Keyframe Animation
Keyframe Animation This node contains the animation curves and the animation logic for all bound properties.
Animation Group Groups different Keyframe Animations to be concurrent in the Template Engine.
Animation Node vs Main Animation
By default, the scene has a Main Animation that can be accessed in the Animation Editor from anywhere in the scene. But in contrast to most 3D applications, Ventuz does not have to associate animations with the scene directly. Instead, the curves, keyframes and logic information of an animation also can all belong to a Keyframe Animation Node. A scene can therefore have any number of independent animations each with its own set of animated properties, timeline and keyframes. The information of an animation can be edited in the Animation Editor by changing the edited Animation with the dropdown menu. For more information on animations in general, see Animation and State Engine.
Each Keyframe Animation node contains a timeline which is independent of the global scene time. To play an animation without a State Logic, a Control Node has to be bound to the Control Input Property.
Animation Logic
Each node will then provide a number of Input Methods that can be used to interact with the state machine. For an explanation on the semantics of Begin/Next/Prev/Present/End, please refer to Animation Editor. Additional methods can be added by using the Custom Model button. When the AutoBegin property is true, the State Machine will jump to the Begin state when the scene is being opened.
Animation Group
The Animation Group Node can be used to make multiple Templates in a Keyframe Animation Node mutually exclusive. To group Keyframe Animation Nodes the Control Input Property has to be bound to the Animation Group Node. Bound Keyframe Animation Nodes have a similar icon as the Animation Group Node. For more information about Templates and the meaning of the Animation Group Node, see Template Engine.
  • Animation Controls
