the Toolbox go to the Geometry category and add a Cube node to the Hierarchy Editor
Keyboard Shortcuts are an important part to Ventuz and will help you in crating your projects efficiently.
If you are working with 3D Layer and you press the Edit button in the Layer Editor you see an area that is called the Hierarchy Editor. The Hierarchy of a scene is a tree of nodes that define the 3D world. This can be Geometry, Axis to position elements, Material assignments, and much, much more. You may have noticed in the Toolbox that there are nodes that have brackets to the left and right of the icon and others with brackets at the top and bottom. The former ones are Hierarchy Nodes which belong to the Hierarchy, the latter are content nodes which belong to the Content of a scene. As you can see in the Content Editor (right next to the Hierarchy Editor), the cube belongs both to the Hierarchy and the Content. This is true for all Layer and Hierarchy Nodes.
Properties
Click on the Cube and you will see a table with multiple rows. Locate the one saying "X" and  double click on the number right next to it. Enter another value - let's say 5 - to change the cubes size in X direction. Notice how the white square in the render output gets larger. The input properties of a node influence how a node performs its function. Now click on the "Outputs" button in the Property Editor. As you can see, there is nothing here.
Okay, this may be a silly example, let's delete it.  click on the arrow between the two nodes and click on the little cross to delete the binding. Let's try something else:
  • Add a Mover node to the content (hint: it's in the Animation tab)
  • Change its properties: min to 0, max to 360 and duration to 5
  • Add an Axis in front of the Cube in the hierarchy (hint: it's in the World tab. To insert it, drag it to the left side of the cube icon until a red arrow pointing to the left appears)
  • Bind the Axis Y-rotation to the Mover's Value output.
We've got a rotating cube! Do you get how it works? The Mover takes 5 seconds to go from 0 to 360. It puts its current value into the output property which than feeds the rotation around the Y-axis in the Axis node. But wait, the Mover moves from 0 to 360 and back. Let's change that... but we're not going to tell you how. Move the mouse over the Mover node and press F1. This will open the user manual description for this node where you find all the properties described. See if you can find out yourself what you have to change so it continues to rotate into one direction...
Conclusion
  • Ventuz Help Start Page
  • Ventuz User Interface
  • Nodes and Bindings
  • Keyboard Shortcuts
