Layers, Containers and Interfaces
  2. Creating a Container
    1. Merge to Container
  3. Navigation
  4. Outputs
  5. Exposing Properties
    1. Property Tabs
      1. Hidden number Sorting
  6. Layers as Containers
  7. Sealing Containers
  8. Interfaces
    1. Defining an Interface
    2. Expose Properties to an existing Interface
    3. Replacing Interface Content
    4. Layers as Interfaces
    5. Repositories and Interfacing
A new container is created in the same way as all other nodes, by dragging  the Hierarchy or Content Container to the respective part of the scene. Since this is a very generic node and a scene often contains different containers, it is advisable to give it an appropriate name right away by double clicking  on the name of the node. It can even be assigned a new icon by selecting the node and then choosing Node/Icon/Open in the main menu bar. Nodes can be added to a Container by cutting them from the hierarchy, navigating into the Container and then pasting them or just create them inside the Container directly.
Merge to Container
An alternative way is to select a node and then use Node/Merge To Container from the main menu bar. This will replace the selected subtree with a container and place the removed nodes inside the container.
Next to merging a selection to a Hierarchy Container it is also possible to merge content nodes to Content Container.
There are basically four different ways of merging:
  • Selection in Hierarchy Editor
    1. A single Hierarchy Node is selected with children.
      If all selected nodes (including value suppliers) are only connected to this partial tree - the merge is performed and a new Hierarchy Container is created
  1. A single HE node is selected without children click +CTRL.
    Only the single HE node is merged with all its suppliers - a new Hierarchy Container is inserted at the previous location. The icon of the previously selected HE node is exposed. Outputs and multi-links are maintained.
  • Selection in Content Editor
    1. Only CE nodes are selected.
      All nodes are merged into a new Content Container. Bindings that pointed outside the selection are re-created by new exposings.
  1. A single HE node is selected and optional one or multiple CE nodes.
    Basically the same as Selection in Hierarchy Editor (2) (above) but only the selected CE nodes are merged. Bindings that pointed outside the selection are re-created by new exposes and the icon of the previously selected HE node is exposed.
All container nodes can be easily recognized by their gray triangle on the left inside of the node icon. By double clicking  on that triangle or pressing ENTER, the editor leaves the current hierarchy level and switches to the inside of the container. When inside a container, the starting point of the hierarchy is not the familiar scene root T-junction, but the container root, a white triangle. Double clicking  on that icon or pressing BACK takes the Hierarchy Editor out of the current container. You can also use the Container Level Up Button or press CTRL + U and Level Down Button or CTRL + D to navigate through the container levels. Pressing  inside the Hierarchy Editor will display a popup window with the Hierarchy Container structure of the complete scene. This overview can also be used for navigation; just click on the desired container. A very comfortable way to enter and leave containers is to use the click . Just hover with your mouse over the Arrows and click .
Outputs
By default, a Hierarchy Container is created with one Output Node already inside of it. An Output represents a connection back up to the parent hierarchy level and allows nodes or subtrees to be placed behind the Container.
Exposing Properties
To quickly expose a property without changing its name or category, click  the small square to the left of the property. To quickly "un-expose" a property, click  on the square. A double-click will bring up the Expose dialog.
Property Tabs
With Ventuz 6.6 we introduced Property Tabs. These allow to sort your properties into custom tabs. To do this simply doubleclick  the expose button and a new window will pop up.
If you want to add multiple exposed parameters to one tab, you need to expose the needed properties on the node itself first. Then jump up one level and mark all of them with shift + Left click .
Right click  one of the selected items and add them to an existing tab, create a new one or even remove it from the current tab.
It is also possible to sort these Property Tabs by hidden numbers instead of the Alphabet. To do this you only need to name your Tabs by starting with a number. This number will not be displayed.
Layers are a special kind of Containers. They can only be placed on the Layer Level - the highest Level of the Scene which can be accessed in the Layer Editor - and thus have no hierarchical relation like Hierarchy Containers. Inside each Container there you can place Content and Hierarchy Nodes and expose their properties like you can do with Hierarchy and Content Containers. To get inside a Layer you have to click  the Pencil-Icon on the corresponding Layer. By just clicking the Layer itself you select it like any other Container and make it visible inside the Content Editor to be able to bind its Exposed Properties to other Content Nodes' or Layers' Outputs.
3D Layers work similar to a Hierarchy Container - they have an inner Hierarchy tree that gives instructions to the Renderer. Since Layers do not lie in a Hierarchy themselves they cannot use Output Nodes. All other Layers (except for Layer Groups, Switches and the Photoshop Import) work similar to a Content Container. They have no inner hierarchy but a network of Content Nodes.
Each Layer has a Root Node which is placed inside the Layer and cannot be removed. A 3D Layer's Root Node is found at the very top-left of the Hierarchy Editor. A 2D Layer's Root Node is always visible in the Content Editor and has no horizontal brackets (like Content Nodes) but only their corners around its icon. A Root Node's properties can be bound and exposed like of any other Node as well. Some of its properties are exposed by default, some other need to be exposed manually to make them accessible from outside.
Also Layers cannot be placed inside a Container (since they have to be located on the Layer Level) and therefore you cannot merge them to a Container. For this purpose, there are Layer Groups.
Sealing Containers
Sometimes an author wants to distribute some customized functionality to another user. The end-user should be able to render and tweak the functionality but not be able to see how it is done. In such a case, the functionality can be wrapped into a container which is then sealed (via Node/Seal Container). There are two types of seals:
  • Simple Seal: This acts like a write-protection on the container. A user cannot step into the container while it is sealed but anyone can remove the seal by using Node/Seal Container again to unseal the container.
  • Seal with Password: A password needs to be provided to seal and unseal a container.
  • Permanent Seal: This permanently removes all possibilities to get inside the Container. This type of seal cannot be undone, therefore the author is advised to create a backup of the unsealed state somewhere.
Interfaces
When removing a node that exposes a property, the interface property stays intact but is visualized in a light gray color. To remove an interface property definition, either double  click on the interface property and press Exclude or use the CleanUp button at the bottom of the Property Editor to remove all interface properties without an corresponding exposing node.
To expose a property to an existing Interface Property,  click and select the desired interface property under the Expose... menu or  click on the small square to the left of the property to pop-up a choice of existing interface properties. Please note that only interface properties of the correct type will be listed!
When using drag & drop with an Interface Container, all containers in the scene with an interface defined are highlighted with a dark gray border. When dragging  the selected container over such an interface container, the target's border changes to red. Releasing  in this state will not remove the original node but replace the targets content with that of the source node. The same behavior is achieved by using Edit/Copy and Edit/Paste Container Content from the main menu.
  1. Property Type must be identical: Input Value, Output Value, Method, Event
    1. If the type is Input or Output Value, the SubType must be identical
    2. (float, integer, string, matrix, …)
  2. Property Names must be identical.
  3. The names are compared case sensitive while the category is ignored.
Layers may be turned to Interface Containers in a similar way as Hierarchy and Content Containers. Though, they are only capable of keeping an unexposed property so that bindings will not be lost. Their content cannot be replaced by that of other Interface Layers.
Interface Containers can be used to easily change and update other instances by using the Repository. To do so you can create a Repository Item by dragging an Interface Container into an opened Repository. Now every new instance of this item will reference it and thus can be updated very easily. See Repositories for more information on how to exactly do that.
  • Container Nodes
  • Toolbox and Repository
